BT, dpfarr
Old 03-15-2022, 10:27 AM   #4453
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Originally Posted by Auto_egr View Post
Ignore my past comment about unmetered air going into the engine, I misread your update since you mentioned it's running rich. If you're getting negative LTFT it's pulling fuel for some reason. Not adding fuel to compensate for unmetered air. A leaky header can cause negative LTFT if it's upstream of the O2 sensor(s).
It is a crack at the Y on the header, so before the 02 sensors. Can you get stalling issues from an exhaust leak it if it bad enough? I have a new header coming this weekend and at this rate, I won't be about to get to the DIY shop 30 min away to install it...
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 03-15-2022, 10:40 AM   #4454
Auto_egr
Drives: 2017 CWP BRZ w/PP
Definitely possible. Any chance you can borrow a jack and jack stands to do the header swap at home?
Auto_egr is offline   Reply With Quote
Old 03-15-2022, 10:52 AM   #4455
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
I will have to try. I already paid a non-refundable $40 deposit to hold the bay
Please let me know of any other ideas. I was running rich before and didn’t have idle issues like this.
Old 03-16-2022, 07:15 PM   #4456
Thanks Mike.
The trim is at idle and with slight throttle. It improves under hard acceleration but my trims do not go positive and they used to under hard acceleration. The trims are the most negative at idle and when in a vacuum (decelerating/engine braking)
The car is running fine except for a slight feeling of power loss during a pull (could be in my head).
My BPV has two bolts which I believe is the upgraded one?
Are you on the stock tune?
BrahmaBull1990 (03-16-2022)
Old 03-16-2022, 07:21 PM   #4457
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Tuned locally on a Dynapack. Never had any issues and the tune has been revised.
Old 03-17-2022, 01:11 AM   #4458
I recommend you ask your tuner what they think the issue might be. They may be best equipped to guide you to what's causing the issue based on logs.
Second, would be to take it to a local trusted shop and have them check for vacuum and exhaust leaks, as well as dirty sensors.
Can you give me a ***COMPLETE*** and exact list of mods on your car when it comes to powertrain?
Old 03-17-2022, 09:59 AM   #4459
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Stock motor (2020 with 13.5k miles), Edelbrock Sc, Fujitsubo EL catless header (cracked weld; new JDL 4-2-1 coming today), Tomei OP, stock front pipe, Corsa catback, Radium PCV catch-can, dynapack tune. It was running super rich -20% LTFT last weekend before this stalling issue on Tuesday.
It does appear I have the “upgraded” BPV on my kit.
Here is a log: https://datazap.me/u/brahmabull/stal...&data=19-28-29
I ran through the cold start and let it idle. All good then when I blip the throttle to 2.5k rpm and the revs fall it drops too low and tries to stall. Did confirm again I have the upgraded BPV
Update: Towing to the shop tomorrow where they are installing the new header and the tuner is looking over the car.
The Following User Says Thank You to BrahmaBull1990 For This Useful Post:
CSG Mike (03-18-2022)
Old 03-17-2022, 05:40 PM   #4460
FrickingReallySlow
Drives: 2015 FR-S
Curious how did you see it's a cracked weld? since you couldn't jack up the car to take off the undertray.
I experienced something like this as well over last summer for a couple of days when it was really hot but the symptom of almost stalling disappeared. (I'm still rich at idle but fine when there's throttle). I added some rubber spacers between the EVAP solenoid and the engine block mounting point since I felt like the new position of it for EBSC was way hotter than its stock position (directly connected to the engine instead of the plastic intake). Not sure if it helps but will see when summer comes.
FrickingReallySlow is offline   Reply With Quote
The Following User Says Thank You to FrickingReallySlow For This Useful Post:
BrahmaBull1990 (03-17-2022)
Old 03-17-2022, 06:03 PM   #4461
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
I had the car in last month for a retune and they noted the weld was split at the Y and it was leaking or about to. A couple weeks later my fuel trims went richer and richer (unsure if the header is the cause).
Unfortunately I bought the header on here and they didn’t tell me the weld was split…I’ve only had it installed for about 2k miles…I texted them and they never replied. $850 flushed
Old 03-17-2022, 08:16 PM   #4462
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Just popped the hose off the actuator and tried blowing in it. I couldn’t blow any air through at all. I’m thinking it’s the POS header.
Old 03-17-2022, 09:46 PM   #4463
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
You should be able to find someone to weld stainless steel relatively cheap. I've had to have my Tomei headers repaired (bought new) and a used Berk front pipe fixed as well. Local guy charged my $20 each. ymmv.
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
Old 03-17-2022, 10:04 PM   #4464
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
That’s a great suggestion but they are in pretty rough shape. The ceramic coating is shot too. FedEx was suppose to deliver the new coated JDL 4-2-1 header today but they delayed the delivery. So I’ll tow it to the shop to look over and hopefully get the header to them by tomorrow afternoon for a Monday install.
Old 03-18-2022, 03:48 PM   #4465
Brewster
Brewster's Avatar
Drives: 13 FRS AT, Edelbrock SC, Tomei EL
I'll be pulling all the injectors to be cleaned soon. The left DI fuel rail and crossover pipe are noted on Toyota's service diagram as not to be reused, but at $390, I'm tempted to.
Your thoughts and experience on this ??
Brewster is offline   Reply With Quote
The Following User Says Thank You to Brewster For This Useful Post:
Old 03-19-2022, 01:28 PM   #4466
tomm.brz
Drives: brz 2017 hksv2
Your tuner is not aware apparently that ZA1JK00C tunes , with any racerom patch available in the last 3 years, is EXTREMELY BUGGED
It's pretty obvious on the logs, like the PI% forced to 100% when off throttle. That's one of the many bugs your tune is full of.
You will never get rid of problems untill you keep using a K00C with racerom patch.
Already the fact your local tuner didn't notice this and let you out of his garage with an extremely bugged rom, says A LOT
K00C cars need to be force-flashed to euro K00G.. or someother newer Usa roms, maybe they are less bugged, but so it is. Good luck
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
B T (03-20-2022), BrahmaBull1990 (03-19-2022)
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 12:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) -- General Topics 0 05-24-2012 10:09 PM
