Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
09-06-2022, 12:37 PM | #1 |
Drives: 2018 Subaru BRZ
Check SRS Airbag System Light After Seat Cleaning
If you're like me, and likes to clean the seats at least once a year, or spill a drink on your passenger seat, and have encountered a "Check SRS Airbag System" light, here's the solution.
Absorb as much liquid as you can with a towel, open windows on a hot sunny day, and recirculate hot air inside the car to further prevent humidity issues. Let it dry. Any other humidity issues can be solved by placing a Damprid container inside the car. Problem should go away. Else, disconnect the negative lead on battery, place foot on brake, re-connect lead, try again. If you left the windows down during a rainstorm, or drove your car into the river, you'll have worse problems than worrying about your airbag system. |
The Following 2 Users Say Thank You to spcmafia For This Useful Post: | soundman98 (09-06-2022), x808drifter (09-07-2022) |
Similar Threads | ||||
Subaru BRZ 2018 "Check SRS Airbag System" bypass | Adrhe | BRZ First-Gen (2012+) -- General Topics | 3 | 02-19-2020 06:26 PM |
Temp removal of pass seat (airbag light) | mhiscott | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 08-30-2018 10:39 AM |
BRZ / FRS Seat Swap - No Airbag Light! | JohnPayneFun | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 07-23-2018 02:27 PM |
WTB: Resistor for Aftermarket Seat Airbag Light | KPDoubleX | Canada Classifieds | 9 | 05-01-2016 03:57 PM |
Side Airbag light with aftermarket seat? | Hanakuso | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 04-09-2014 03:20 PM |
