Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
10-03-2014, 10:34 AM | #85 |
Drives: 2015 BRZ Series Blue
I purchased the pearl one, received it yesterday and installed it. Appearance is great. It feels great. My only slight issue with it is that now when I put the car in neutral from reverse the switch doesn't release 100%. I mean it lets go but it doesn't pop back smoothly and sometimes I have to push it back down all the way.
Anyone else have this slight binding issue? |
10-10-2014, 03:41 AM | #86 |
Is not fast.
Drives: 2014 Whiteout M/T
Just ordered mine tonight, so I'll see if I can replicate your issue when it comes in. However, it's the first mention of it so far so you may have gotten a bad knob. I'd consider contacting Team Voodoo to see if they can do anything for you.
10-15-2014, 09:00 PM | #87 |
Is not fast.
Finally installed. Originally spun aluminum finish, painted it with Duplicolor Engine Enamel with ceramic. Now it doesn't get unbearably hot when left uncovered in the sun. Not as insulating as plastidip, but much tougher and better looking, nice gloss without clear coating. No binding issues with the reverse lockout so far. Loving the voodoo knob. Definitely a different feel from my Anarchy Motiv. Lighter than stock but it feels smoother through the gates. Also, because it's ever so slightly shorter, it feels like the throws are shorter too. Amazing value for money, would absolutely recommendd |
10-15-2014, 10:02 PM | #88 | |
Drives: BRZZZ
10-16-2014, 05:39 AM | #89 | |
Is not fast.
1. Anarchy Motiv is stainless steel and weighs well over a pound whereas the Team Voodoo knob is aluminum and weighs slightly less than the stock knob. 2. Anarchy Motiv comes in a wide gambit of colors; Team Voodoo you have four choices I think? 3. Anarchy Motiv is much more expensive than the Team Voodoo knob. 4. Anarchy Motiv knob is larger overall, not just the weight, and it sits much higher when installed because the Team Voodoo knob has recessed threads. I wouldn't really say one knob is better than the other because they're tailored to two different types of shifting. The Anarchy Motiv knob is an absolutely spectacular knob for people who want plush shifts with minimal effort. You'll rarely see the Anarchy knob vibrating as you idle because of the sheer mass. All you need to get the knob to fall into its gate is a swift nudge. By contrast, the Team Voodoo knob is much better suited to people who prefer crisp feeling shifts. If you want to experience a taut shifter with no vagueness whatsoever, this is your knob. Satisfying clicks as you row through the gears. There's a bit more effort involved to work through the gears, but you never have to wonder which gate you're about to slide into. I think both shift knobs are spectacular at what they're designed for. Ultimately, as my transmission broke in more, I found myself preferring a crisper feeling shifter over a smoother feeling one. And now that I've discovered the wonders of Engine Enamel Paint, I no longer have to worry about burnt hands or peeled off plasti dip! |
03-27-2016, 07:04 PM | #90 |
Drives: Subaru BRZ
Just ordered the textured voodoo. Hadn't realised the £ to dollar rate was so bad atm!
09-21-2020, 09:01 PM | #91 |
Drives: 1999 Miata
Just got my VooDoo Magnum, in piano black.
DJ
1999 Miata VVT swap "Maggie" 2013 BRZ "Nancy-Drew BRZ" |
09-28-2020, 03:49 AM | #92 |
Drives: '16 BRZ
That looks great. I will upgrade mine also once I'm done with my sound system.
Similar Threads | ||||
Stock shift knob weight | pkny | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 07-30-2015 09:11 PM |
2012 Scion Tuner Challenge Team VCMC powered by Shift Autosport!! | VCMC-STC | Tracking / Autocross / HPDE / Drifting | 69 | 02-05-2014 03:47 PM |
Any Red Leather shift knob for an AT? | Liquidsnake | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 06-19-2012 08:02 PM |
Report: Supercharged Toyota 86 being developed by TRD!! | Craikeybaby | Engine, Exhaust, Transmission | 205 | 03-04-2012 03:42 PM |
