Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-08-2020, 01:43 PM | #57 |
Drives: Bone stock
09-08-2020, 02:03 PM | #58 | |
Drives: 2017 Subaru BRZ w/ Performance Pack
That's what I thought, but it says on their page specifically that it isn't. I think that's just a copy pasta from the WRX ones tho, cause it's the same site as subispeed.
2017 Subaru BRZ Performance Pack - Brembo Brakes - SACHs Dampers - Wedsport TC-105x 18x8.5 - Michelin Pilot Sport 4S 245/35 - STI Short Throw Shifter
09-08-2020, 02:18 PM | #59 |
I mean I guess if these mounts fit WRX and BRZ, you'd figure the Group N for WRX 2015+ fits BRZ as well?
The Following User Says Thank You to doku For This Useful Post: | Joveen (09-08-2020) |
09-08-2020, 02:39 PM | #60 |
Drives: Bone stock
09-08-2020, 02:41 PM | #61 |
Drives: Bone stock
09-08-2020, 02:47 PM | #62 | |
Drives: Bone stock
Sent from my SM-N960U using Tapatalk |
09-08-2020, 07:15 PM | #63 | |
Drives: 19' Toyota 86 TRD
I was actually in the same boat as you and decided the perrin mounts are better buy. Better construction IMO, the STI mounts feel like stock from what I heard so its not much of an upgrade if you do go that way. Perrin is also cheaper It does vibrate a little at idle, but not annoyingly, and my girlfriend hasn't made a fuss of it yet. It really does help with shifting especially in lower gears as I don't have as much movement of the transmission/engine moving from side to side when shifting/using the throttle, although it definitely has more "jerk" to her. EDIT: Yes it was the header rubbing with the plate Last edited by hifiguy99; 09-28-2020 at 10:04 AM. |
09-08-2020, 07:23 PM | #64 | |
I don't think Group N engine mounts exist for our car or the 2015+ wrx |
09-08-2020, 07:42 PM | #65 | |
I have no idea personally, but it makes sense to me that if those mounts fit a 2015+ STI, then the 2015+ STI group N should fit the BRZ? I'm looking at this: https://www.ftspeed.com/part/fr-s-br...toyota-86-2017 Versus this: https://www.subispeed.com/part/15-st...ounts-2015-sti Not trying to say anyone is wrong, I'm planning on getting the regular STI ones and I'm not particularly bothered about them being N or whatever.
09-08-2020, 09:08 PM | #66 | |
Drives: Bone stock
09-09-2020, 11:28 AM | #67 | |
Oh right, I forgot the STI was still using the old engine and the WRX was using the new one. I actually talked to the dealer about this cause he was saying some people were buying up the current model before they change the engine and some were waiting for more displacement.
10-03-2020, 01:23 AM | #68 |
Drives: 2013 FRS, 2015 FRS Turbo
I just installed the new and updated Perrin motor mounts I bought from them directly. My car is FI with 8k miles and the stock motor mounts were shot. I did not remove the header as it would include removing the turbo too. Loosen the steering rack bolts and you can squeeze in a ratchet to get the driver/passenger side engine mount bolt.
It was pretty easy. Lift up car, remove the under body covers. Unbolt subframe bolts. Jack up engine by oil pan. Turn steering wheel left. Remove steering rack bolts. Use impact wrench to remove the top and bottom bolts for the driver side. Install. Repeat other side. When I was lowering the engine to get the stud of the mount into the subframe holes, the driver side wasn't aligned. I found out you can swivel the stud to angle it into the subframe! This is such a great feature from Perrin. I did have trouble with removing the stock motor mounts from the driver side. I jacked the engine up some more and was able to remove it. The bolt with the spacer was a b*tch to thread in as it was a weird angle doing it blind and on jack stands. Total install time was 2ish hours. Test drive: slight noise, vibration, harshness (NVH) added at idle. I can feel my shifter and seat slightly vibrate at idle. You get used to it really quick. I highly recommend these. Minimal NVH added that doesn't get annoying even if you daily it (I don't). |
The Following User Says Thank You to Top Gun For This Useful Post: | StraightOuttaCanadaEh (10-03-2020) |
10-04-2020, 12:29 AM | #69 | |
Seņor Member
Drives: '17 BRZ PP
10-13-2020, 11:20 PM | #70 | |
I went with the Perrin mounts b/c I needed them ASAP (the car would jerk on decel and when changing gears, it was horrible) and b/c I heard that the STI mounts may not be strong enough for turbo. The STI mounts that I found were all in Japan and pricey. |
Similar Threads | ||||
Reliability concerns after major warranty engine repair? | guanqi89 | Engine, Exhaust, Transmission | 10 | 07-10-2018 09:40 PM |
Wtb frs/brz sti engine mount | bartuc | Want-To-Buy Requests | 0 | 01-05-2018 06:17 PM |
FS: Mtec Shift Springs / Perrin Support Mount / Perrin Shifter Mount | andy86 | Transmission and Driveline | 6 | 05-25-2017 01:26 AM |
Perrin Trans Mount and Perrin Shifter Bushing | 00vsmcoupe | Transmission and Driveline | 1 | 03-09-2016 10:02 AM |
sti engine mounts, oem engine/tranny mount, oem radiator | sickmint79 | Engine, Exhaust, Bolt-Ons | 0 | 08-08-2015 03:15 PM |
