Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
07-27-2016, 03:21 PM | #1 |
Drives: 2015 Ultramarine FR-S
Humidity Issue?
whats going on guys, so i have a quick question for ya guys... anyone in the northeast area of the country of the great country of the USA (philadelphia) have any issues the past week or so with their clutch pedal feeling really spongy? i think its just the humidity, but idk...
ALSO.... im OFT stage 2 UEL on 93oct, anyone having a horrible lag issue with throttle response? i think its JUST humidity, but was curious to see if anyone else has had the issue? |
07-27-2016, 04:49 PM | #2 |
I'd guess your observations are due more to the heat than humidity...........
humfrz |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | Ultramaroon (07-28-2016), zc06_kisstherain (07-27-2016) |
07-27-2016, 05:47 PM | #3 |
see the heat is at like 90-98 degrees with humidity... but the heat can make it lag that bad??? its got like a 2/3sec hesitation before the throttle feels like it actually does something
07-27-2016, 06:11 PM | #4 | |
As far as the increased lag with higher temperatures, other than noting that warmer air carries less oxygen, I'm really not sure. Captain obvious is asking if you're running the A/C more ..... ?? humfrz Last edited by humfrz; 07-28-2016 at 02:12 AM. |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | SlammedSilly (07-28-2016), Ultramaroon (07-28-2016) |
07-28-2016, 08:10 AM | #5 | |
The Following User Says Thank You to SlammedSilly For This Useful Post: | humfrz (07-28-2016) |
07-28-2016, 08:53 AM | #6 |
Huge E85 fan!
Drives: 2016 Scion FRS
Heat and humidity is pretty much a full time thing here in Florida. I don't have either of the probs the OP has. I think you have something else going on.
The Following User Says Thank You to guybo For This Useful Post: | Tcoat (07-28-2016) |
07-28-2016, 09:03 AM | #7 |
see i plugged my oft in, and had my friend watch the real time data, and he said everything looked absolutely fine, so idk, on top of all this my friend who works at a toyota dealer said that the clutch feels terrible in my car, hes like granted you have 30k on it, but something is not ride, im gonna bleed the slave and go from there and see what happens
07-28-2016, 11:19 AM | #8 | |
Drives: Whiteout FRS
07-28-2016, 12:49 PM | #9 |
Change your brake and clutch fluid and then get a steak extra cheese wit!! or 2
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete Last edited by stevesnj; 07-28-2016 at 01:04 PM. |
The Following User Says Thank You to stevesnj For This Useful Post: | SlammedSilly (07-28-2016) |
07-28-2016, 02:23 PM | #10 |
The Following User Says Thank You to SlammedSilly For This Useful Post: | stevesnj (07-28-2016) |
07-28-2016, 02:45 PM | #11 |
Drives: '95 delSol, '13 EvoX, '14 Leaf
Geno's > Pat's
*drops mic* |
The Following User Says Thank You to scmil95eg For This Useful Post: | SlammedSilly (07-28-2016) |
07-28-2016, 03:04 PM | #12 |
OREGON STEAKS OVER ALL
07-28-2016, 08:56 PM | #13 |
I've been eating Pat's forever, I heard Oregon has good steaks, gotta try it. But I tried Geno's 3 times and to me they were just awful, better roll but crap on the inside.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
The Following User Says Thank You to stevesnj For This Useful Post: | SlammedSilly (07-29-2016) |
07-29-2016, 10:07 AM | #14 | |
you will be in heaven, not the greatest are after 10pm, but if you go with a group of people, you'll be fine! but day time is completely fine |
The Following User Says Thank You to SlammedSilly For This Useful Post: | stevesnj (07-29-2016) |
Similar Threads | ||||
AT frs rpm issue | ricebox | Issues | Warranty | Recalls / TSB | 18 | 01-04-2016 01:01 AM |
OFT IAM issue | Tectoniic | Software Tuning | 23 | 10-28-2015 05:52 PM |
Need help with FI issue!! | Jhood | Forced Induction | 16 | 09-07-2015 10:04 PM |
a little issue here | Asian Delight | Electronics | Audio | NAV | Infotainment | 8 | 02-10-2014 03:32 PM |
LED DRL issue | CaptainSlow | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 08-12-2013 05:15 PM |
