07-04-2020, 02:04 AM | #9003 |
Drives: '13 Subaru BRZ Crystal Black Silica
I'd consider the same belt. The belt that comes with the kit max's the tensioner anyways. A -2.5mm diameter, i would assume, would still be reasonable to use the same belt.
IG: setgo.moto
07-04-2020, 12:56 PM | #9004 | |
Sorry I meant I want to replace the belt because it's a used kit, where would I find the belt? |
07-04-2020, 01:00 PM | #9005 | |
2013 Series 10 FRS #553
07-04-2020, 02:59 PM | #9006 | |
Drives: 2017 toyota 86
Alternatively you can get a larger diameter supercharger idler pulley and fit a belt accordingly I posted this one about a year ago on here - Dorman 419-610 It is same bearing width/diameter but it is 76mm diameter instead of 70mm so more belt wrap on SC pulley, and 31mm width instead of 27mm so less chance of belt slipping off but requires about 3mm longer belt with 75mm sc pulley, i used it for a year no issues before switching to below. I posted this one more recently been using about a month now Dorman 419-606 same bearing width/diameter but it is 82.5mm diameter and 30.5mm width so requires about 6.5mm longer belt with 75mm sc pulley. K061015 paired with 72.5mm sc pulley and 76mm idler would be a hair tighter than before approximately 1.75mm tighter K061016 Is 3mm longer paired With 72.5mm sc pulley and 76mm idler pulley it would be a hair looser then before approximately 1.25mm looser Or with the 82.5mm idler would be approximately 2mm tighter K061020 Is 12mm longer paired with the 72.5mm sc pulley and 82.5mm Idler pulley it would be a tad looser then before approximately 7mm looser You want tensioner pulley at about 70-80% of its max Travel/tension so as belt stretches it has plenty of travel to pickup the slack, so you can decide based on current setup if slightly looser or tighter is better, and by how much you can deviate + or - If you ever switch to the 69mm pulley the 82.5mm idler and k061016 should be a perfect pairing almost identical to original tension only about .5mm tighter. Last edited by 86TOYO2k17; 07-04-2020 at 04:19 PM. |
07-11-2020, 05:10 PM | #9007 |
Drives: '14
Does anyone know at what IAT temp does the ECU pull timing? Afaik, the IAT's aren't accurate with this kit and my IAT's are sometimes sporadic. One day, it would go up to as high as 158-165f and other days it would be about 125F.
07-11-2020, 05:14 PM | #9008 | |
If i am moving my IAT at stock location is at or below ambient. If I’m sitting idling it creeps up maybe to 120s if i sit long enough. Once moving it goes back down pretty quickly. |
The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | kev0 (07-11-2020) |
07-11-2020, 05:21 PM | #9009 | |
Drives: '14
07-11-2020, 05:22 PM | #9010 |
You should really think about going back to the stock airbox and Cai.
07-11-2020, 05:35 PM | #9011 | |
Because IAT sensor is in MAF pre blower i don’t think most tuners tune use the IAT sensor for tuning. If you relocated to post blower they could probably safely get a little more out of your setup when IAT temps where really low and detune if it got really high and have it adjust accordingly between instead of a general “blanket” tune. But you’ll probably be in the IAT temps that the “blanket” tune is at already in most conditions regardless so it really wouldn’t be much different. And again with E85 it’s less of a concern. Also I am pretty sure the hotter air pre blower would mean less dense air going into the blower and thus less boost coming out post blower so pre blower IAT temps is already being “adjusted” for naturally because of that. IE at 100 degrees IAT you have say 12psi vs 150 degree IAT 11.5psi so timing and fuel wouldn’t need adjusting to accommodate the added heat if that makes sense. |
07-29-2020, 09:09 AM | #9012 |
Drives: Subaru BRZ 2013 6AT& Honda Odyssey
I run a oil catch for a month. The good news is that There's less oil leaking out.
The bad news is that A code P0108. Check no vacuum leakage. I bought a new map yesterday BOSCH 0261230283...Hope everything goes back to normal...
2013 Subaru BRZ 6AT; Rays 57XTREME STD SPEC 18' 9.5J Wheels; TEIN FLEX Z Coilovers; Brembo OE Gold Front Brake Kit(STI); Sprintex 210 SC;GReddy GT ver.2 Exhaust; CUSCO strut bar F/R...
07-30-2020, 10:22 AM | #9013 |
LOL I think I made a mistake about the MAP sensor mentioned in the CUSCO SC Japanese manual(sprintex in Japan),It is 4pins and bigger. I even bought it without comparing. LOL Now I have a maximum pressure of 0.7bar about 10.15psi, This seems normal. I just cleared my CEL and it hasn't show up right away. Hope everything will be fine.[IMG][/IMG]
07-30-2020, 05:35 PM | #9014 |
Drives: UK GT86
It's not ideal running a wider range sensor. You'll need to adjust the tune to get the MAP correct, but also it make it run worse at WOT. You'll need some custom mapping or move the sensor out of the runners. Best bet is to put an OEM sensor back on.
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | LOJOKO (07-31-2020) |
07-31-2020, 12:03 PM | #9015 | |
I bought a 2.5-bar sensor a few days ago when I found that it was OEM, but I may not need it now. Thanks to 86TOYO2k17, I asked him in Messages. As you said, OEM sensor with the correct MAF&MAP tune may be the best choice.
08-04-2020, 12:36 AM | #9016 |
Drives: Supercharged 2013 Scion FR-S
I just bought my frs a few weeks back and the owner had one of these installed, I will say, it is very fun
The Following User Says Thank You to frostyfrs For This Useful Post: | 86TOYO2k17 (08-26-2020) |
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
