Forced Induction Turbo, Supercharger, Methanol, Nitrous |
12-02-2012, 05:41 AM | #29 | |
Drives: '06 AM V8V Coupe
I think you need a bigger cam to pull this off since the volumetric efficiency at high rpm is evidently quite good on the stock cam, and the duration is not all that high so it is likely near or at fully retarded position at high rpm for latest possible intake closing. A bigger cam would help bleed off volumetric efficiency. Say if you were planning on running 9 "traditional" psi (increasing mass airflow by 60%), a cam that closes 30 degrees later and opens a few degrees earlier (for pumping loss reduction, would need cam phasing remap) might reduce volumetric efficiency by 25% (probably an exaggeration) at the top end, so your absolute pressure goes from 1.65 bar up to something like 2.4 bar if you can maintain the same mass airflow rate, and now you're sitting in the centrifugal blower's maximum efficiency zone The intercooler now sheds twice as much heat off, so the final charge temperature is considerably lower. With more modest power aspirations (such as 1.4x stock mass flow rate) then an Eaton TVS charger would be a bit more appropriate since the boost pressure will be about 0.8 bar, where the TVS is most efficient. |
The Following User Says Thank You to serialk11r For This Useful Post: | FreshFRS (12-02-2012) |
12-02-2012, 01:19 PM | #30 | |
KCCO From Canada
Drives: Asphalt FRS
The Following User Says Thank You to FreshFRS For This Useful Post: | JoeBoxer (12-03-2012) |
12-02-2012, 09:39 PM | #31 |
Drives: 12' Jeep Rubicon 08' 997 Targa 4S
I just wish we didn't have to settle for less than an excellent turbocharger in a kit, No matter how driveable or power it has I wish I could use a GTX28r series turbo with UEL if not EL headers on 1.1 bars of boost at least, Not sure if stock motor can take it tho.. oh well. We'll get there when I find a BRZ in black around here for sale lol
12-02-2012, 09:43 PM | #32 |
Drives: 13 FRS
Well you haven't seen our kit yet
The Following User Says Thank You to JDLAutoDesign For This Useful Post: | JoeBoxer (12-03-2012) |
12-02-2012, 09:50 PM | #33 |
Drives: 2003 Subaru Outback
Dream kit for this car, gtx3582r(in front of engine), big frontmount, UEL, V-banded, 3" single exit exhaust. Unless you can make your own kit, you gotta settle with what companies produce.
12-02-2012, 09:53 PM | #34 |
Drives: 13 FRS
There are better pricing options than a GTX. Our kit is pretty modular so if you really want a 35R that will not be a problem
12-02-2012, 09:54 PM | #35 |
a 6262 will work just as well
12-02-2012, 09:55 PM | #36 |
Drives: 13 FRS
Or a 6235
12-02-2012, 09:58 PM | #37 |
12-02-2012, 10:01 PM | #38 |
Drives: 13 FRS
We will have more details in a week or so. Just need to dyno all our NA parts then we can wrap up the turbo kit. Check our website to see our work. We have been building high quality turbo kits for 10 years
12-03-2012, 12:03 AM | #39 |
Drives: Whiteout FR-S
Can't wait to see the twin scroll, I think a supercharger is more for me but all if them have one or more issues I don't like except maybe the litchfield.
The Following User Says Thank You to JoeBoxer For This Useful Post: | smacdon (05-13-2015) |
