03-20-2015, 02:26 AM | #15 | |
Drives: PEARL WHITE GT86 TRD
The fuse box is under the hood, in front of the battery. But I don't know which to look for. |
03-20-2015, 02:36 AM | #16 |
Drives: '15 Toyota 86
Oh my.......... it was the one terminal of the battery that wasn't tightened from factory. The one bolt was so loose that a simple rocking of the car/ignition must've made it loose contact. As soon as the positive battery cover was lifted up, she came back to life! It's also an error on my part for not checking or not having the wisdom to have checked. I guess the silver lining is I don't have to deal with the dealership today.
03-20-2015, 02:46 AM | #17 |
And I was still so aggravated by feeling tricked into the sale by my dealer that I haven't exactly responded to his last email about the warranty issue. However, what he basically inferred was the entire warranty (bull$hit I know) and not just the exhaust.
I'll open a separate thread regarding the exhaust warranty issue as I don't want to derail this thread any further. Thank you so much for both of your inputs, even though I feel like a tool for not knowing any better to check the battery myself |
03-20-2015, 03:05 AM | #18 | ||
Drives: .
"Some will follow your footsteps, easier than they will your advice."
03-20-2015, 03:14 AM | #19 |
86 Nut
Drives: 86 Satin 6MT High
the pre delivery process should have highlighted the loose terminal, bad dealer.
03-20-2015, 03:27 AM | #20 | |
It wouldn't really be tricked, per say, but it (the fact that I was under the presumption that the car could be reasonably modded - wheels, exhaust) did play a factor in influencing my decision to purchase. I'll touch base on this in the separate thread. @GeeTee86, bad dealer but unfortunately theres only two options of dealers in Cape Town: foreshore and somerset west. I don't exactly stay near Somerset west |
The Following User Says Thank You to Ryliko For This Useful Post: | Dammod (03-20-2015) |
04-07-2015, 07:35 AM | #21 |
Drives: Hachi-Roku
confirmed working on STD 86,
thanks for the tip!!!! |
The Following 2 Users Say Thank You to Scarl3t For This Useful Post: | Dammod (04-07-2015), FT_86_SM_GP (04-07-2015) |
04-08-2015, 10:16 AM | #23 |
Drives: '13 BRZ Ltd
How does this eliminate the cold (loud) high idle? Do you need to let it crank for a while to eliminate the cold high idle or can you just tap it for a bit and then the next start will be normal idle?
04-09-2015, 01:44 AM | #24 | |
Drives: Hachi-Roku
don't think it's ment to eliminate the high idle upon start. but i may be wrong, anyone have other thoughts on this? |
04-09-2015, 01:51 AM | #25 |
Drives: 2014 Pearl BRZ Limited
The 'high idle' start is based on the temperature of the coolant. This will not affect that.
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully | | Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns | |
04-09-2015, 02:12 AM | #26 | |
Drives: .
I have found that by simply letting it turn over for a few seconds (5?) using the above mentioned method, the car starts with a less "severe" the high idle. Just my personal observation I thought I'd mentioned. You welcome to give it a go to see for yourself. |
04-09-2015, 09:22 AM | #27 |
Drives: '13 BRZ Ltd
Thanks guys. That makes sense. Nonetheless a good tip - maybe not a bad idea after an oil change.
The Following User Says Thank You to Wepeel For This Useful Post: | Dammod (04-09-2015) |
04-09-2015, 09:32 AM | #28 |
Drives: .
Similar Threads | ||||
Random squeak from Heater when cold?? | BRZnut | Issues | Warranty | Recalls / TSB | 0 | 01-18-2015 12:57 PM |
jerky starts | goshem | BRZ First-Gen (2012+) -- General Topics | 14 | 01-19-2014 11:21 PM |
White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
Cold morning starts | coldy | CANADA | 43 | 04-23-2013 02:30 PM |
Issue: Cold starts | jesseps | CANADA | 7 | 11-24-2012 11:26 AM |
