Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
#15 |
Drives: 13 Whiteout
2K to spend?.....not on audio says I...go fast bits FTW.
2013 Scion FR-S (Whiteout) GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned. Less parking more racing |
#16 |
Drives: Whiteout FR-S
Not sure when jbl was ever not a top tier company, sure they make cheap entry level stuff but their high end lines have always been good. Even the cheap jbl gto subs are well ahead of most other entry level stuff. Their MS components are very positively reviewed and the EZ amps are simple to install and make good power.
#17 | |
Drives: GBS BRZ Limited
That's not a bad option and I saw you mention it in your build thread. My question would be how teathering works from phone to phone. Also, I believe you answered this, but the EVO is using the Pioneers GPS antenna, correct? I like the new interface Dezoris is using prototyping. It's pretty slick and polished. Plus, by using an Android based device I can always swap out to another interface if I don't care for it. My major concern with using something like a MK808 w/ a stand alone monitor is audio quality. I'm somewhat an audiophile and would like the best possible sound I can get from my system. I'm pretty new to the Android platform but I'm fairly certain it won't support an external DAC. |
#18 |
Well, the audio is over HDMI, so the quality will be dependent on the head unit, not the MK808. Yes the EVO uses the Pioneer GPS.
#20 | ||
Using a stand alone monitor like the Xenarc, not pairing it with a head unit. ![]() If the MK808 supported an external audio processor like maybe a Creative Labs X-Fi HD I could pipe the audio to a processor like the 3sixy.3 but that's just adding layers of complication Last edited by Skippman; 02-21-2013 at 01:26 PM. |
The Following User Says Thank You to Skippman For This Useful Post: | 2forme (02-21-2013) |
#21 |
Drives: 2013 FR-S, raven
My budget is 4k so the components will vary a bit, but this is what I got and could be a good reference point:
Headunit: Pioneer AVH-x5500bhs (around $400) Front stage: Audible Physics XR3M 3" Wideband (in place of tweeters) and 6.5" Midbass (around $1000) DSP: Mosconi 6 to 8 DSP (around $800) Subwoofer: Arc audio ARC8 (around $125) Amplifiers: Arc Audio XDi 803 and 804 (around $800 for both) The rest goes to labor, building a custom amp rack, fiberglass side sub box, sound deadening, etc. Good luck.
悪魔のハチロク
2013 Scion FR-S, Raven Current Mods: TRD Full Body Kit | TRD JDM Exhaust | SQ Audio by Simplicity in Sound Stance Coilovers & LCA | TE37SL18x9.5PressedGraphite |
The Following User Says Thank You to brianlo622 For This Useful Post: | JoeBoxer (02-21-2013) |
#22 |
The Arc Audio KAR series was on my short list, but you prefer the XDi's? What's the major difference? They're both Class D amps as far as I can tell.
I've heard of Mosconi but never experienced them in person. I'm wondering if thats not a West Coast thing like Nakamichi was back in the day. |
#23 |
great question regarding the XDi's =)
Part of the build of my goal is to maintain the trunk space, maintain the spare tire, and also make sure my rear seats are still foldable. Therefore, I needed amps that have a small footprint and the XDi's are perfect. When the system is done, I will share some pictures, but basically these two amps and the DSP are installed on a custom amp rack, replacing the skinny but long piece of styrofoam that sits between the rear seats and spare wheel. the KAR series are sweet if space is not a concern. I think Mosconi recently entered the market, and they do have a wide range of products. My friend @DekaMori has the AS series and it sounds awesome. http://www.ft86club.com/forums/showthread.php?t=19058 When it comes to DSP, I think Audison is great =)
悪魔のハチロク
#24 |
#25 |
XDi's are great small footprint amps as are the JL Audio XD's and HD's, Rockford Fosgate BRT (6.5"x4.25"
The Following User Says Thank You to JoeBoxer For This Useful Post: | brianlo622 (02-21-2013) |
#26 |
Drives: Argento 6spd FR-S
bit10d or 3sixty.3
HSK165XL or HSK165XL HDP5 or P1000X5 HX250D or T1D210 I would say one of these setups, but keep in mind building a box. If you build it about 150 for mats, if you have it built then 350-550. Ill pm you on a 3rd option. Last edited by cruzinbill; 02-21-2013 at 07:28 PM. |
Wheel Directory: 5Zigen FN01R-C 18x8.0 +35 | jma | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 08-26-2013 03:15 PM |
New tires on a budget | jflogerzi | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 01-23-2013 06:32 PM |
BALLIN ON A BUDGET | Obja | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 10-22-2012 10:17 PM |
There goes my MOD'ing Budget | RedRocket | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 10-19-2012 08:14 AM |
Toyota working on low budget FR sports car!!! | yera | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 03-16-2011 02:45 PM |
