Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
11-27-2021, 02:17 PM | #15 | |
AutoX-10/10ths every run
That catch can is amazing. :P
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
The Following User Says Thank You to whataboutbob For This Useful Post: | Ultramaroon (11-28-2021) |
11-27-2021, 02:52 PM | #16 | |
Drives: 2016 scion frs
i would log cylinder misfires, knock correction, port fueling injection ratio, injector D4S mode. i'll look at the rest of the parameters when i have a look later |
The Following User Says Thank You to jrhudson For This Useful Post: | blsfrs (11-28-2021) |
11-28-2021, 01:09 PM | #17 |
Drives: 2013 frs base
11-28-2021, 04:01 PM | #18 | |
No, the oil accumulator is good, have one myself. It's this that I was commenting on, looks to be a tin can of some sort. Is this in your vacuum loop path? Could be causing problems if it isn't really sealed...
The Following User Says Thank You to whataboutbob For This Useful Post: | blsfrs (11-28-2021) |
11-28-2021, 06:10 PM | #19 |
The Following User Says Thank You to blsfrs For This Useful Post: | whataboutbob (11-28-2021) |
12-04-2021, 05:53 PM | #20 |
I replaced the MAP sensor, drove it across town a couple of time and then pulled a log.
https://datazap.me/u/blsfrs/log-1638657723?log=0&data= I still can't tell one log from another. I have a replacement O2 sensor but will wait and see how the new MAP works out. |
12-23-2021, 10:54 AM | #21 |
I've replaced the upstream 02 sensor, MAP, and MAF. Checked for vacuum leaks with starter fluid and "my" smoke machine. 0219a and 0119f (occasionally 0304) still pop up every few drive cycles. I give up. In Jan, I'm taking it to PTuning.
All right PTuning, it's on! |
01-15-2022, 09:04 PM | #22 |
The saga continues. Took the car to PTuning. On the dyno, power is way down 150-160hp at 3500rpm. Rich afr. #4 shows intermittent misfire. The tuner starts tuning. Everything seemed to be working nicely. Then, my Driveshaft Shop aluminum driveshaft breaks in half. No warning! No NVM. Nothing but bang and clackity clack sound coming from the dyno room. PTuning is going to source a stock drive shaft and finish the tune next week. I'll pick the car up next Friday and we'll see what happens next. Great folks at PTuning though.
