Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-17-2014, 03:24 AM | #29 |
Drives: 2013 MT Asphalt FRS
I LOVE these bad boys!
I installed mine today, I took my headers off. I have two questions. 1. Did I have to put the black metal plate from stock mounts onto the new mounts? I tried at first but it kept sliding off, so I just took it off. 2. Whats the deal with the two bolts on each mount? Had no idea how much to torque, so I tighten them until I passed two threads |
09-17-2014, 04:56 AM | #30 |
Drives: Toyota GT 86
Yep. Just to confirm: it requires unbolting the header and lifting the engine quite a lot. No other way of doing it
The Following User Says Thank You to Efferalgan For This Useful Post: | Sportsguy83 (09-17-2014) |
09-17-2014, 07:23 AM | #31 | |
I Love custom Turbo kits
Drives: Limited BRZ
The bolts on the mounts are adapters to fit what are WRX/STI motor mounts originally to our car. I didn't use a torque wrench either.
09-17-2014, 12:41 PM | #32 | |
What's worst case scenario not putting the plates back on? |
09-17-2014, 02:01 PM | #33 |
Drives: Limited BRZ
The plates are heat shields to the mounts.
09-17-2014, 03:32 PM | #34 | |
Drives: Strangely.
I bought a set, I think I'll put em in when doing my header, judging by all these horror stories! What is the stock durometer anyhow? |
09-17-2014, 07:08 PM | #35 | |
09-17-2014, 07:09 PM | #36 |
09-17-2014, 07:29 PM | #37 |
Drives: Limited BRZ
I didn't mount the plates because I have Perrin mounts, not Cusco mounts. Perrin mounts are a weird shape and the plates do not fit.
The Following User Says Thank You to Sportsguy83 For This Useful Post: | Carlitoz3 (09-17-2014) |
09-17-2014, 09:39 PM | #38 |
The Cusco mounts don't use them either they are constructed completely different than the stock mounts. I swapped the Cusco for the STi mounts, too much NVH.
09-21-2014, 11:53 PM | #39 |
Drives: None
09-21-2014, 11:55 PM | #40 |
Drives: None
PSA: Replacing Engine Mounts can be a BITCH and much more!
Btw, I'm glad to here your cars been doing good
Sent from my iPad using Tapatalk |
09-22-2014, 12:20 AM | #41 | |
Drives: Limited BRZ
Sent from my SAMSUNG-SM-N900A using Tapatalk
10-12-2014, 04:30 AM | #42 |
Drives: Strangely.
Just replaced my motor mounts. It's not that bad, guys.
For tight bolts: use a longer ratchet. And I was able to get the driver's side mount out with the manifold still on. The trick is, you remove the lower manifold heat shield and then fold the offending flange out of the way. Bend it back to stock and reassemble, zero rattle due to the pretty fantastic heat shield design.
My FR-S has a build thread!
(It's mostly full of Nissans) |
Similar Threads | ||||
Video and short review on the Cusco Engine Mounts and Rear Diff Brace | RallySport Direct | Engine, Exhaust, Transmission | 24 | 07-23-2018 03:43 AM |
Engine Mounts? | mrk1 | Engine, Exhaust, Transmission | 17 | 05-15-2016 04:31 PM |
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive | Pure Automotive | Engine, Exhaust, Transmission | 23 | 05-15-2016 04:21 PM |
Scion FR-S (2013 2.0L) - Cusco Strengthened Engine Mounts | ptuning | Engine, Exhaust, Bolt-Ons | 0 | 02-04-2013 10:24 AM |
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive | Pure Automotive | Mid-Atlantic | 9 | 01-31-2013 01:03 AM |
