Old 02-10-2017, 10:11 AM   #15
stevesnj
stevesnj's Avatar
Any help I can give I'll do it. I will need these for as long as I have the car so they are invaluable.
My 2016 Build thread
Old 06-03-2017, 08:46 PM   #16
joro2
joro2's Avatar
Drives: 2017 BRZ Premium MT (DGM)
Absolutely fantastic resource, thank you. I've been searching for a "repair manual" like this, I miss the old days when e.g. Chilton published these for almost every make/model/year.
Originally Posted by fireblaze View Post
Subaru to come at some point in the future...
As a MY 17 BRZ owner looking forward to this, although obviously enough similarities w/ the already posted MY 17 86 documentation. Thank you again for posting these.
joro2 is offline   Reply With Quote
Old 06-19-2017, 04:58 PM   #17
celek
Resident Gear Head
celek's Avatar
Can you zip up all the source code html java ect into a downloadable zip?
PLEASE?
celek is offline   Reply With Quote
Old 09-13-2017, 08:57 PM   #18
Doraemonlam
Drives: 2016 MT FRS Base
Thank you so much!
Doraemonlam is offline   Reply With Quote
Old 10-10-2017, 01:53 PM   #19
ermax
ermax's Avatar
Drives: 2013 FR-S 6MT Raven
I stumbled on this today. Any chance we can get that image you spoke of. I hate to hammer your friends server as I build my own archive. I just fear something like this will eventually go offline for one reason or another. I would like my own offline copy that I have full control over.
Old 02-05-2019, 09:26 AM   #20
gkubed
gkubed's Avatar
Drives: 15 ZN6, 97 NA8, 87 AE82, 78 MX32
I have acquired the files behind this website. If anyone is interested in getting them, PM me, and I can distribute them to you.
gkubed is offline   Reply With Quote
Old 06-15-2019, 05:25 PM   #21
tay.green
Drives: Toyota 86 2018 Halo
Hey guys, I own a 2016 Scion FRS and am having some trouble with getting my new Spec D headlights to work (with the rewire).
So coming out of the body of the car there is the 8 pin connector and it comes with these wires:
1. Tan
2. NA
3. NA
4. Black
5. Blue
6. Black / White
7. White / Blue
8. Black / White
The Spec D Headlights come with the 6 Pin Connector but only 4 of the 6 pins are being used:
1. NA
2. NA
3. Red / Black
4. Blue
5. Blue / Black
6. Red
From digging through other forums I've found the Spec D Headlights mean this:
3. Red / Black: Motor (-)
4. Blue: Headlight (+)
5. Blue / Black: Headlight (-)
6. Red: Motor (+)
From my understanding the Spec D wires should go into the 8 pin connector as such, but it isn't working:
1. Yellow - turn signal
2. NA
3. NA
4. Black - both grounds
5. Blue
6. Blue / Black
7. Red
8. Red / Black
Does anybody know what the wires from the 8 Pin Connector coming out of the body of the FRS mean and which wires they would connect to on the Spec D Headlights? If I know which connects to which I could be done with this night mare.
Any information would be helpful, thanks.
tay.green is offline   Reply With Quote
Old 09-22-2019, 02:31 AM   #22
HSV Guy
Drives: Not a HSV (2017 BRZ)
Awesome resource, thanks for putting this up. Anyone know if there is a BRZ equivalent? I'd assume 99% of it is the same but I've got a MY2017 BRZ and looking at some info regarding the fuel sub tank and on the BRZ it is very different (basically it doesn't exist) compared to what's listed for the Toyota 86 2017.
HSV Guy is offline   Reply With Quote
Old 02-05-2020, 01:23 AM   #23
Yahya
Drives: 2015 Scion FR-S
THANK YOU I was so close to paying for a online repair manual subscription just to do damn service and maintenance lol. I honestly love you man XD
Yahya is offline   Reply With Quote
Old 04-15-2021, 07:36 PM   #24
fireblaze
Bump... (for anyone following the thread)
The original server the rip was on is now gone, see the first post in the thread for info.
There is also an offline version of this packaged as a Windows/MacOS program, again, see updated first post...
fireblaze is offline   Reply With Quote
Old 04-15-2021, 08:35 PM   #25
let's build a raft!
Thanks, @fireblaze. Sig link is updated.
Ultramaroon is online now   Reply With Quote
Old 05-17-2021, 12:06 AM   #26
nico_rsx
Drives: BRZ 2017 Pure Red, MT
If someone has the offline version mentioned in the post, I'd love to have it. For the 86 2017.
Thanks
nico_rsx is offline   Reply With Quote
Old 05-25-2021, 10:04 PM   #27
FunnyGopher
Drives: 2015 BRZ Limited
I'd like an offline version of the 2015 BRZ version PLEASE. This resource has been immensely helpful to me over the years. After seeing the message at the old link, I too would like a copy I can retain even if the server goes.
--EDIT--
I no longer need a copy.
Grams 72mm Throttle Body | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
Old 05-31-2021, 09:39 PM   #28
Autoxer62
This is very helpful, I'd like to get an offline copy as well.
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts FSB/Mann RSB/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
repair manual, service manual, wiring diagram
BRZ Headlight pin/wiring diagram 2SeeKU Electronics | Audio | NAV | Infotainment 12 06-28-2020 03:17 AM
O2 sensor wiring diagram g0odspeed Electronics | Audio | NAV | Infotainment 1 12-18-2015 06:01 PM
Wiring diagram for BCU 1GiantTurtle Cosmetic Modification (Interior/Exterior/Lighting) 0 12-07-2014 11:10 PM
2 SVC+ 2 DVC WIRING DIAGRAM PineappleFriedRice Electronics | Audio | NAV | Infotainment 8 03-03-2014 01:12 PM
Wiring Diagram for base radio? -max- Electronics | Audio | NAV | Infotainment 2 12-19-2012 05:39 PM
Copyright ©2000 - 2022, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
