Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
07-10-2018, 02:53 PM | #1 |
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Replace blue stuff now?
My '14 Monogram had 29K on it when I bought it three months ago. I have no service records, so I'm about to change out tranny and diff fluids. I changed oil to Mobil-1 5W30 and installed a Fumito drain plug. I think I saw in the manual that the coolant is good for five years, but it seems prudent to me to flush and change now. I see now there's red stuff that is supposed to be better than blue stuff. Anyone know anything about that?
07-10-2018, 03:03 PM | #2 |
I should add that I went to a Toyota dealer and asked to see the coolant bottle. It said clearly on the back "For all Toyota engines EXCEPT, Scion FRS."
So much for what some dealers know. They also wanted $35 for a cabin air filter that I got at O'Reilly for $15. |
07-10-2018, 03:18 PM | #3 |
Drives: 2015 FR-S
Pretty sure the Monograms run a special coolant so be careful.
The Following User Says Thank You to Impureclient For This Useful Post: | MJones_RB (08-08-2018) |
07-10-2018, 03:25 PM | #4 | |
Yep, if you change it, I'd suggest you use the recommended blue stuff. humfrz |
07-10-2018, 03:26 PM | #5 |
07-10-2018, 03:48 PM | #7 |
The local Subaru dealer knew right away what to use. He mentioned it's good for 100,000 miles, but agreed you never know what the PO might have put in there. Mine doesn't seem to use coolant, even in hot Florida. Takes a little less than 2 gallons at $25 a gallon. Blue stuff for regular FRS's and violet for Monograms.
07-10-2018, 04:11 PM | #8 | |
Drives: 2014 BRZ Limited
It shouldn't. Even open cooling systems are not supposed to allow coolant to evaporate. Apparently it's "normal" for some coolant to disappear during the engine break-in period (and both of my engines have done it), but I put that in quotes because "normal" is not always normal with this car. After break-in, it's not supposed to use coolant, and unexplained coolant loss would be a red flag for either a leak or a blown head gasket. |
08-07-2018, 02:33 PM | #9 |
Drives: 2016 Subaru BRZ
Pentosin Pentofrost A3 is the same thing and it's cheaper than the Subaru Blue, you can also buy Pentosin at Advanced Autoparts which is probably closer than a Subaru dealer.
08-07-2018, 02:37 PM | #10 | |
Country Boy 4 Life
My dealership wanted $39.99 for the cabin filter!!!! I ordered one off of ebay for $8.50 shipped.
I LIKE TIRES! |
The Following User Says Thank You to Leonardo For This Useful Post: | ToySub1946 (08-07-2018) |
08-07-2018, 02:46 PM | #11 |
The Fail Boat
Drives: CWP S.B.
Just remember to check coolant lvs once in a while, this engine runs hot & some of the coolant escape from radiator cap once you have some fun time with the car.
*which doesn't seem to happen after I got a oil cooler... O.o |
08-07-2018, 03:24 PM | #12 |
Drives: 15FRS, 05MustangGT, 85Toyota truck
I'm tired of all this anal bullshit.
Warranty and Maintenance guide: Engine oil: Change every 7500 miles, change filter as well. Use a full synthetic 0W-20 oil. change engine coolant at 137,500 miles or 11 years (whichever comes first). Specified coolant: Toyota Super Long-Life Coolant {SLLC} BLUE. Manual transmission oil. Inspect every 22,500 miles. Implied: Change never. Automatic Transmission oil: Inspect every 15, 000 miles. Change every 60,000 miles. Rear Differential oil. Inspect every 7500 miles. Implied: Change never. I'm a former auto tech. The above is exactly how I I'm going to treat my car. If it does not like it, too bad. Last edited by ToySub1946; 08-07-2018 at 03:42 PM. |
The Following User Says Thank You to ToySub1946 For This Useful Post: | humfrz (08-07-2018) |
08-07-2018, 04:24 PM | #13 |
08-07-2018, 04:28 PM | #14 | |
I agree 100% (for non heavily tracked cars). And I'm a retired agronomist - humfrz |
Similar Threads | ||||
Have to replace entire assembly to replace fuel filter? | tobkin | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 08-04-2017 02:26 PM |
EBC yellow stuff/red stuff | R3AP3R_Playz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 09-13-2016 05:37 PM |
To replace rims or not replace? | unlimited86 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 23 | 09-21-2015 12:12 PM |
CruiseControl's Ultramarine FR-S - Perrin Tips, Shark Fin, JDM Stuff, Other Stuff | CruiseControl | Member's Car Journals | 4 | 07-01-2014 05:53 PM |
