Old 06-26-2017, 05:57 AM   #379
ZZT86
ZZT86's Avatar
Drives: BR86
^^ No, rings not required, wheel is perfect fit for BR86 & should not rub on stock suspension, plenty clearance but . . . If you have neg camber of -1.5deg like I & you go for wider tyre (235/40) it will rub on stock suspension. If you have less neg camber, eg: -1 you may find it OK. Best way to overcome these issues is to replace suspension with coilovers.
ZZT86 is offline   Reply With Quote
Wheel Directory: Gram Lights 57Xtreme 17x9.0 +40 L8Apex Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 71 08-05-2023 09:20 PM
Wheel Directory: Gram Lights 57Xtremes 18x8.5 +45/18x9.5 +40 WorkoArt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 02-18-2017 06:46 PM
Candy Red Gram Light 57Xtreme 18X9.5 +40 ugadogs_11 Wheels and Tires 8 10-03-2013 09:04 AM
FS: Gram Lights 57Xtreme 18x8.5, 18x9.5 funcheung Canada Classifieds 7 09-16-2013 05:01 PM
