Old 04-08-2021, 12:27 PM   #15
slickd
slickd's Avatar
Drives: 2013 silver toyota 86 (high) man.
Originally Posted by Mr_Eyo View Post
Not all LED replacements are appropriate for our cars because of the way they're wired up. They're connected to the ECU and there is a non zero voltage applied to the dome light hi side even when the doors are closed. This voltage may be enough to forward bias and "light" certain LEDs. I had to test multiple LED replacements to ensure they would stay off when the doors are closed before I found one that fits the bill.
Thanks for that feedback, sadly i think me having incorrectly fitted the LED or having chose the wrong LED may have led to the slight bigger problem after the burning smell. Ive been unable to follow the wiring further than the side airbag area by the a-pillar. Would you maybe be able to give me a guide as to where i could check for obvious faults (e.g damaged/melted wire) or maybe what i need to consider replacing. Ive tried replacing with standard bulbs, but unlike the LED's in 'door' position which just light up dimmer than in the 'on' position, the standard bulbs dont switch on at all when in 'door' position. Ive checked the housing of the dome light, no damage or irregularity there. Also, could you maybe advise which leds you found that correctly suit the gt86
slickd is offline   Reply With Quote
Old 04-11-2021, 04:22 PM   #16
Mr_Eyo
Drives: 2017 Toyota 86
Sorry, can't really help you here. Reversing LEDs shouldn't cause any harm. The only thing I can think of is if you removed the dome light module from the headliner, you may have damaged the selector for on/off/door.
Mr_Eyo is offline   Reply With Quote
Old 04-11-2021, 05:03 PM   #17
slickd
slickd's Avatar
Thanks for the advice and feedback, much appreciated
#1 The Best Interior LED Light Kit for your FR-S! Precisionleds Interior Parts (Incl. Lighting) 59 07-30-2013 02:23 PM
Auto-Hauss Dual Trunk Light Introuctory Price! Light Up The Rest Of Your Trunk! Auto-Hauss Interior Parts (Incl. Lighting) 10 03-11-2013 10:55 PM
Interior Light Swap? soontobrz Cosmetic Modification (Interior/Exterior/Lighting) 4 01-13-2013 02:08 PM
Interior Red Light Nitesh31 Cosmetic Modification (Interior/Exterior/Lighting) 18 10-05-2012 10:20 AM
Interior Brake Light Lefty Scion FR-S / Toyota 86 GT86 General Forum 14 09-05-2012 03:38 AM
