BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
03-01-2021, 01:16 PM | #15 | |
Drives: 2018 BRZ
The Following 3 Users Say Thank You to Ohio Enthusiast For This Useful Post: |
03-01-2021, 01:22 PM | #16 |
Drives: '23 BRZ
Overhangs are fine wit me. In fact a "proper" FR sports car is generally going to *want* to have longish rear overhang for better front/rear weight distribution.
What I wanna do is section out 10" of the lower part of the car and shove the rear wheels forward 10". Should be easy enough with a Sawzall, no?! |
The Following User Says Thank You to ZDan For This Useful Post: | Wally86 (03-02-2021) |
03-01-2021, 01:26 PM | #17 | |
has a funny hat
Drives: 2014 BRZ Limited
Funny enough this could work. A friend once "accidentally" jumped his Gen 1 Durango at Silver Lake Sand Dunes and face planted the landing. Somehow the airbags did not detonate, but the entire front end was mildly squashed. Luckily, it hit squarely and the damage was almost symmetric and didn't actually look like damage. The fenders and hood gained a subtle increase in the curves and the bumper was a little more flush. Aside from replacing the condenser and radiator he never had it fixed because he thought the result left it looking more aggressive. Not saying I'd try this with an 86 twin, but I'd definitely enjoy watching the attempt. |
03-01-2021, 02:43 PM | #18 |
Drives: 2019 potential buyer brz
Lololol How do you guys know what engineering and composite fabrication skills I have? Lolololol We’ll take bets when I do this next year!!!
This all depends on the new car having a similar structure to the current one. My plan is to modify just the plastic bumper covers and the hood. I’ll remove the rear bumper and perhaps replace it. IF the new car is similar to the old one, there is plenty of room to reduce the overhangs, as shown below. My plan is to reuse the areas of the parts that include the attach points and fabricate new areas in between using Rutan’s lost foam process. I’ll make oversize globs of expanded foam that are in contact with the saved portions. I’ll trim these to the desired shape, then lay the initial fiberglass plies over the whole deal. After removing the blob, I’ll remove the formed in place foam. There will be more fiberglass and of course, bondo and sanding and bondo and sanding. |
03-01-2021, 02:55 PM | #19 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
we'll revive this thread in a few years
03-01-2021, 08:20 PM | #20 |
Guys guys. I don't think we're paying enough respect to the anonymous internet poster's skill level.
Seriously though flyboy - I think you will get plenty of recognition if you pull it off. And I have no problem saying I'll follow your build thread. Until then though, it's all just dreamin'. Do you have any other projects you've done where we could see examples of your handiwork? |
03-02-2021, 12:51 AM | #21 |
Drives: 86 (sold), 370Z
What an odd thing to be concerned about. The overhangs are already quite short, and if you want it to look lower, just lower it on some coilovers. The hood is already pretty low, about as low as you will get on a budget, front-engined sports car with today's safety regulations. Even with a boxer four, they still need to leave a certain amount of space between the top of the engine and the bonnet for pedestrian safety (and cooling etc).
03-02-2021, 12:57 AM | #22 | |
03-02-2021, 02:31 AM | #23 |
Drives: JRSC BRZ SOLD
Just get rid of the OEM strut style suspension and you can lower the hood as much as you like.
The Following User Says Thank You to PulsarBeeerz For This Useful Post: | NoHaveMSG (03-02-2021) |
03-02-2021, 08:18 AM | #24 |
Drives: Crapcan
I think we should revive it every few months
The Following User Says Thank You to NoHaveMSG For This Useful Post: | soundman98 (03-02-2021) |
03-02-2021, 08:48 AM | #25 | |
Drives: '23 BRZ
Z4 coupe, new Supra, Shelby Daytona Coupe, 250 GTO, 240Z, etc. etc. The one thing that bothers me most about the FT86 is the 2+2 compromise. A *proper* FR 2-seat sports car generally has the rear wheels situated just aft of the driver, and not shoved way aft like a Scion tC. Functionally this puts more weight on the front wheels, hence we have a craptastic 55/45 F/R weight distribution. A short-wheelbase FT86 would be 50/50, would be ~100 lb. lighter-weight, be a bit stiffer torsionally, and would be even more responsive-handling. All wins for me. And I'm also a big fan of the look as well. Doesn't look "taller" to me due to shorter wheelbase, and definitely wouldn't in person. |
03-02-2021, 08:53 AM | #26 | |
Drives: 2018 Subaru BRZ Limited with PP
03-02-2021, 09:07 AM | #27 | |
Drives: '23 BRZ
Think if you moved the rears WAY way forward, at some point they'd take 100% of the weight and moving them any further forward the fronts would lift off the ground! |
03-02-2021, 09:16 AM | #28 | |
Similar Threads | ||||
IRP Short Shifter (60% shorter) - Install & Review | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 34 | 02-26-2019 09:41 PM |
FI+ shorter final drive | HUNTERANGEL121 | Forced Induction | 38 | 07-24-2017 12:41 AM |
is there a shorter endlink out there? mcs motion control damper | toby714 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 10-19-2014 07:28 PM |
OEM shorter lightweight battery bracket? | fstlane | Tracking / Autocross / HPDE / Drifting | 1 | 03-08-2014 12:26 PM |
WTB: Shorter exhaust hangers | FrSnake | Want-To-Buy Requests | 0 | 12-30-2013 09:25 PM |
