Old 08-10-2017, 10:18 PM   #2227
BassBoosted86
Drives: 2015 Halo Scion FR-S
Originally Posted by batlwagn View Post
Just got these yesterday to replace my 265 Hankook Ventus v12. Tires are Federal 595rs-rr 265/35R18
Sent from my SAMSUNG-SM-G891A using Tapatalk
Let me know how these fit for you ! I just picked up a brand new pair of RAYS Gramlights 57xtreme in 18x9.5 +40 offset & they are wrapped in a set of 265/35/18 Federal RS-R tires. I have seen pictures of @Jive Turkey car running the same exact setup, but couldn't find solid details about weather or not I can expect these to rub hardcore or just the "rear bumper tab" as everyone has stated before, I have RS-R Moto spec coilovers waiting to be installed with these so spring perch clearance issues wouldn't be a problem. Literally just trying to determine what I need to do in order to mount these to the car.
BassBoosted86 is offline   Reply With Quote
Old 08-10-2017, 10:24 PM   #2228
batlwagn
Drives: 2016 Outback 3.6R, 2016 BRZ(ordered
I know the RS-RR run a little wide but you should have any clearance issues unless the car is stupid low. I'm on Apex'i coilovers and 18x9.5 +40 NT03+m wheels I am using a 5mm spacer to clear my brakes but don't have any clearance problems at the moment. The car is only lowered about an inch lower than stock.
ALL THE MODS!!
batlwagn is offline   Reply With Quote
Old 08-21-2017, 04:56 AM   #2229
Stimmed
Stimmed's Avatar
Drives: Toyota 86
Just got done putting 275/35r18 Federal RSRR on my CE28SL's 9.5 +40.
Still plenty of room height wise. Wouldn't go any wider on the rim then that though as people have mentioned the RSRR run about a size +. But fitment is great no issues with clearance. Had to raise the back a bit to avoid any rubing. Only other option would be a slight guard roll and lower it maybe 1cm to a decent height. But I am loving not having to stress about speed bumps as much will keep it around this I think for a while!.
Fronts are 255/35r18 same brand tyre. Had 255 on the rear before the 275s went on.
2013 Toyota 86 (IQOf86) - Coyoda Turbo Kit, Perrin 3" Exhaust, 18" CE28SL's, Custom Oil Cooler/Transmission Cooler, Tuned by Coyote Tuning, Built FA20, E85 Fuel, Turbo Kit and Oil Coolers installed by Turbo Yoda
Stimmed is offline   Reply With Quote
Old 08-22-2017, 03:37 PM   #2230
GirlRepellent
GirlRepellent's Avatar
Drives: Evo X FE/FRS 10 Series
Do you have anymore pics?
GirlRepellent is offline   Reply With Quote
Old 08-22-2017, 09:29 PM   #2231
Stimmed
Stimmed's Avatar
Drives: Toyota 86
Cars at the mechanics atm. Will take a few more when I get it back in a day or so.
Old 09-15-2017, 09:43 AM   #2232
ReeceR34
ReeceR34's Avatar
Drives: 2014 whiteout FR-S
I need some help guys. I'm on a 18x9.5 +38 front and +40 rear with a 255/40/18 federa super steel 595. I'm on bc coils, spc toe arms and lca's. aligment set at -0.5 camber up front and -1.00 in the rear. I have about a finger gap all around on full hard damper setting. I for some reason am rubbing so bad up front on the top of the tire to the plastic liner that I've literally destroyed it on the driver side and soon to be the passenger. Dips and bumps it scrubs and at full lock rubs the inner frame. What am I doing wrong? Too big of a sidewall? Should I drop it down to a 255/35 up front or do I need more camber or something? I'm not rubbing the fender itself just the liner and inner frame.
ReeceR34 is offline   Reply With Quote
Old 09-15-2017, 10:05 AM   #2233
batlwagn
Sounds like to much side wall. Or just adjust you ride height (free mod). Mine are 265 35 18 on 18x9.5 +35 up front and +40 out back no rubbing anywhere
ALL THE MODS!!
The Following User Says Thank You to batlwagn For This Useful Post:
ReeceR34 (09-15-2017)
Old 09-15-2017, 11:51 AM   #2234
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
Federals run meatier than other tire brands, speaking from experience (I was once forced into a set of federals and assumed they would be okay because they were the specs of the prev tires I had.. A couple of miles later and the coilovers ate an entire ring on the inside of the brand new set of federals). Those 255's run like 265's.. 265/40 is pretty huge with that suspension set up. I have 265/35 continentals and it runs pretty flush. Definitely sounds like too much sidewall. Good luck!
IG: @Lucky_FatPat
10 series // TRD x Turbo Build:
http://www.ft86club.com/forums/showthread.php?t=79474
mmmcambelsoup is offline   Reply With Quote
The Following User Says Thank You to mmmcambelsoup For This Useful Post:
Old 09-15-2017, 12:16 PM   #2235
swarb
Wrong tire size. You are a full Inch+ taller than what is recommended. 255/40 are for 17's. You are on 18's...
245/35 or 255/35 are your choices.
The Following User Says Thank You to swarb For This Useful Post:
Old 09-15-2017, 12:59 PM   #2236
ReeceR34
ReeceR34's Avatar
So im guessing I should switch to a 255/35 up front then and rhat will donthe trick as far as the liner scrub.
Old 09-17-2017, 03:44 PM   #2237
BassBoosted86
Finally got around to mounting the rims and I must say I am extremely happy with the way everything came out ! Running 265/35/18 tires on a set of 18 x 9.5 +40 offset Rays Gramlight 57Xtreme with a drop of about 1.25" all around. This leaves me with about a finger space of gap between the fender and the wheel on all corners. Fitment is spot on & it's exactly what I was hoping they would look like ! They " poke " ever so slightly without spacers but in my opinion it perfectly completes the look I was trying to achieve. Dropped on RS-R sport I coilovers, I had to have the alignment guys use the offset toe bushings that came with my SPC LCA to get it back into a "spec". Alignment specs are as follows, anyone care to drop some words of wisdom Not entirely sure how good this actually is or not. it almost seems like it's pulling to the right, could that be from having toe on one side in the front and not the other?Other than that everything seems good.
Front camber - L= -1.8 & R= -1.8
Rear camber - L -1.1 & R= -1.4
Front toe- L=0.01 & R= 0.00 Total= 0.02
Rear toe- L=0.02 & R=0.01 Total= 0.03
http://imgur.com/gallery/e8QZu
http://imgur.com/gallery/EvMmk
http://imgur.com/gallery/zMgvf
Old 09-18-2017, 10:51 PM   #2238
kai_gt86
Drives: 2017 Toyota 86
265/35/18 Zestino Gredge 07RS on 18x10 +40 VOLK ZE40
-2.4 Front // -1.7 Rear
RS*R Sports-i Coilovers
RS*R LCA
SPC Camber Bolts
kai_gt86 is offline   Reply With Quote
The Following 4 Users Say Thank You to kai_gt86 For This Useful Post:
ApexEight (09-18-2017), ILLSMOQ (10-04-2017), Jive Turkey (09-23-2017), jordonallison (09-19-2017)
Old 09-18-2017, 11:30 PM   #2239
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
RS*R LCA
SPC Camber Bolts
Holy shit. Well done. That's a lot of wheel and tire. How does it feel? More pics pls lol
ApexEight is offline   Reply With Quote
Old 09-19-2017, 01:13 AM   #2240
kai_gt86
Thanks! Feels great, just a little rubbing on the rear bumper tab. Going to see if I can get it on the track next season.
@kai_gt86
Search this Thread:
Advanced Search
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
