07-29-2020, 09:49 PM | #239 | |
Drives: 2013 FRS
Sent from my SM-G960U using Tapatalk
WIFE: "How can there be anything left to buy?"
07-29-2020, 10:04 PM | #240 | |
I am thinking it could be time for a checkup on the fronts, not sure how that works. I have hotchkis bars both set on full soft. I suppose I would put the front 1 hole stiffer prior to next event. I sometimes feel that the car pushes, but, I also think that could be a bit of over driving/steering input. I took out some compression on the rear mid event last event, didn't seem to notice much, but others mentioned the same complaints in our second heat of no grip. Last edited by ka-t_240; 07-29-2020 at 10:16 PM. |
07-30-2020, 12:43 AM | #241 |
Drives: 2017 BRZ series.yellow
So far the setup is working really well for me. Car handles amazing. It's been the fastest thing not on slicks at my last couple local events. Managed 4th place in STX at my first Pro Solo in Packwood.
Couldn't have asked for an easier car to drive at the limit. |
The Following User Says Thank You to Breezio For This Useful Post: | Racecomp Engineering (07-30-2020) |
07-30-2020, 08:07 AM | #242 |
Congrats on the finish!
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post: | Breezio (07-30-2020) |
07-30-2020, 10:01 AM | #243 | |
Also check ball joints and tie rods for play. Double check your rear alignment (I hate the toe adjusters). - Andrew |
07-30-2020, 10:02 AM | #244 | |
Drives: 2017 BRZ w/PP
honestly i saw that i was like 1/2 a second off your time and was trying to beat that but threw it away at the hairpin and tried to make up for it. my wheels are supposed to be here on the 3rd, since tomei said the replacements are on backorder until november i just ordered a new exhaust that will get here the 8th, and will be aligned friday. i already replaced my LCA so i should be good go to saturday |
07-30-2020, 12:36 PM | #245 | |
My weekend plan is to try and figure out how to test the ball joints and tie rods. I am ordering new FLCA bushings today. Going w/ superpro. Alignment to follow |
The Following User Says Thank You to ka-t_240 For This Useful Post: | Racecomp Engineering (07-30-2020) |
07-30-2020, 01:08 PM | #246 | |
Purist
Drives: 2013 FRS - Hot Lava
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
07-30-2020, 02:22 PM | #247 | |
Drives: Many
I couldn't put together a good right side run Congrats on 4th! |
07-30-2020, 08:23 PM | #248 | |
I think getting the second fastest run on the right side says you did great over there! I was behind on the left side, a good second off pace. Congrats on getting second place! You and Glen put down awesome times. |
07-31-2020, 01:23 AM | #249 |
Drives: Many
Yeah, 1st loser lol
But thanks. I was happy enough with my left side run but got into my own head with red lights and cones on Saturday. I just switched to the 5k/9k setup which is a little loose off the corner with low-grip packwood. Needed an event or two more of practice before Tour/Pro. |
07-31-2020, 03:14 PM | #250 |
08-01-2020, 11:29 AM | #251 | |
What are your front/rear sway bars? I'm on 400 lbs/in front and rear Hotchkis 1" bar on soft in front, oem PP (16mm) bar in rear. |
08-01-2020, 01:37 PM | #252 | |
Drives: '13 FRS - STX
https://www.ft86club.com/forums/show...88#post2844088 e1 griego and m0nk3y are both on that path iirc Early successful cars were about 400/400 and that's what the Racecomp/KW T2's come with and I believe that's where the Proparts/Wong/Heitkoter setup is currently. |
The Following User Says Thank You to strat61caster For This Useful Post: | Breezio (08-03-2020) |
Similar Threads | ||||
SSC setup thread | conehead | Tracking / Autocross / HPDE / Drifting | 26 | 06-06-2023 02:21 PM |
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
STX setup sharing thread (2019) | CoolHandMoss | Tracking / Autocross / HPDE / Drifting | 110 | 02-17-2020 11:27 AM |
STX Set-Up Sharing & Results Thread | race2win | Tracking / Autocross / HPDE / Drifting | 76 | 02-16-2017 11:30 AM |
Official Roll Cage/Bar Thread **Show off your setup!** | slava | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 01-02-2015 10:05 PM |
