Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
03-29-2023, 01:48 PM | #1 |
Drives: Toyota GT86
Subframe Bushings NVH
So my superpro subframe bushings have arrived. When looking up install videos I saw a few comments saying they are very harsh.
I was a bit surprised by this as they were recommended to me by a friend who is NVH conscious. Oh and it also looks like the install is a real PITA So for the people running subframe bushings how bad are they ? Any install tips ? Thanks Note should be the same as Whiteline Positive Traction kit (KTD922)
2014 GT86 Orange 6 Speed https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
03-29-2023, 03:07 PM | #2 |
Drives: '13 FRS - STX
Alone no big deal. Combine with other stiffer bushings and the effect adds up quick.
The Following 4 Users Say Thank You to strat61caster For This Useful Post: | autoracer86 (03-29-2023), DarkPira7e (03-29-2023), finch1750 (03-30-2023), Ohio Enthusiast (03-29-2023) |
03-29-2023, 03:23 PM | #3 |
Wes
I have the whiteline inserts, not the full bushing replacements, and there was only added harshness over bumps. No noise or vibration
Instagram: @gt86ws
03-29-2023, 05:52 PM | #4 |
Drives: Toyota GT86
That is more or less what I got. Good to know thank you
03-30-2023, 07:29 PM | #5 |
Human
Drives: 2015 BRZ Black
I had only the diff insert bushing, and basically no increase in nvh, but definitely improvement in feel. Once i added in the subframe bushing, it added in a lot of nvh but only a slight increase in feel. At the same time i did the subframe bushings, i did some lift spacers too, so comparison isn't 1:1.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
03-30-2023, 08:43 PM | #6 |
Weight Weenie
Drives: 15 FR-S
I didn't have any NVH when I did the whiteline subframe inserts but when I added the diff bushings it increased. I removed the front diff bushings only and it was fine, for me.
03-30-2023, 08:53 PM | #7 | |
Drives: Toyota GT86
So far I am loving the rear diff bushing inserts. I didn't think it would have such a big impact on my enjoyment level when driving the car. Subframe bushings next then TRD trans and motor mounts
03-30-2023, 09:24 PM | #8 | |
Drives: 2018 BRZ
03-31-2023, 01:17 PM | #9 |
Persona Non Grata
Drives: '15 BRZ (WRB)
A couple of things. First, as others have said, the diff inserts do a lot to reduce drive train lash and "wind up." I have the subframe inserts in my "project" box in the garage, but have not yet persuaded myself they are worth doing.
When I was closer to doing the subframe, I took note of the number of people who have had problems with the subframe bolts cross threading on reinstallation. I looked closely at the installation and concluded that the cross threading problem is caused or at least exacerbated by doing the two ends of the subframe in isolation. When you install the subframe inserts, you support the subframe assembly on a jack. If you snug the jack up, remove the front or rear bolts alone and the lower the jack a bit you can get the inserts in. But because they add thickness to the mount, and the rear of the assy is still bolted to the car they add a small amount of angle to the whole assy. When you try to reinstall the bolts, that added angle will try to cant the bolts slightly. Thus, the cross threading. My advice is to support the assy with the floor jack, loosen (but do not remove) ALL the bolts about half way, lower the jack slightly, remove one set of bolts, install the inserts, then hand thread that set of bolts in 1/2 to 3/4ths of the way. Do the same thing for the remaining inserts, then raise the jack until the mounts are just touching the frame and hand tighten ALL the bolts as much as possible, then raise the jack to fully support the assy against the frame and torque the bolts.
Slow is smooth, and smooth is fast
The Following 6 Users Say Thank You to Capt Spaulding For This Useful Post: | autoracer86 (03-31-2023), BlueWhelan (04-04-2023), NoHaveMSG (04-04-2023), Stonehorsw (04-04-2023), strat61caster (03-31-2023), Wally86 (12-13-2023) |
03-31-2023, 07:42 PM | #10 | |
Drives: Toyota GT86
thanks for sharing yours as well
04-01-2023, 11:39 AM | #11 |
Persona Non Grata
Those bolts have caused more than their share of tears. Glad you’re up to date. Good luck.
The Following User Says Thank You to Capt Spaulding For This Useful Post: | autoracer86 (04-01-2023) |
04-04-2023, 11:39 AM | #12 |
Drives: Crapcan
I cheated and used a forklift
If you are just doing inserts, it's not difficult as Capt outlined. My recommendation is to loosen the subframe down on to stands so that it is even. The stock bushing has a pretty hard metal inner sleeve. I suspect people that are not keeping the subframe even are flattening the threads binding against them.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | autoracer86 (04-04-2023), Spuds (04-04-2023) |
04-04-2023, 12:40 PM | #13 |
The Dictater
Drives: '13 Red Scion FRS
I just did this. As others have said, loosen all the subframe bolts just a bit first. I didn't and got lucky, but the left rear did not go back in easy. I loosened all bolts afterwards and used a rubber mallet to nudge the subframe into alignment. Doing this first would have been better.
Also: "Build Thread" |
The Following 2 Users Say Thank You to Spuds For This Useful Post: | autoracer86 (04-04-2023), NoHaveMSG (04-04-2023) |
04-04-2023, 02:33 PM | #14 |
Drives: Toyota GT86
Thanks all. This is very helpful. I ordered the TRD motor and trans mount today as well. That should be it for mounts on this build I think
Similar Threads | ||||
Subframe Bushings and Alignment (Toe) | gonzo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 07-16-2018 11:06 PM |
FS: SuperPro subframe inserts & LCA inner bushings | xn7485 | Brakes, Suspension, Chassis | 1 | 09-13-2017 03:23 AM |
Whos running PBM subframe bushings? | ft86xtc | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 03-03-2016 12:31 PM |
rear subframe bushings? | Roadcone | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 09-09-2014 09:25 PM |
Whiteline subframe bushings | Proof | Brakes, Suspension, Chassis | 1 | 03-18-2014 12:14 PM |
