#29 | |
Drives: Crapcan
#30 |
not playing cards
I've poked around but never found anything that looked reasonably stout. Just trading one failure mode for another.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | conehead (05-27-2022) |
#31 |
Famous Potatoes
Drives: '15 ultramarine
The only one I found was $5k and required a lot of machining of other covers and stuff, required a custom exhaust, and didn't come with lines or tank.
| The Following 2 Users Say Thank You to Sapphireho For This Useful Post: | conehead (05-27-2022), Ultramaroon (05-27-2022) |
#32 | |
Drives: 2013 WRB BRZ 6MT
A few ex-Miata guys I've spoken to about it mentioned they let the cars go because of financial pressure and the cars are getting too difficult to fix. It's my opinion that the pandemic has forced many people into making decisions about which vehicles to keep and 2nd vehicles like Miatas are the first to go while twins are often the owners only car. Factor in supply chain issues and manufacturers are just not producing parts for old cars anymore. My own 2008 Forester is unusable right now because it needs a new alternator tensioner that Subaru doesn't make anymore. I expected my experience was spreading around because I don't think the situation here is special at all but perhaps not as much as I thought. Anecdotal experiences are hard to quantify like this. |
#33 | |
Drives: None
I moved from a NB Miata and it was only because I wanted something newer that left you with more room once a cage is in the car. I'm solving the motor issue (warranted or not) though.
| The Following User Says Thank You to RedReplicant For This Useful Post: | Lynxis (05-30-2022) |
#34 |
Drives: 2020 BRZ/86, 2020 BMW 330i
What about adding an extra quart of oil?
#35 |
Drives: '23 BRZ
#36 |
That's what I used to do in my 2008 WRX, it ran fine. I guess there should be a sweet spot where you have extra oil, without it being hit by the crank.
#37 |
Drives: Crapcan
If I got to the point I needed to do that, I would just run an accusump. The crank is fairly high up since there is the oil pan, then an upper pan assembly, but I don't know how it would fair with that much oil. I'd also be curious how much more oil an AOS would pickup doing that.
#38 |
Drives: '23 BRZ
No reason to assume the "sweet spot" isn't somewhere between the "add" line and the "fill" line if you ask me... I just run it at the "full" mark and don't worry about it.
| The Following User Says Thank You to ZDan For This Useful Post: | Tcoat (05-31-2022) |
#39 | |
Drives: 2022 BRZ; 2014 BRZ
#40 | |
Drives: None
#41 |
Drives: Track preped NA FRS
Maintenance is important of course but the difference between 3 and 4 track days is not a blown engine. Synthetic oil is so good that it is very abuse proof. a dozen track days and 270 degree oil will not destroy it. Now if you are using 0w20 that could be a problem.
I'm going to guess that cautious maintainers are also cautious drivers and they aren't hitting the temps and Gs to cause starvation.[/QUOTE] Yeah you are right, but better be safe than sorry. Yes the difference between 3 and 4 is not. But between 3 and 4 and 4k miles of street driving might be. People double duting usually kind of forget their car also sees a lot of engine running time, even when just stop in traffic (it all adds up). I maintain my engine well, so I can not worry about it when im at the track. I do not spare my car any misery when im at it. So its rather the other way around. I do good maintenance so I can have my head (conscience) clear when im pounding on it at the track. |
#42 |
A maintained FA20 not boosted will last. MY 2013 (was not in recall) has about 90K miles on it. Honestly its running pretty good. Full bolt-ons with E85. I track my FRS regularly and will now be full time track car. I also have all the correct supporting mods(including oil cooler) and a solid tune by Zach at CSG
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | Icecreamtruk (06-01-2022) |
| VR6 engines... | dem00n | Other Vehicles & General Automotive Discussions | 29 | 01-25-2013 02:41 AM |
| 100 hp/l NA engines | einzlr | Other Vehicles & General Automotive Discussions | 95 | 11-15-2012 08:55 PM |
| What other engines fit our transmissions | 1strwdcar | Engine, Exhaust, Transmission | 36 | 08-02-2012 05:45 PM |
| So you think you know engines? | Ryephile | Other Vehicles & General Automotive Discussions | 43 | 02-04-2012 04:49 AM |
