11-01-2021, 07:59 AM | #23409 |
TRACKBREAD
11-01-2021, 08:10 AM | #23410 |
11-01-2021, 08:57 AM | #23411 | |
Drives: 86 GT
The image below from one of the threads discussing this should give you an idea. https://www.ft86club.com/forums/show...7&postcount=22 Unfortunately I'm currently monetizing it - hope you understand. If there's enough demand from owners overseas I can set something up. Last edited by Compelica; 11-01-2021 at 09:57 AM. |
The Following 4 Users Say Thank You to Compelica For This Useful Post: |
11-01-2021, 09:16 AM | #23412 |
TRACKBREAD
11-01-2021, 09:51 AM | #23413 |
Drives: 86 GT
Pretty good so far - during testing I had set up a scenario and repeated it several times as consistent as I could; in that particular scenario I would see a significant delta with one side equipped and the other without.
Though, how much cooling is obtained is going to be due to many factors, eg. how far you've driven to allow it to cool, how fast you got up to speed, time to measurement - but the results from the repeated scenarios do show a trend that the deflector is doing its job. Some of the local guys are taking it to test on track during the next few days, will certainly be able to get some feedback from them. |
The Following 3 Users Say Thank You to Compelica For This Useful Post: |
11-01-2021, 08:36 PM | #23414 |
Drives: 2013 frs base
These look good. My car has 17x9 Apex wheels with 245/40 tires. I tried to refit the Porsche deflectors to my car. I trimmed them way down but never could get it so the tires didn't rub. If you haven't already, test fit your deflectors with aftermarket wheels and tires.
The Following User Says Thank You to blsfrs For This Useful Post: | Compelica (11-05-2021) |
11-01-2021, 08:49 PM | #23415 | |
Sent from my Pixel 5a using Tapatalk
2013 Series 10 FRS #553
The Following 2 Users Say Thank You to jflogerzi For This Useful Post: | Compelica (11-01-2021), Yoshoobaroo (11-01-2021) |
11-01-2021, 09:04 PM | #23416 |
Drives: Crapcan
What material are you using?
11-01-2021, 09:57 PM | #23417 |
Drives: 86 GT
11-01-2021, 10:33 PM | #23418 |
TRACKBREAD
11-01-2021, 11:00 PM | #23419 |
Drives: 86 GT
I have considered it but not fully explored that option - last I looked around it was prohibitively expensive for the expected demand.
However the current printed piece is very solid - I would think that I may have overengineered it in terms of structural strength (not an actual engineer) but I prefer having a larger safety factor. The deflector is light too, about 115g for each side. Since it is sitting on the lower arm it would technically be considered as unsprung weight, though it's unlikely to be a major concern but always an advantage to maximize what's available. |
The Following User Says Thank You to Compelica For This Useful Post: | Yoshoobaroo (11-02-2021) |
11-01-2021, 11:41 PM | #23420 |
Drives: 2013 Scion FR-S 10 Series
WHAT DID YOU DO TO YOUR FRS TODAY?
Cleaning
11-02-2021, 01:08 AM | #23421 |
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
i had enabled winter mode, now i am running on snows tires.
The Following User Says Thank You to Sasquachulator For This Useful Post: | Wally86 (11-02-2021) |
11-02-2021, 01:17 PM | #23422 |
Drives: 2013 Scion FRS
Change front wheel bearing
And wheels Sent from my iPhone using Tapatalk |
The Following 2 Users Say Thank You to buruguduy For This Useful Post: | beltax90 (11-09-2021), villainous_frx (11-06-2021) |
Tags |
:popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
