Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
07-15-2020, 06:30 PM | #15 | |
Drives: 2017 toyota 86
I am not talking about changing to a ram system with high pressure air either. Just having access to the fresh cold air coming through the front grille and being able to have that air cool the air in the space previously occupied by bumper bar and foam. And possibly being able to “suck” air from that cold stream but not “ramming it” and not redirecting the high pressure air to come in the grille and then curve up to the filter location or bringing the intake duct end closer to the high pressure air either. Just allowing a direct link between filter and direct cold air while maintaining a low pressure zone. My IAT dropped a good amount switching to my custom setup. Although my reasons for switching and doing this had nothing to do with this was just a pleasant bonus. Wish i had pics when bumper was off. |
07-15-2020, 06:51 PM | #16 |
The Dictater
Drives: '13 Red Scion FRS
Not really. Better than cutting a hole through the bumper, but I wouldn't expect much better performance. Maybe you get a bit more dynamic pressure converted that isn't flowing through the radiator, but you lose some of that to bleeding off the edge and you get more turbulence in the inlet. I honestly haven't actually done a real analysis on this car, but having some experience in airflow (I'm an aeronautical engineer by education), it seems like the inlet was pretty well optimized for the current solution. This MIGHT change if you were to reduce pressure in the engine bay by way of vents and the like. Then you might benefit from a more direct intake snorkel.
The Following User Says Thank You to Spuds For This Useful Post: | norcalpb (07-15-2020) |
07-15-2020, 06:55 PM | #17 | |
The Dictater
07-15-2020, 07:14 PM | #18 | |
Besides not being a fan of oiled filters, I also didn’t like how the perrin filter “sat”. In Perrin’s picture it is fully exposed on all sides but on many other peoples pictures and including mine it always sat on the crash bar and was basically blocked by the bottom and “lip” sticking up so only airflow could go in from behind and up to the top basically limiting service area. Switching to beatrush crash bar and swapping on a 2.75” x 11” coned dry filter it is now truly open all around. I also don’t see how it would create turbulent air removing the foam. Air comes in straight at / into radiator at which point it will diverge into radiator and some will go up and into the holes on the plastic piece. I don’t see what would really cause it to instantly diverge up prior to encountering any resistance or obstacle. The space directly behind the front bumper which is now wide open and has a straight line to the filter should still be a low pressure non turbulent zone just much closer or straighter path to fresh cool air. Not saying it’ll make gains, but possibly maintain HP / less heatsoak type issues. Disclaimer: I also have a sprintex SC may change some factors regarding all of this and the benefits etc... |
07-15-2020, 08:04 PM | #19 | |
Drives: '24 GR86
The Following User Says Thank You to TylerLieberman For This Useful Post: | Spuds (07-15-2020) |
07-15-2020, 08:10 PM | #20 | |
Also a chance this new skinnier longer filter may be able to slide in with only undoing the top bolts/clips. |
07-15-2020, 08:18 PM | #21 | |
Drives: '24 GR86
On a slightly related note, I had a Grimmspeed intake on my 13 FRS and had no issues. The data logging showed everything checked out well with regards to the MAF scaling after install. Had a slightly louder and more pleasant induction note. No real noticed change in power. MAYBE pulled a slight touch more in the very top end before dying off, but after a couple pulls, I couldn’t really tell a difference. I honestly just hate looking at the OEM unit in the engine bay. Between the piping, the snorkel, and the sound tube, it’s all just a giant eyesore to me. I wonder of the 2013-2016 intake tubes work for the 17+. The HKS Carbon one is nice. Pricey and useless, but I almost don’t even care Hahahaha
The Following User Says Thank You to TylerLieberman For This Useful Post: | norcalpb (07-15-2020) |
07-15-2020, 08:36 PM | #22 | |
07-15-2020, 09:38 PM | #23 |
Drives: '24 GR86
Lucky you. The corner lights alone have proven to give tons of people issues after removing and re installing the bumper a few times.
07-15-2020, 09:44 PM | #24 | |
The Dictater
Anyway, the rate of airflow near the intake pickup is quite low, so the directness of flow actually has very little effect. The vents in the air dam probably allow plenty of flow for the engine in any NA application. FI, you might start seeing that as a restriction. The benefit of a Perrin-like setup is that the air spends less time inside the hot engine bay, and the filter absorbs less heat. Plus, aluminum is a pretty good insulator from heat. |
07-15-2020, 09:44 PM | #25 | |
Lol, after 6x it was slightly worse than the picture shows. Still not really bad or anywhere near some pics I’ve seen of other bumpers. But while doing the 7th removal i replaced the headlight bracket and side bracket and put 3 of the tab supports on each side. Got it back to near factory. And just swapped the filter, so I’m done removing bumper for a long while. |
12-04-2020, 07:28 AM | #26 |
Drives: Black 2020 BRZ
does greddy fit 2020 brz?
12-10-2020, 01:22 PM | #28 |
Drives: Scion FR-S 10 Series
Similar Threads | ||||
Grimmspeed Intake / HKS Intake Duct / JDL Catted UEL / HKS Hi Power V2 Cat Back | ANUSTART | Engine, Exhaust, Bolt-Ons | 9 | 03-01-2020 11:15 PM |
HKS Intake Duct | Akuma13 | Engine, Exhaust, Bolt-Ons | 5 | 01-25-2017 03:22 PM |
FS: HKS Intake Duct | 1Cor10:23 | Canada Classifieds | 0 | 10-27-2015 11:07 AM |
Crawford BPB Nib, perrin intake tube, and hks intake duct | AlexBinJackson | Engine, Exhaust, Bolt-Ons | 6 | 08-04-2015 03:19 AM |
