Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
03-20-2018, 08:01 PM | #1 |
Drives: 2013 Toyota 86
Pads not releasing enough on new dba4650s rotors
Hi, after hating my stock brakes at my first track day I decided to upgrade the pads/rotors/fluid.
I bought some dba4650s rotors with new high performance pads for the front. When putting the calipers back over the new rotors and pads it was extremely tight. When I looked into it further the dba rotors are 1mm thicker than oem (25mm compared to 24mm oem). DBA have confirmed these are the correct rotors and that 1mm thicker isnt a problem. The pads are rubbing on the rotor without my foot touching the brake pedal. The pads have a few bubbles where they have overheated. When I feel the caliper after a short gentle drive they are quite hot. The back dba rotors are identical to oem, the calipers fit over no problems and the calipers are cold after a gentle drive. Has anyone else experienced this with dba front rotors or any tips in general? I could grind down the pads a bit but they have a special bed in coating on top so I dont want to do that . |
03-20-2018, 08:29 PM | #2 |
Drives: Legacy GT
Do you have any shims on the back of the pads? You can remove them for a little extra clearance and then reinstall after a bit of wear if you're getting noise.
03-20-2018, 08:54 PM | #3 |
Yes there are shims, thats a great idea!! Will try that
04-05-2018, 09:16 PM | #4 |
Installed the new pads without shims and no dragging! Rotor spins freely, thanks for the advice!
Similar Threads | ||||
WTB: Stock pads and rotors | tawheed | Want-To-Buy Requests | 0 | 08-09-2014 03:26 PM |
Replacing Pads without doing the rotors | robtan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 07-29-2014 10:59 PM |
DBA Brake Rotors - T3 4000 Series (DBA4650S) | smellslikecurry | Brakes, Suspension, Chassis | 10 | 12-21-2013 04:02 PM |
GTS OEM rotors and pads | yomchi1989 | AUSTRALIA | 1 | 12-30-2012 04:47 PM |
GTS OEM rotors and pads | yomchi1989 | Australia Classifieds | 0 | 12-28-2012 06:28 PM |
