Engine Swaps Discussion of engine swaps. |
07-01-2016, 09:28 PM | #43 |
Toyotas don't have boxers
Drives: GTV86, ISF, TE27
Finally got certification (required to drive on road in NZ). Which was a drawn out process.
Failed on noise and emissions (as well as other things) but got it there eventually. Had to add cats and another muffler. Has toned down the sound quite a bit. Sort of in two minds whether I like it or not. Don't really have a lot of choice, has to be what it is. [ame="https://www.youtube.com/watch?v=_BVWxw3yVn4"]V8 Toyota GT86 - New exhaust note - GT86 + 1UZFE - YouTube[/ame] [ame="https://www.youtube.com/watch?v=ZnT0iHe_Pt4"]V8 Toyota GT86 - New exhaust note (in car) - GT86 + 1UZFE - YouTube[/ame] Another thing I fixed is the oil surging. Last drift day if I chucked it too hard it would surge. I had a oil pressure sensor which would cut power and save the motor, but it was still frustrating. With the new sump it seems to have solved the issue. [ame="https://www.youtube.com/watch?v=myZmiTqhnIQ"]GTV86 - Gated / baffled sump 1UZFE - YouTube[/ame]
The Following 4 Users Say Thank You to Manji For This Useful Post: |
07-15-2016, 06:37 PM | #44 |
Drives: '14 981CS, '99 NB1
I think it sounds amazing like that.
The Following User Says Thank You to johan For This Useful Post: | Manji (09-30-2016) |
07-19-2016, 10:02 AM | #45 |
Drives: 2018 Golf R
^ Same here. I love it.
Parting out HERE
The Following User Says Thank You to civicdrivr For This Useful Post: | Manji (09-30-2016) |
09-23-2016, 04:18 AM | #46 |
Have been tracking car for past few months, and power has gotten old. So have ordered a new built 1uz.
Ordered from Hartley Engines in NZ. Their top spec 1uz setup delivers 480 to 490hp (on an engine dyno) at 7800rpm, with a 8400rpm red line, which is what I've ordered. This video is of a similar motor on their dyno, but with a carb and 10:1 compression. I'll be running injection and 11:1 [ame="https://www.youtube.com/watch?v=rp7uSaNExYU&f"]Lexus 1uz-fe Hartley Engines NZ - YouTube[/ame]
09-23-2016, 07:44 AM | #47 |
Wow, that's awesome. What sort of cost is a built 1UZ?
09-30-2016, 07:09 AM | #49 |
Decided to step up to a sequential box. Should do a good job of keeping the new motor on song.
The Following 2 Users Say Thank You to Manji For This Useful Post: | civicdrivr (10-03-2016), Dpk3 (10-03-2016) |
10-07-2016, 07:19 PM | #50 |
Drives: 02 s2k, 08 350z, 08 Fit sport
Are you considering a higher final drive. It looks like you'll never need to go past 3rd gear when WOT for the 5 speed and 2nd gear for the sequential box. I understand most of the time is spent part throttle, but it seems these ratios (with your final drive) are fairly tall.
edit: D'oh. Didn't see km/h. Last edited by tirespin782; 11-25-2016 at 08:13 PM. |
11-01-2016, 12:26 AM | #51 |
Drives: 2012 Honda Civic
Hi!
Hello sir.... So I really wanted a v8 swap gt86 for a while and I came across your build. I bought a slight front end damaged gt86 with no engine in it and about to purchase a vvti 1uz. I was wondering if you would be willing to help me out with with some planning and more info on what you did for your swap. I want so badly to follow in your footsteps!
09-14-2018, 01:45 AM | #52 |
[ame]http://youtu.be/rpFvwDike-I[/ame]
[ame]http://youtu.be/04RwcLTJy4g[/ame]
The Following User Says Thank You to Manji For This Useful Post: | Iceman (09-14-2018) |
09-14-2018, 01:59 AM | #53 |
Car has been almost fully rebuilt over past 12 months.
Decided to dry sump motor. Meant it could be mounted better, lower and further back. Twin plate clutch, new cooling system, ducting and vents, new fuel system, bigger brakes, new suspension bits, more tyre; all to cope with more power. New intake manifold is glorious compared to the OEM one. Has cage and seat now; though most the interior is still there. Is still 100% street legal. Power is up almost 50% now. Makes peak power at redline (8500). Could maybe push to 9000 but not just yet.
The Following 6 Users Say Thank You to Manji For This Useful Post: | Aphaux (04-03-2019), CxG (11-19-2018), DIY (09-15-2018), Kenny_LongWrench (09-15-2018), tirespin782 (09-22-2018), Zer0 (04-04-2019) |
04-03-2019, 02:33 PM | #54 |
Drives: Silver 2013 BRZ
Hi,
I am in the midst of a very similar build and will and have been referencing the work done on your car sir Manji. I am very thankful that there is even some support and history of this build. I am still a long way from the goal in terms of work, but I am driven and my 13' BRZ has no engine so double that. I am installing a 1992 1UZ-FE pre-vvti from a Lexus SC400. Thank you, wish me luck! -A |
04-03-2019, 02:51 PM | #55 | |
Drives: 16' BRZ
On the upside there is no way in 1000 years you could get approval to drive a MoTeC car in Califorina, so big kudos to you my friend and enjoy those twisty roads your build is epic! |
04-04-2019, 12:28 AM | #56 | |
Drives: 2015 frs
Similar Threads | ||||
Aerocatch hood pins, anyone got pics and comments? | K-NoMs | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 08-28-2014 12:51 PM |
Custom Cat-less Exhaust (Pics & Vids) | Ch3cho86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 15 | 03-08-2013 01:44 AM |
2JZ GT86 first Drag test, 11.1@220km/hr (vids) | Bahraini86 | Tracking / Autocross / HPDE / Drifting | 4 | 02-07-2013 09:12 AM |
Norcal: Alice Meet Official Pics and Vids Thread | 86_ZN6 | Southern California | 21 | 08-01-2012 11:34 PM |
Yokohama Ride & Drive with Scion FR-S ( pics & NOW VIDS ) | gatorfan462 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 8 | 05-17-2012 04:30 PM |
