Xero Limit
Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB > Technical Topics > Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Old 12-26-2019, 11:21 AM   #183
gkubed
gkubed's Avatar
Drives: 2015 ZN6, 1987 AE82, 1978 MX32
Did this on my car over the weekend, and doing it with a friend on his FR-S this evening.
It's way easier to do after releasing the engine/transmission mounts and jacking up each side of the engine. It takes <20 minutes to do and will make the rest of the job a breeze.
edit: followup - we did the entire job in just under 2 hours, from pulling into the garage to pulling out and including test starts for every plug. One little question I had, however. On both of our cars ('13 and '15), after doing the third spark plug (closest to the passenger), the car would start and then immediately stall out (over a few trials). We would re-do it, lower that side of the engine, and...it would work! My theory is that either I wasn't getting the coil pack on correctly for that particular plug, or that the engine doesn't like to be lifted up on the RH side (relative to the engine bay) on start. Has anyone else experienced this?
gkubed is offline   Reply With Quote
Old 05-19-2020, 04:48 PM   #184
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
I'm at 35K, 5 years, according to the intervals, I am due..... well my plugs are due. Does the charge capacity in the plugs wear out over time?
Should I wait another 1-2 years till 50k-60k, or do it right meow?
Mods: Helix Dark Side Markers / Dezod Cat-Back / Enkei TS9s 18 x 8.5 / Continental ExtremeContact DW 245/35/18 / Valenti Sequential Tail Lights (Black Edition) / JDL Turbo / HRI Tuned / Radium Catch Can / South Bend Clutch
https://wheelwell.com/g-ramos/2jkh/2015-subaru-brz
ShadowReaper is offline   Reply With Quote
Old 05-19-2020, 08:25 PM   #185
soundman98
Boost is Whack. N/A4LYFE
soundman98's Avatar
Drives: '14 brz limited
spark plugs are not like pizza. they don't go bad sitting.
my '14 brz limited "the return to normal" (or is it?)
led mods-10%(planning/designing/sitting on hands)audio mods-99%(done is never done)
hidplanet build log
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Busybee (05-23-2020), Dadhawk (05-19-2020)
Old 05-19-2020, 09:07 PM   #186
1st86 Driver!
Drives: "Olivia" my Firestorm 6AT FR-S
I didn't change my plugs until 120K miles when I had the spring recall done, and the one I saw basically looked new. Your wear may vary.
Dadhawk is online now   Reply With Quote
Old 05-20-2020, 05:03 PM   #187
ShadowReaper
Indulgent Tormenter
thats what I thought
Old 05-22-2020, 01:58 PM   #188
Ernest72
Did mine at 50k and they looked perfect. So you can wait for sure. I would only change early if getting a protune, but even that is overkill.
Old 05-31-2020, 04:21 AM   #189
airrick
Drives: R.S. 1.0
i would wait. Only times you should consider it unless youre at the interval would be if your car isn't starting up right away, misfiring, running weird, bad fuel economy, etc..
theres alot that problems that should be apparent when you got bad spark plugs.
i did mine at 62k and when i took off the old ones, they looked worn sure but still usable for probably at least 20k more miles so yea you should be fine.
airrick is offline   Reply With Quote
Old 05-31-2020, 11:31 AM   #190
solidsnake11
Drives: brz
Good write up, there Scenic Driver ......thanks for posting ......
I think when my FR-S gets up to that point ..... I'll just trade it in .....
Oh, the "good old days", ...... just open the hood, climb in the engine compartment and change the plugs; a 5 minute job.....
10 min for me!
hours to change. Before pic
solidsnake11 is offline   Reply With Quote
The Following User Says Thank You to solidsnake11 For This Useful Post:
humfrz (05-31-2020)
Old 05-31-2020, 11:42 AM   #191
soundman98
soundman98's Avatar
Originally Posted by solidsnake11 View Post
10 min for me!
Attachment 188823
i'd call you a cheater, but that's much more setup work than a set of plugs!
hidplanet build log
Spark plugs for turbo whitefrs Forced Induction 88 05-05-2018 09:18 PM
boosted spark plugs? 350matt Forced Induction 9 08-09-2014 03:54 PM
Spark plugs Triumphrider Engine, Exhaust, Transmission 12 06-19-2014 10:47 AM
spark plugs subaruferrucci Engine, Exhaust, Transmission 22 04-10-2013 11:24 AM
Copyright ©2000 - 2020, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
