#169 |
Drives: 2014 FRS LS Swap
got the fuel system redone with ptfe lines today and relocated the fpr. no more fuel smell and the fpr gauge is easier to see. I also installed siemens deka 80lb injectors from tre performance. flow matched and fit perfect in the ls2 intake. waiting on a professional brake flaring tool as the t bar always made off center flares no matter how careful i am. all brake lines removed from car currently as a vacuum test of the lines showed leaks on almost every flare i made. ordered 25 ft of earls brake line and will rebend and remake every line on the car.
![]() ![]() Sent from my SM-G973U1 using Tapatalk |
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 11:54 PM |
Not just another ls swap | killin'_for_a_livin' | Member's Car Journals | 7 | 08-28-2016 05:58 PM |
WRX SWAP!!! | PowderfaceTr. | Photos, Videos, Wallpapers, Gallery Forum | 1 | 02-24-2015 07:29 PM |
Ej Swap | koyv90 | Engine Swaps | 50 | 11-14-2013 08:59 PM |
Should I swap? | michaelahess | BRZ First-Gen (2012+) -- General Topics | 8 | 06-12-2012 08:32 PM |
