Drives: 2015 Scion Frs
What to do with PCV valve hose?
OK so I posted this question already on the general forum when I should've posted here. (Original Post Link At The Bottom)
So im building my turbo kit have everything mocked up besides the driver side PCV hose that is under the compressor (The hose that connects to the intake boot originally). You'll see my set up through this link that it's not a kit from a manufacturer. I sourced/"fabricated?" most of the throttle body piping myself. I just have this hose sitting there and I don't know what to do with it. You can see that I already have a catch can for the rear PCV valve. But I don't know what to do with the front one. LMK thank you guys, yall are clutch! https://imgur.com/a/yQKyoXW |
#2 |
Bubba says to run it into the other one.
Or, cork it off.
#3 |
That's your CCV Hose first off.
Secondly - run it through a catch can and vent to atmosphere (VTA) You don't want to cork that off
Kyle H. - #89 STX
#4 |
Drives: 2013 BRZ HKS Turbo
Connect it to the turbo inlet pipe, between filter and compressor. It's important that this sees vaccum and is not vented to atmosphere or worse, corked.
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
#5 |
That is your fresh air inlet for your PCV system. It is to be vented to atmosphere. There are different ways to do that. Factory is in the atmosphere pressure area of the intake, after filter before throttle body. Yours would be after filter before turbo as stated above. If you are concerned about oil blow by during boost you could vent to atmosphere with its own filter or run it through a catch can.
#6 | |
#7 |
So this image I uploaded on imgur is how I decided to do it
https://imgur.com/a/BlCK8yU And the video I’m referring to is https://youtube.com/clip/UgkxN_pEWgG...G7DOX0evmzmsQ- |
#8 |
Rust bucket enthusiast
If you're going for high boost pressure, oil WILL be coming out of that. I filtered mine and it was fine at 300whp and 15 PSI. Going into the mid to high 20s and it needed a catchcan.
Definitely do not cork or route back through the intake as OEM has it.
#9 | |
#10 |
I’m just gonna be running 8psi
#11 |
Drives: 2016 Scion FRS Release Series 2#439
Radium sell a.catch can specifically for that purpose.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. ECF on 17x8 720Form GTF2 wheels (track) |
| PCV Valve Replacement with STI Valve | apelpapa | Forced Induction | 30 | 06-03-2022 08:23 PM |
| Valve float after valve spring recall | mswbrz | Issues | Warranty | Recalls / TSB | 5 | 11-22-2019 07:03 PM |
| What's this hose? | Christopher1977 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 7 | 10-18-2018 08:35 AM |
| Hose | AncientCityFRS | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 9 | 01-24-2016 11:54 AM |
| Where does this hose go? | ChrisD | Engine, Exhaust, Transmission | 2 | 08-15-2015 06:46 PM |
