Old 06-16-2021, 07:00 AM   #1
I_amhassan
I_amhassan's Avatar
Drives: Toyota 86
Exclamation Rebuilding Engine, Help!
I had purchased a used gt86 last year and the car had plenty issues to start with which i fixed step by step until... The connecting rods got damaged.
The garage that dismantled my engine has made a huge list of items i need to buy including oil pump, water pump, pistons, conrods etc. He did confirm the damage is only done to the conrods but asked me to replace most of the internals.
Could anyone advise what parts to look at, aftermarket or OEM or even mention parts that I can reuse because I have never had to rebuild an engine and I'm trying to save as much as I can.
Thanks
I_amhassan is offline   Reply With Quote
Old 06-16-2021, 07:15 AM   #2
Ashikabi
Ashikabi's Avatar
Thanks
Replacing most of everything is pretty standard. The labor is so expensive, you don't want to have someone do it twice. Which makes the few hundred for the extra parts a good investment. I would personally use aftermarket so the motor is stronger, then you can boost it later without risking another rebuild. But I definitely understand saving money too. At the very barest minimum you have to replace your seals and bearings. It's really up to you how much you can spend. You should be talking this over with the shop to see what it will cost to do it cheap and the associated risks. Since they will know better how far they can go at your price point
Sent from my ONEPLUS A5010 using Tapatalk
Old 06-16-2021, 06:36 PM   #3
義理チョコ
How many miles/Kms on the engine? How did only one or more conrods fail without putting a hole in the block?
Something smells fishy.
Old 06-17-2021, 04:50 AM   #4
I_amhassan
I_amhassan's Avatar
Drives: Toyota 86
Around 121000 kms done
Okay so the reason why I did have the block opened is because everytime I had my foot on the throttle, there was loud knocking sound coming from the engine. however it wouldnt knock on idle or maybe it did very faintly. the more i pressed my foot the louder the knocking got.
Old 06-17-2021, 12:01 PM   #5
義理チョコ
I see. Spun rod bearing. I guess if they're blown out at the wrist pins too... Ash is right. Whole thing needs to go.
Old 06-20-2021, 04:18 AM   #6
I_amhassan
I_amhassan's Avatar
Drives: Toyota 86
Understood..
Where do i buy aftermarket parts from that would ship internationally? Any suggestions?
Old 06-24-2021, 05:01 PM   #7
daninplymouth
Drives: 2017 86
Fensport in the uk have complete blocks with upgraded rods. They might ship
daninplymouth is offline   Reply With Quote
Old 06-24-2021, 06:56 PM   #8
Swift
I just Drive.
Swift's Avatar
Drives: in the womb still
Honestly I would do a k-swap a this point. With a spun rod bearing you will probably need crank reground as well etc etc. These blocks or so iffy on holding power or being reliable it just aint worth dumping money into it. Just my two cents
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project
Swift is offline   Reply With Quote
Old 06-24-2021, 07:12 PM   #9
Ashikabi
Ashikabi's Avatar
K swap is gonna run you 10 grand+. Used FA20, 3000 if you're patient. I cannot recommend a swap unless you're really fuckin dedicated to your particular car, know what you're doing, and have really deep pockets
Old 10-04-2021, 02:05 AM   #10
I_amhassan
I_amhassan's Avatar
Drives: Toyota 86
Update: So I am rebuilding the engine, ordering the parts i need off a list
The mechanic just told me i need to replace my fuel injectors. I've been trying to read about them but I can't figure it out. But what I see is it is pointless to upgrade your injectors if your running NA?
Any thoughts and recommendations?
Old 10-04-2021, 06:59 AM   #11
Ashikabi
Ashikabi's Avatar
Maybe replace since you've already got the motor apart. But yeah there is no need to upgrade on NA
The Following User Says Thank You to Ashikabi For This Useful Post:
I_amhassan (10-10-2021)
Old 10-05-2021, 09:38 AM   #12
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
IMO: I would have the injectors professionally cleaned and tested. It cost me $20 each for the PI's and $30 for the DI's. Getting new ones sounds like an unnecessary expense.
blsfrs is online now   Reply With Quote
The Following User Says Thank You to blsfrs For This Useful Post:
engine, rebuild
Rebuilding Head from 2013 ML Engine, Exhaust, Transmission 8 02-22-2021 07:00 AM
Rebuilding FRS! darko Scion FR-S / Toyota 86 GT86 General Forum 6 03-29-2015 09:22 PM
MotoIQ Article on Tein Dampers and their servicing/revalving/rebuilding CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-29-2015 02:52 AM
Thoughts about rebuilding stock clutch. (or, conversation about friction materials) qtwre Engine, Exhaust, Transmission 0 07-09-2014 12:56 PM
Rebuilding strut/shock dampers to be firmer than spring rates? fooddude Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 04-16-2014 12:23 AM
