Old 05-22-2024, 03:01 PM   #337
removedonut
Drives: 2022 Toyota GR86 Premium 6MT
Originally Posted by blsfrs View Post
Since you are using the Fa20 wiring harness, instead of repinning the "first 4" sensors, couldn't you just use the FA20 sensors? Or am I missing something?
- Threads and sensor lengths are different for oil and coolant temp, so we can’t reuse those from the FA20.
- On the 17-20, reusing the FA20 crank position sensor would create the same problem as the 13-16 swap where you’d need to do a custom reluctor and bracket. Which is a lot more work when we’ve already got a perfectly usable hall effect signal coming out of the FA24 that we can utilize with a simple connector change.
- Didn’t bother checking if the FA20 evap purge setup could be transferred over to the FA24. I would also put it in the “not worth it” category.
- We can’t reuse the 13-16 fuel pressure sensor because it’s different threads. On 17-20 we can reuse it though, it’s the simplest option.
removedonut is offline   Reply With Quote
The Following 6 Users Say Thank You to removedonut For This Useful Post:
alphasaur (05-24-2024), bcj (05-23-2024), blsfrs (05-22-2024), T-Steve (05-22-2024), Tatsu333 (05-22-2024), Teseo (05-22-2024)
Old 05-22-2024, 03:41 PM   #338
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I see. So, repinning is much easier that finding adaptors. I guess the timing chain covers too are different for FA20 vs FA24
Old 05-22-2024, 03:58 PM   #339
removedonut
With the way i’m building the harnesses, nobody needs to repin anything (besides the fuel pressure sensor, for 13-16 cars). I am building modular jumper connectors that leave the FA20 harness totally intact and just adapt the existing connectors to the sensors on the FA24. One of the big advantages of doing it this way is, for example, if you decide later after the swap that you want to add a 1st gen evap-based flex fuel kit/boost controller/etc. Rather than needing to repin the FA20 connector back onto the harness, you just unplug my adapter and then you’ve got a gen1 evap connector again.
The Following 9 Users Say Thank You to removedonut For This Useful Post:
alphasaur (05-23-2024), blsfrs (05-22-2024), pope (05-27-2024), RT-BRZ (05-23-2024), Spankopotomous (05-23-2024), T-Steve (05-22-2024), Tatsu333 (05-22-2024), Teseo (05-22-2024), Ultramaroon (05-22-2024)
Old 05-23-2024, 08:10 PM   #340
removedonut
17-20 test car is up and running with my kit. I’ll have a video posted and the kits up for sale sometime next week after I’m back from vacation. Final price is going to be $300 for the 17-20 harness set.
The Following 5 Users Say Thank You to removedonut For This Useful Post:
alphasaur (05-28-2024), blsfrs (05-24-2024), Tatsu333 (05-24-2024), Teseo (05-23-2024), ZC6_STi (05-24-2024)
Old 05-23-2024, 08:29 PM   #341
Teseo
Drives: frs
Much appreciated. Waiting a "curated" kit for 13-16 model year
Old 05-23-2024, 10:11 PM   #342
removedonut
Fingers crossed for no snags on that one. All my stuff is installed on the motor, shop should be dropping it in any minute now.
The Following User Says Thank You to removedonut For This Useful Post:
blsfrs (05-24-2024)
Old 05-24-2024, 12:47 PM   #343
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
For the 17+ cars being plug and play, are we specifically taking about the red top manual cars, or both manual and auto?
Old 05-24-2024, 10:16 PM   #344
removedonut
Bof.
Auto should actually be slightly easier since all FA24s have a vacuum pump setup like the automatic FA20s did, whereas on the MT cars you have to do some brake booster rerouting.
My 2013 test car is an automatic - unless there’s some hidden surprise I didn’t account for that we discover once it’s fired up, should be exactly the same process.
The Following 3 Users Say Thank You to removedonut For This Useful Post:
blsfrs (05-26-2024), RToyo86 (05-26-2024), Teseo (05-26-2024)
Old 05-26-2024, 10:47 AM   #345
blsfrs
blsfrs's Avatar
Bof.
To clarify: All FA24s use a vacuum pump for the brake booster? Auto and manual alike?
I would assume that there is a hose/line that runs from the pump to the booster on all FA24s.
Old 05-26-2024, 12:33 PM   #346
removedonut
Correct. Which means on 6MT 1st gens, you need to acquire the brake booster tubing from an auto.
Old 05-26-2024, 12:50 PM   #347
blsfrs
blsfrs's Avatar
A "complete" salvage 6mt engine should come with line? No?
Old 05-26-2024, 01:10 PM   #348
removedonut
That’s gonna depend pretty heavily on the salvage yard pulling the engine lol. Most are monkeys and would sooner just cut a hard line than put the effort in to disconnect it.
blsfrs (05-26-2024)
Old 05-26-2024, 02:42 PM   #349
blsfrs
blsfrs's Avatar
Here's a diagram of a 22 legacy. I imagine the twins are similar.
Old 06-14-2024, 11:20 AM   #350
blsfrs
blsfrs's Avatar
This guy posted on FB.
https://phillipwilliamsoliveira.subs...wLCJy-TCpmqyMV
Search this Thread:
Advanced Search
FA20 vs FA24 Zata Engine, Exhaust, Transmission 15 06-01-2023 11:18 AM
FA24 In-Depth Look Kona61 GR86 General Topics (2nd Gen 2022+ Toyota 86) 36 10-11-2021 09:27 AM
Second Gen Swap? FA24 AutoNewb Engine Swaps 86 07-06-2021 11:55 AM
FA24 Mix n Match RiceCracker86 Engine, Exhaust, Transmission 1 04-18-2019 04:59 PM
Incoming... MisterSheep Off-Topic Lounge [WARNING: NO POLITICS] 19 04-02-2016 01:33 AM
