Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
10-29-2011, 07:38 PM | #1 | ||||
Drives: Bugatti Veyron
Susupension Thread
From the Car & Driver article:
BRZ Prologue ii Last edited by quik1987; 10-30-2011 at 06:39 PM. |
11-01-2011, 11:12 PM | #2 |
Drives: '09 335, '85 535, '95 Yota Pickup..
Im pretty sure most of the aftermarket companies will jump on this. Tanabe and Tein would be dumb not to take advantage of this.
11-02-2011, 08:55 AM | #3 | |
Rocket Surgeon
Drives: PSM GGA OMG
11-02-2011, 10:58 AM | #4 | |
Site Moderator
Drives: Stuff
Most likely they were testing both and no one knows what it will actually come with yet.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
11-02-2011, 01:58 PM | #5 |
Hello,
We are already thinking about shocks, coilovers, springs, swaybars, bushings, brake ducts, etc. for this car. We've got lots of experience with the Subaru Impreza platform, though this is a different ballgame. Also plenty of experience with Mitsubishi EVO, Porsche, and BMW. We've got good relationships with Ohlins, Bilstein, AST, KW, Whiteline, JRZ, and also design a few of our own parts. Can't wait to bring high quality parts to this car. If the standard shocks are made by Showa, that's a pretty good thing. The 2008+ STI switched to Showa from KYB and there was a nice improvement in valving quality to go with it. From the sound of it they've paid more attention to valving than usual. Not as good as Bilsteins but a big step up from the usual OEM japanese stuff. Plenty left on the table for a good well designed spring to upgrade to (if done correctly). We'll have them dyno tested as soon as it's possible. This spring is going to be great! At least 2 of us in the office really want this car. EDIT: Sachs isn't bad either....they make a wide range of stuff though. Some very very high end stuff and some simple OEM type replacements. I feel pretty confident the standard shocks will be impressive for an OEM (though maybe not Koni Yellow or Bilstein Sport good). - Andrew |
11-02-2011, 02:30 PM | #6 |
Site Moderator
Drives: Stuff
Do you guys do any custom valving or anything like that? Examples of what you've done?
I've love to see a dyno of the stock dampers and have someone determine the spring rates. I'd gladly send a set in to you for testing but I likely won't be one of the first to buy the car (I have zero intention of paying MSRP, let alone above that..).
-Dave
11-02-2011, 02:47 PM | #7 |
We do not do custom valving in-house, but we work closely with Bilstein for a custom valved "Sport" shock with matched springs for the current Impreza WRX and STI. Also have a custom KW coilover set for the same cars. So that kind of stuff is done by working with those companies (designed here with their help, made in Germany to our specs, revalved and serviced by them stateside). Shock dyno is coming and at that point we would be able to do anything. We used to share shop space with another shop and have been procrastinating getting our own dyno for the new place.
We're pretty function oriented....one of our "lowering" spring sets for the Impreza STI lowers the car just 5mm....and comes with shortened bumpstops. So you end up with more bump travel than stock. More travel + a nice healthy increase in spring rate works very nicely, and our core customers are really into it. The hellaflush scene...not as much. But that's okay, different strokes. - Andrew |
11-02-2011, 03:15 PM | #8 |
Site Moderator
Drives: Stuff
Function > Form for me man Get that shock dyno!
I love Bilsteins but for custom apps normally run custom Konis just because it's so easy to find. I'd rock a set of custom valved bilsteins with threaded sleeves and custom rate springs for sure Unless I wanted to dump too much money into the suspension.. I'm trying to avoid that route :P KW Var 3's are one of the better off the shelf setups I've messed with. What did you guys do custom with those? Increased rate? Road race car? or Rally? or? Sorry for the questions, just curious.
-Dave
11-02-2011, 03:18 PM | #9 |
2 wheel member
Drives: JZA80, 997.1, Taco
Welcome Andrew. Do you have any feedback regarding Ohlins? I know they are increasing their suspension in the automotive market but any rough comparison between Bilsteins and the Ohlins that you are familar with?
11-02-2011, 03:21 PM | #10 | |
We'll do a lot of testing and measuring and all that good stuff once we get the girl-i mean car. - Andrew |
11-02-2011, 03:22 PM | #11 |
Site Moderator
Drives: Stuff
Ohlins, Motons, Penske, etc are all great products. Everything I've used/been in from any of them has been custom designed though.
Some of the JDM tuners (not the parts dumpers, the guys who actually race) use custom Showa dampers too, which are outstanding as well. In the ITR world Penske and Showa's are generally regarded above the rest. I'm likely not a good enough driver to take advantage of anything quite that well setup though :P
-Dave
11-02-2011, 03:26 PM | #12 | |
Bilstein is close in terms of capability, but off the shelf can leave something to be desired on the performance end (which is why we prefer custom valved when possible). Ohlins just nails the valving all around and the adjustability is more consistent, but they are a bit more expensive. Both great shocks. - Andrew |
11-02-2011, 03:29 PM | #13 |
Site Moderator
Drives: Stuff
It'll be interested to see if we have any shock travel issues with this car.. I won't be affected but the guys that want to do 2"+ drops might hate it..
-Dave
11-02-2011, 03:32 PM | #14 | |
- Andrew |
Similar Threads | ||||
D-4S Thread | WingsofWar | Engine, Exhaust, Transmission | 85 | 03-31-2020 04:25 PM |
AZ bs thread | sfwg | Southwest | 185 | 09-11-2012 03:11 AM |
Intoxicated thread | #87 | Off-Topic Lounge [WARNING: NO POLITICS] | 46 | 04-27-2012 07:17 PM |
The Diet Thread | Maxim | Scion FR-S / Toyota 86 GT86 General Forum | 126 | 06-14-2011 05:47 AM |
The Music Thread | aliphian | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 03-28-2011 11:35 AM |
