GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
08-01-2022, 05:17 AM | #29 |
Drives: Mini
So initially before I got my BRZ, I was reading people's thoughts about it and figured it was no big deal. I had a Mini Cooper S with the same style turn signal which I actually liked a lot.
Fast forward to finally owning my twin and I'm very annoyed with this turn signal. With my MCS, if I fully engage the turn signal but want to cancel it, I just move the stalk half way in any direction and it's instantly canceled. I liked it because it was easy and there was a subtle but noticeable detent before fully engaging. With my BRZ, I've begun to hate how it only cancels if I engage the stalk halfway in the opposite direction and it feels like the half way point is so light that at times I've accidentally signaled the other way instead. So yeah, I'd be more than happy to try this. Hope I'm able to find a cheap one on ebay as well, would be even better. Thanks for sharing!! |
08-01-2022, 03:44 PM | #30 | |
Drives: '23 BRZ Limited
Slight touch, 3 blinks for lane change. Push it past the detent, stays on until the wheel is turned or you push it back past the detent to cancel it. The same as our '18 Mazda 3.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
08-02-2022, 09:36 AM | #31 | |
The guy w/o an FRS or BRZ
Drives: '23 GR86 Premium 6MT Halo White
Don't waste time in our forums like this. People are here to learn, all you're doing is adding zero value by not watching and sending the OP's thread down a rabbit hole for no reason. |
The Following User Says Thank You to ROFL it's Waffle For This Useful Post: | CincyJohn (08-02-2022) |
08-02-2022, 10:11 AM | #32 | |
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
Kind of like the shifter buttons or electronic shifter replacing a manual shift lever....with the purpose of "opening up" some space in the center console.....(which it usually doesn't actually do because the buttons are laid out in such a weird way they take up all the shifter space anyways....) |
08-08-2022, 03:29 PM | #33 | |
Drives: 2023 GR86 Base MT
08-08-2022, 03:37 PM | #34 |
Drives: 2022 GR86
Did you need to quote the whole thing just to reply 2.5 lines?
Follow the build thread for my GR86!
08-09-2022, 03:43 PM | #35 |
Did you need to yell at him without quoting so he may never know you said anything?
The Following User Says Thank You to Tcoat For This Useful Post: | Spektyr (08-09-2022) |
08-10-2022, 01:20 AM | #36 |
Drives: 2022 GR86
Don't know if it works the same way for others, but once I post on a thread, I start getting emails about all future posts until I manually unsubscribe.
The Following User Says Thank You to timurrrr For This Useful Post: | Tcoat (08-10-2022) |
08-10-2022, 05:49 AM | #37 |
OH GOD that would suck!
08-10-2022, 11:28 AM | #38 |
Drives: GR86
08-10-2022, 11:39 AM | #39 |
Do they have to reply to the email about how they replied to the post that sent the email that caused them to reply to the post?
08-10-2022, 12:23 PM | #40 | |
Pavement Grey
They can reply to the email about how they replied to the post that sent the email that caused them to reply to the post, or they can choose not to reply to the email about how they replied to the post that sent the email that caused them to reply to the post. But if we can always go deeper....... |
The Following User Says Thank You to Sasquachulator For This Useful Post: | Tcoat (08-10-2022) |
08-10-2022, 12:37 PM | #41 | |
08-11-2022, 01:47 AM | #42 |
Drives: 2022 GR86
And then quote the whole thing.
The Following User Says Thank You to timurrrr For This Useful Post: | Tcoat (08-11-2022) |
Similar Threads | ||||
LED DRL and turn signals | Sasquachulator | Other Vehicles & General Automotive Discussions | 4 | 10-25-2021 11:27 PM |
How to take apart frs Turn Signals? | Hentai | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 10-12-2016 12:49 PM |
Turn signals don't always automatically turn off | one2onejackpot | Issues | Warranty | Recalls / TSB | 6 | 04-18-2016 07:35 AM |
Turn as tail timing not matching with the front turn signals | NahumCC | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 01-03-2016 10:40 PM |
Need help with LED turn signals. | Khalis | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 08-11-2012 11:23 PM |
