07-14-2022, 04:04 PM | #1163 |
Drives: 2013 toyota 86
So I got my TB all back together & then noticed the car sounded a lil off. Cracked my cat back almost all the way around. But nothing a welder can't fix.
The Following User Says Thank You to hedtrip For This Useful Post: | RedReplicant (07-14-2022) |
07-14-2022, 09:53 PM | #1164 |
Drives: 2017 Hot Lava 86
Pretty much identical to how mine cracked. Mine actually cracked all the way around at that location though. It also cracked nearly all the way around the weld at the muffler, and at the flange for the header.
07-15-2022, 09:27 AM | #1165 |
Drives: Fr-s
Thinking out loud, I wonder if an engine torque damper would help control the movement of the engine and reduce some of the exhaust issues.
07-15-2022, 03:27 PM | #1166 | |
Drives: None
I was going to do the red 90a version, but I looked at the similar style 70a Supermiata mounts that I used in my SuperMiata and they were already super aggressive. Track car, but come on, need to be able to see out of the mirrors. https://www.iagperformance.com/iag-s...sti-04-08-fxt/
07-15-2022, 08:40 PM | #1167 | |
Drives: None
Yay, more oil temp stuff.
Turns out, KPower put the oil temp input on SPI, rather than AVI. Haltech has a support note about this: https://support.haltech.com/portal/e...rature-sensors Quote:
KPower was like nah and threw random colors at the ECU connectors. Pin 13 was also already populated by an orange wire. Where does it go? Who knows. Side note is that the unassigned SPI1 goes to the connector that KPower uses for their flex fuel kit. I tried the Haltech official sensor calibration (https://www.haltech.com/product/ht-0...rature-sensor/) and the sensor is reading as 140c maxed out at rest but not disconnected. Assigning the sensor back to the SPI input in Haltech reads as disconnected, which is expected. A lot of the calibrations for the Bosch Motorsports sensor AKA Bosch 0261230340 sensor AKA Mazda PY8V-18-541B are listed with a with 4.6k pull up resistor included in the values which is why those don't work for us. This is pretty annoying.
The Following User Says Thank You to RedReplicant For This Useful Post: | endless_pain (07-18-2022) |
07-16-2022, 03:16 AM | #1168 | |
Drives: '88 Supra 1JZ, '16 FR-S, '23 GR86
Would a fluidampr pulley help any with vibrations?
NARFALICIOUS
Noob Poster 1988 | 2016 |
07-16-2022, 10:55 AM | #1169 |
Drives: Fr-s
I'm assuming not since it was sold like that from the factory, I drove an rsx-s years ago and it didn't stand out. However the stroke is like 86 vs 99 iirc.
The Following User Says Thank You to redlined600 For This Useful Post: | NARFALICIOUS (07-16-2022) |
07-16-2022, 07:14 PM | #1170 |
Drives: None
Well, at least I've got an answer. There is interference from DBW to other sensors, which is what is causing the oil/temp sensor reading issues. I'm wondering what else is affected by this.
07-16-2022, 07:44 PM | #1171 |
Wears Pants
Drives: 14 FRS K24 swap - SOLD
07-16-2022, 08:22 PM | #1172 |
Drives: None
It might be more obvious when the car is up to running temperature since the scaling on the temp sensor is pretty exponential as you get hotter.
07-17-2022, 01:43 PM | #1173 |
Drives: 13 White MT FR-S
is your sensor grounds good? One of the benefits of using the SPI is that its shielded, so if the shielding is not grounded correctly it could get the interference like that.
07-17-2022, 03:46 PM | #1174 | |
Drives: None
I corner weighted my car today, it went from 2901lb with the Harrop/FA20 to 2687lb after the swap. Ballpark it at about a 200lb weight loss.
The Following 2 Users Say Thank You to RedReplicant For This Useful Post: | captain awesome (07-18-2022), Irace86.2.0 (07-17-2022) |
07-18-2022, 04:44 PM | #1175 | |
Drives: 2015 FR-S
So the Kpower kit uses the engine mounts from the WRX? would our FA20 STI mounts work or perhaps the group N STI mounts for STI.
07-18-2022, 04:48 PM | #1176 | |
Drives: None
KPower says the STI mount just added NVH, but I am more worried about keeping things from moving. Good idea? Bad idea? I dunno.
Similar Threads | ||||
Rigid Industries SR-Series Pro Light Bar on my BRZ | Stang70Fastback | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 12-29-2019 03:13 PM |
Airlift from industries finest | J_Nasty | Member's Car Journals | 0 | 02-04-2017 01:59 PM |
Carbox Industries - Introduction | CarBox | CANADIAN Sales | 5 | 04-22-2014 01:22 PM |
86 industries | Duthebarber | Northern California | 70 | 03-28-2014 04:10 PM |
Another 86 Industries another bad experience | sikest | User/Vendor/Sponsor Reviews, Feedback, Comments | 3 | 03-13-2014 01:00 AM |
