07-22-2014, 11:45 AM | #141 | |
Drives: Subaru BRZ with Delicious Innovate
What do you think is possible with that blower and a built motor? How much boost do you think it can hold?
07-22-2014, 12:08 PM | #142 |
Do you have a plot you can share?
It's a big supercharger, I would expect it to be good to 20+ PSI on this motor. Biggest issue would be combating the additional heat generated at high boost. I haven't been real impressed by the integrated IC. |
07-22-2014, 12:37 PM | #143 |
Drives: 2013 Pearl White FRS
Iat were about 140 to 145. I have an aluminum intake manifold that I think needs a heat wrap.
Turbo car is still 12.5 Yes, I meant 3000 rpm. Also I'm on an auto, so the torque converter starts slipping around 7100 I believe. I think we should have left the cr stock. The elevation change lowered boost more than expected. And the bigger heat exchanger and pump seem to have helped a lot with the iat, they were about 190 in Miami |
07-22-2014, 01:39 PM | #144 | |
I think if you are running E85 I would keep the CR stock or maybe 11.5:1 until you get into big turbo numbers. |
07-22-2014, 01:41 PM | #145 |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
I think he meant to say intake. Not intake manifold. Granted the intake manifold is aluminum but it is still the same one from Sprintex that they provide with this kit. At least that's what it looks like from the pic in his build thread.
07-22-2014, 01:43 PM | #146 |
Thanks, I hadn't looked at his build thread.
07-26-2014, 12:48 AM | #147 |
Trying to order smaller pulley... Probably be 3 weeks minimum before I can get around to getting this done and back onto a dyno...
07-30-2014, 11:27 AM | #148 | |
Drives: 08 STI|15 BRZ|95 L Coupe
08-04-2014, 02:17 PM | #149 | |
Drives: FR-S 10 #103 AT
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
08-11-2014, 08:04 PM | #150 |
Mad Sciontist
Drives: gt86
I got my 335 upgrade
Sent from my SM-N9005 using Tapatalk
08-11-2014, 08:16 PM | #151 |
Twin Screw You
Nice. I'm hoping they send some units over to the states some time soon. Sprintex USA still doesn't have an ETA on them.
08-12-2014, 12:18 AM | #152 |
08-12-2014, 12:23 AM | #153 |
Twin Screw You
I called and asked. The guy I spoke with said the intake casting that bolts to the back of the blower is different. I could try to have something made but don't know how feasible it would be.
08-12-2014, 12:27 AM | #154 |
I've never seen a 210 but i the reason they decided to try the 335 is it fit.
Similar Threads | ||||
Abbey Motorsport Sprintex SC updated Dyno plots | Mark@Abbey m/s | Forced Induction | 49 | 02-15-2017 11:13 PM |
Khorne's - AUDM Red 86 GTS Sprintex | Khorne | Member's Car Journals | 53 | 08-31-2014 09:44 AM |
Sprintex or Vortech, which setup has more potential? | Turbowned | Forced Induction | 328 | 09-14-2013 11:09 AM |
Abbey Motorpsort GT86 Sprintex installation | Mark@Abbey m/s | Forced Induction | 18 | 09-07-2013 04:11 AM |
Sprintex Supercharger Sneak Peak!!! | invisage | Forced Induction | 52 | 03-03-2013 06:11 AM |
