Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB > Technical Topics > Engine Swaps
Old 06-02-2021, 03:51 PM   #29
Irace86.2.0
Non Sequitur
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I purchased a Drift Armor front crash bar. This isnít needed, but I wanted something that would allow for more flexibility and room for mounting the FMIC and for running the IC piping. I also bought a Honda coolant overflow tank that I want to use to replace the huge windshield washer reservoir. I plan to retrofit the filler neck and pump to this new reservoir.
I bought a Berk catted front pipe. That has delays but should be here in a few weeks. I bought some titanium exhaust studs for the header. Iíve had bolt mounting/clearance problems and broken/worn bolts in the past. These should make installation and reliability better. I bought a Mishimoto S-Line FMIC. I opted for the black powdercoated version for stealth. Very nice quality for the price.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
Arthur-A (06-02-2021), BrahmaBull1990 (06-02-2021)
Old 06-05-2021, 01:10 AM   #30
Irace86.2.0
Non Sequitur
In preparation for the FMIC intercooler piping, I made a smaller reservoir. This is necessary. The crash bar should add more clearance, but the reservoir had to go. It is huge. More pictures in My Build.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
DustinS (06-05-2021)
Old 06-05-2021, 05:48 PM   #31
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
Howíd you fabricate the bracket(s)?
Drifter X is offline   Reply With Quote
Old 06-05-2021, 07:43 PM   #32
Irace86.2.0
Non Sequitur
Originally Posted by Drifter X View Post
How’d you fabricate the bracket(s)?
It is just aluminum bent and hammered with a rubber mallet in a vice to shape. I drilled some holes in the ends and cleaned up the edges. Nothing fancy.
Old 06-11-2021, 02:58 AM   #33
Irace86.2.0
Non Sequitur
Few more pics with and without the crash beam. Iíll add another when I get the new Drift Armor crash beam.
Brz-123 (06-11-2021)
Old 06-11-2021, 03:02 AM   #34
Irace86.2.0
Non Sequitur
Just a mock up of the FMIC, but not in any way is it in a final position. Just more showing the size.
The Following 4 Users Say Thank You to Irace86.2.0 For This Useful Post:
Arthur-A (06-12-2021), BrahmaBull1990 (06-11-2021), Capt Spaulding (06-11-2021), WC-BRZ (06-11-2021)
Old 06-11-2021, 10:21 PM   #35
Irace86.2.0
Non Sequitur
Picked up the engine today. Getting more serious boys! Pulled the spark plugs. Looks clean. I havenít pulled the valve cover off, but it looks clean inside.
The Following 8 Users Say Thank You to Irace86.2.0 For This Useful Post:
Arthur-A (06-12-2021), BrahmaBull1990 (06-12-2021), Clash0901 (06-12-2021), Drifter X (06-12-2021), NoHaveMSG (06-11-2021), Petah78 (Yesterday), RToyo86 (06-11-2021), Spuds (Yesterday)
Old 06-12-2021, 05:29 PM   #36
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
I can't wait for the results on this! I sold my 2jz BRZ but I kind of want a k swapped one. I just know it will not cost much less so I probably won't do another, but K turbo swapped something would be cool. Maybe an e30? O.o
Want to 2JZ swap your 86? Click here first!!
Clash0901 is offline   Reply With Quote
The Following User Says Thank You to Clash0901 For This Useful Post:
Irace86.2.0 (06-12-2021)
Old Yesterday, 08:15 PM   #37
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Ok, I need to point out something that has probably been glossed over here. Now, doing all the work himself is impressive enough, but what I find crazy about this is Irace is doing it all in a 1 car garage that seems to double as his fitness room...
Irace86.2.0 (Yesterday), NoHaveMSG (Today)
Old Yesterday, 10:17 PM   #38
Irace86.2.0
Non Sequitur
I little more progress stripping the motor. Everything looks clean. I removed the top, oil pan and timing cover in preparation for installing the oil pump and 50 degree VTC when I eventually get those items.
I may clean and paint the longblock and then do a wrinkle coating for the valve cover. Either red or black for the cover. Either silver or grey for the longblock. I need to weld on a bung for the breather that will go to a catch can, but I want to see what Kpower comes up with for a solution to the rear of the engine.
jflogerzi (Today)
Irace86.2.0 Build Irace86.2.0 Member's Car Journals 175 06-05-2021 12:48 AM
KPower Industries K24 swap PulsarBeeerz Engine Swaps 194 05-28-2021 12:45 PM
Turbo or swap Fastend Forced Induction 35 06-11-2020 07:12 PM
Built Turbo K24 Swap? Calmwhiteguy Engine Swaps 31 02-13-2018 05:07 PM
IRACE86's Build Irace86 Member's Car Journals 25 01-10-2017 04:35 PM
Copyright ©2000 - 2021, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
