07-03-2023, 01:23 PM | #85 |
Drives: Too fast
We all used to have the moroso 5.5L road race oil pan in our B-series honda back in the days, which had directional doors to prevent starving. It worked very well and was super reliable. I looked for pics, but they all suck as the top baffle hides the doors.
https://jhpusa.com/en-ca/products/mo...affled-oil-pan |
The Following User Says Thank You to dsc_pat For This Useful Post: | 900BRZ (07-04-2023) |
07-03-2023, 03:26 PM | #86 |
Drives: 2023 brz limited 6mt red
Of all the technology and rigorous testing goes in a car and particularly this car did they just run an oil pressure gauge on a stationary dyno and check the box? Why would you not thrash the vehicles in its natural habitat with all data inputs running to measure all values and literally tell people to abuse the car to find its weak points?
You wonder if the fa20 they got lucky and applied the same bogus test that they clearly didn’t try here.
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles |
07-03-2023, 03:52 PM | #87 | |
Drives: None
In either case, it would seem FA pan design is somewhat limited by the header.
The Following User Says Thank You to RedReplicant For This Useful Post: | 900BRZ (07-04-2023) |
07-03-2023, 04:12 PM | #88 |
Drives: honda element
Likely needs a different style pickup and/or an aftermarket oil pan.
I know its not rocket appliances - but all of your pressurery tests and graphicy graphics are nice and all - but you could chase the problem down with a gopro pointed at a cup of water in the car. sync the timing of the gopro to the oil pressure and whatever the water is doing the oil is doing. then focus on baffling that region. Last edited by austintampa; 07-04-2023 at 01:05 AM. |
The Following User Says Thank You to austintampa For This Useful Post: | Arthur-A (07-03-2023) |
07-04-2023, 12:34 AM | #89 | |
Drives: Supra MKV, FR-S
07-04-2023, 03:40 PM | #90 | |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
07-05-2023, 12:11 PM | #92 | |
Drives: '23 BRZ
So, I ran a very right-hander intensive track last week (NJMP Lightning) and will be running a very right-hander intensive track next week (Thompson, CT). I somewhat limited my laps at NJMP and plan to do the same at Thompson. Also intend to do 85% of laps on RT660s and save the A052s for one abbreviated practice session and the time trial. Q: how comfortable do you feel lapping your car with these pressure drops? Considering Accusump, but my old 240Z's 3.1 lasted a decade and maybe 80 track days, dropping pressure every single right-hander, before I ran it low on oil at VIR and wasted a bearing... Installed a higher-capacity Nismo baffled pan with the rebuild! For sure this loss of pressure will drastically reduce engine life in a tracked car, but I wonder if early-on failures might be a result of partially RTV-blocked oil passages combined with pressure drops. Pure speculation... Anyway, obviously you're taking this *very* seriously so I'm curious how much you are limiting your track time based on still experiencing pressure drops. Thanks! Last edited by ZDan; 07-05-2023 at 02:19 PM. |
The Following User Says Thank You to ZDan For This Useful Post: | NoHaveMSG (07-05-2023) |
07-05-2023, 02:01 PM | #93 | |
Drives: 2022 Subaru BRZ
I just recently bought a front BBK for roughly the same cost as an FA24 short block through Subaru. Obviously that doesn’t include the labor involved in rebuilding the engine, but it helps keep things in proportion. |
The Following 4 Users Say Thank You to 900BRZ For This Useful Post: | RacingredGR86 (07-05-2023), raisingAnarchy (07-05-2023), RedReplicant (07-06-2023), ZDan (07-05-2023) |
07-05-2023, 02:14 PM | #94 | |
Drives: Crapcan
07-05-2023, 05:21 PM | #95 | |
What I’m thinking about right now is: If we can’t address the speed at which the oil returns, then all we can do is try to keep as much oil available to the pickup as possible. I think the Kazama design can help by reducing the effects of the offset pickup. I’m also thinking the Kazama-style baffle in combination with an overfill might be good enough to even out most of these drops. Of course, accusumps or dry sumps are still an option down the line, but even an accusump becomes less necessary if you can mechanically keep the oil available to the pickup with a baffle. |
The Following 5 Users Say Thank You to 900BRZ For This Useful Post: | Arthur-A (07-05-2023), Frost (07-06-2023), NoHaveMSG (07-05-2023), raisingAnarchy (07-05-2023), ZDan (07-05-2023) |
07-05-2023, 05:49 PM | #96 |
Drives: 2023 Gray BRZ
Do you think it is possible the pump is having trouble re-establishing its prime even after the pickup tube gets back in oil? Or do you think the pickup is starved for oil throughout the low-pressure interval?
How much oil is there in the pan while going down a straight... and do you add significantly more oil to make up for the oil cooler volume? Yeah... lots of questions :-) |
07-06-2023, 01:16 AM | #97 | |
Drives: 2023 GR86
Check out this article from almost a decade ago:
http://www.speedhunters.com/2014/01/...s-own-racecar/ Quote:
07-06-2023, 09:37 AM | #98 | |
The Following User Says Thank You to Frost For This Useful Post: | ZDan (07-06-2023) |
Similar Threads | ||||
2022+ BRZ/GR86 FA24 Oil Pan Baffle - Ansix Auto | Ansix Auto | Engine, Exhaust, Bolt-Ons | 0 | 11-18-2022 06:15 PM |
Killer B Motorsport 2022 BRZ Dyno Plot with Oil Pressure and Temp | KillerBMotorsport | BRZ Second-Gen (2022+) -- General Topics | 50 | 10-29-2022 08:36 AM |
High Flow Oil Pickup by Killer B Motorsport | KillerBMotorsport | Engine, Exhaust, Bolt-Ons | 4 | 04-26-2022 10:51 AM |
FS: NEW Bluemoon Oil Baffle & Killer-B pick up tube. | FRSH86 | Engine, Exhaust, Bolt-Ons | 2 | 04-20-2020 11:49 AM |
Compatibility: Moroso Baffle and Killer Bee Oil sump | Nightflo | Engine, Exhaust, Transmission | 3 | 04-27-2019 10:40 PM |
