Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
09-17-2012, 07:19 PM | #1 |
Drives: Rocket Bunny FR-S
A few problems...but how bad are they?
So I've had my FR-S for a little over 2 months now and I've been experiencing a few issues that dont seem too big of a deal ( in my opinion) but they could be worse than I really think.
First, im experiencing the idle issue where my car drops to 400-500 rpm and then jumps back up before it stalls. My car has actually stalled or the engine simply turned off WHILE I was moving. I was coasting at about 20-30 mph in neutral and when I tried to accelerate, I realized my car was off and I would have to restart it which happened twice. This worries me a bit more. I also have issues starting the car once in a while. I've tried starting the car and turned the ignition on and it would take a few seconds for the car to start rather than the normal quick start up. It would choke for a while and after a few seconds it finally stars. This has happend a couple/few times. Anyone else experiencing these problems or have any advice/tips for me? I know the idle issue is common and I also read that some people are being compensated for some issues? Only mod I have is an Injen Intake. |
09-17-2012, 11:07 PM | #2 |
Drives: 2013 DGM BRZ Limited
The rpm dip/stalling resulted in my CEL coming on shortly after. Could also be a sign that the intake wasn't installed properly.
09-18-2012, 12:18 AM | #3 | |
Drives: 2013 FR-S Navy Blue
09-18-2012, 03:16 AM | #4 | |
Ill probably bring it into a dealer but not sure if they are gonna make a fuss about an aftermarket intake and void my warranty... |
09-18-2012, 05:15 AM | #5 | |
Drives: Supercharged Car
09-18-2012, 01:02 PM | #6 |
The Following User Says Thank You to deedz For This Useful Post: | ftc~brz (09-18-2012) |
09-18-2012, 02:39 PM | #7 |
NASA SpecE30 Racer
The car turning off while coasting with the clutch in is definitely an intake issue. I have seen this in other cars as well. The tubing and filter are not giving the MAF a good reading under those conditions confusing the ECU.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
09-18-2012, 03:39 PM | #8 |
Would it most likely be installer error? or is it just because the ECU is not flashed to know the intake is there?
09-18-2012, 03:43 PM | #9 | |
As far as startup, the engine turns over normally, but in hot weather it'll shutoff at almost every stop i come to and then have weird prolonged starts. I believe it is the MAF sensor and the tubing or filter is messing with the airflow, giving the ecu incorrect readings.. I've had my car for a little over 2 months now and just swapped to the injen intake a week in a half ago. No problems prior to the install, so i will probably go back to stock, even though the intake does make the car sound a little nicer. |
09-18-2012, 05:05 PM | #10 | |
09-18-2012, 10:45 PM | #11 |
First 86
Drives: Scion FRS Argento Automatic
What kind of gas are you using?
Life is short...NO BORING CARS |
09-20-2012, 04:03 AM | #12 |
04-28-2013, 07:44 PM | #13 |
Drives: GBS BRZ Limited
Any potential solutions to this? I've been encountering the same issue. Reseted my ECU several times and etc. I am going to go back to stock because the engine cut off is pretty damn annoying.
04-29-2013, 12:45 PM | #14 |
NASA SpecE30 Racer
The ECU is not prepared for the turbulent air that is being created by the intake while coasting. Then when the RPM drops it is not able to hold it at idle. No amount of ECU resetting will fix this. Either keep a little throttle to keep it from stalling, get an ECU tune, find a way to modify the intake to straighten the air, or put the stock airbox back in.
- King Tut
Similar Threads | ||||
No CEL problems here | BRZranger | Issues | Warranty | Recalls / TSB | 41 | 12-08-2012 02:36 PM |
Engine problems | Gerri | Engine, Exhaust, Transmission | 2 | 08-14-2012 08:14 AM |
Anyone else having bluetooth problems? | Scooter Style | Electronics | Audio | NAV | Infotainment | 8 | 08-03-2012 07:38 PM |
Problems with detailing | Nezz | AUSTRALIA | 23 | 06-28-2012 10:08 AM |
Do you think this car is going to have some problems? | Huss | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 03-21-2012 02:48 PM |
