08-23-2020, 09:08 PM | #1261 |
Financial Distress
Drives: 2017 GT86 325WHP
JDL UEL V2 kit with the GT2860RS Turbo, exhaust is fully aftermarket, catless overpipe + front pipe + magnaflow catback.
Goal is ~310-320hp on 91 pump gas, will the 7psi spring with the kit do the trick or will I need a 10psi spring for that specific turbo? Thank you. |
08-23-2020, 09:14 PM | #1262 | |
Rust bucket enthusiast
The spring is also very easy to change, so don't feel like you're stuck with it |
The Following User Says Thank You to DarkPira7e For This Useful Post: | scottryan (08-23-2020) |
08-23-2020, 09:17 PM | #1263 | |
Financial Distress
The Following User Says Thank You to scottryan For This Useful Post: | DarkPira7e (08-23-2020) |
08-23-2020, 10:16 PM | #1264 |
Your not gonna hit that on pump with just 7 psi. Flex fuel you might have a shot... But for safety stay at the 7psi on pump till you know the time is dialed in
2013 Series 10 FRS #553
08-25-2020, 02:19 AM | #1265 | |
08-29-2020, 04:33 AM | #1266 | |
Whats next?
Drives: '13 Asphalt FRS MT
Life is too short to drive a boring car...
Instagram: @angelb_af |
The Following User Says Thank You to FRS_FIEND For This Useful Post: | DarkPira7e (08-29-2020) |
10-18-2020, 04:40 PM | #1267 |
Drives: 2015 FRS
What are the differences in JDL optioned turbos? GT28 vs GT2806RS vs GTX28, etc.
Sent from my SM-N960U using Tapatalk |
10-18-2020, 10:51 PM | #1268 |
Drives: RX-7 / BRZ
GT is the base of the line oil-cooled Garrett turbo charger with a cast machined compressor wheel. GT--R is the same GT turbo except with a ball bearing configuration. GT--RS is a R turbo with a built-in internal wastegate and water cooling. Unless I'm mistaken, the JDL kit is only currently offered with an external wastegate so this isn't an option without some custom fab work. GTX series is the top of the line Garret Turbo with Ball Bearings, Oil/Water Cooling, and an improved and more efficient billet compressor wheel. A GTX series turbo will run cooler, spool faster and have much more top end then the lower series Garrett turbo charges. 9/10 it is always worth the money. On a front mount car the oil/watercooling will easily pay for itself in IAT temps.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
10-19-2020, 07:46 PM | #1269 |
Drives: 2017 Toyota 86
@Itsjustmika_ To tag onto @Kiske, the JDL V3 kit has the newest G25 series available, which is another generation of engineering and materials advancements. In general it's more efficient (Lower friction and lighter components meaning faster spool, lower heat, longer lifespan), and in turn the turbine design is more aggressive, so it can reach similar pressure ratios with less exhaust flow than the previous generations.
That's pretty much how it goes for all of them, each step is an improvement in mechanical design, materials choice, or both. A GT28 was pretty cutting edge in the 90s, but it's not the turbo OEMs are choosing in 2020 to get 400HP from a 4-cylinder reliably. |
10-19-2020, 08:46 PM | #1270 |
Recommended a GTX. Don't skimp on the turbo. What's another 500-1000$ when your already spending 5-8k for kit+supporting mods (on the low end)
10-22-2020, 01:57 PM | #1271 |
Drives: 2013 Scion FRS
Hey guys, this might be a stupid question, I was wondering if you'd be okay to run an OEM catback with a turbo kit? Or are you better off with having a more free flowing system? In
my case I have a fully catless system with the HKS dual res front pipe and an OEM catback and I love the sound. I'm not sure how big of a factor it is but I figured this would be the place to ask. I like the idea of retaining the quietness and not being so in your face. Thank you. |
10-22-2020, 02:09 PM | #1272 | |
Drives: 2019 Toyota 86 TRD SE
Depends on your goals. There's nothing detrimental about running an OEM cat back on a bolt on turbo kit. Sent from my iPhone using Tapatalk |
The Following User Says Thank You to Drifter X For This Useful Post: | FRStevan (10-22-2020) |
10-22-2020, 02:42 PM | #1273 | |
The Following User Says Thank You to DarkPira7e For This Useful Post: | FRStevan (10-22-2020) |
10-22-2020, 02:45 PM | #1274 |
That Guy
Drives: 2013 asphalt FRS MT
Similar Threads | ||||
HKS Supercharger owners thread | wbradley | Forced Induction | 1048 | 10-12-2023 08:03 PM |
P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 02:31 AM |
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? | xuimod | Forced Induction | 106 | 09-01-2016 07:33 PM |
**Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 12:58 PM |
P&L Turbo Owners Topic Thread | GTB/ZR-1 | Forced Induction | 4 | 09-01-2013 06:27 PM |
