Old 09-14-2021, 09:44 AM   #1
Akrochik
Drives: Golf TDI for now
Bouncing on high speed right-hander on track
My car was doing something odd on track in my last session. There's a long high speed right hander with a lot of camber and many times in that corner my car did a sort of rhythmic bouning when I was around 33% throttle. Is this porpoising? Anything else I can do to address? Thanks!
2013 FRS
Tein Flex Z coilovers set to about 66% of the way to full firm
1" lower than stock
Stage 2 tune and bolt ons
Akrochik is offline   Reply With Quote
Old 09-14-2021, 10:11 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
What swaybars are you running?
Old 09-14-2021, 10:18 AM   #3
Akrochik
Suspension is stock besides the coils
Old 09-14-2021, 11:25 AM   #4
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
Could be lots of things. Maybe a read thru this can get you started
https://grassrootsmotorsports.com/ar...-to-cure-them/
Sent from my SM-G960U using Tapatalk
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
Old 09-14-2021, 02:15 PM   #5
CSG Mike
CSG Mike's Avatar
2013 FRS
1" lower than stock
Have a datalog?
Old 09-14-2021, 02:59 PM   #6
Akrochik
I have the outputs from TrackAddict but I imagine you're looking for something more detailed.
I do have onboard video if that's helpful.
Old 09-19-2021, 12:23 PM   #7
949 Racing
FT86Club Official Vendor
949 Racing's Avatar
Drives: Miata, GT350, FR-S
Its your shocks. FLEX-Z are a relatively cheap twin tube with a lot less bump travel than OEM. Turned up stiff enough to avoid wallowing and they'll bounce due to inadequate low speed rebound. Turned down to avoid bouncing.. and it wallows.
Make sure you have lengths adjusted so you're staying off the bumpstops. Raising the car will likely reduce the bouncing.
Swaybars are not the source of the oscillation and have nothing to do with it so ignore that.
Any adjustable shocks should always be set to the softest possible setting that controls wallow. No stiffer than that. Poorly designed shocks will often start to bounce before the wallow goes away so you can never find the right setting.
949 Racing is offline   Reply With Quote
The Following 6 Users Say Thank You to 949 Racing For This Useful Post:
alphasaur (09-19-2021), Decep (09-19-2021), kevaughan (09-21-2021), RToyo86 (09-19-2021), StraightOuttaCanadaEh (09-19-2021), Ultramaroon (09-19-2021)
Old 09-19-2021, 04:41 PM   #8
義理チョコ
Critical damping is critical
Old 09-19-2021, 09:01 PM   #9
949 Racing
949 Racing's Avatar
tru dat
The Following User Says Thank You to 949 Racing For This Useful Post:
Old 09-20-2021, 12:41 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Never experienced that in the couple seasons I ran Flex Z's, though I also didn't have a corner like what you described. Don't think ride height is the issue.
Old 09-20-2021, 01:45 PM   #11
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
As long as OP hasn't done something to reduce bump travel I'd agree, one of the advantages of the 2-piece coilovers is they can keep the stiffness consistent at various heights. On another coilover or if the OP has reduced bump travel by lowering the spring perch and is using more bump stop due to a lower height then yes, ride height will matter for handling bumpy pavement.
ineedyourdiddly
bad window seal at high speed? slyphen Issues | Warranty | Recalls / TSB 9 03-04-2018 07:57 PM
Downshift from 6th to 5th at high speed bravedeer Issues | Warranty | Recalls / TSB 35 08-30-2017 09:26 PM
High RPM for current speed HachiRo Engine, Exhaust, Transmission 14 04-02-2015 02:59 PM
Brakes unless at high speed - what to tackle? empower-auto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 10-12-2012 05:06 PM
Video: BRZ / FR-S High Speed Run to 124 MPH (200 km/h) Levi BRZ Photos, Videos, Wallpapers, Gallery Forum 43 05-16-2012 12:37 AM
