08-20-2013, 09:58 AM | #71 |
Drives: Scion fr-s
I would also not run much more then -0.5 rear camber, the car is very predictable at -.2 like i have now.
Curious guys, how your clutch holds up?? i have about 10-12 drift day on those and seems to still be pretty good, even tough i know it doesn't bite like when it was new! I am wondering how long will it last! |
08-20-2013, 09:59 AM | #72 |
Drives: Scion fr-s
08-20-2013, 08:41 PM | #73 |
Drives: 2015 BRZ/ Blue Series/ WRB
Anyone running sway bars at all? I am considering beefing mine up to reduce some of my snap back on low speed corners.
2013 SWP BRZ #137 First BRZ in Columbus, OH! SOLD
2015 WRB Blue Series #900/1000 Team Rowdy Ohio Native Instgram brooks_church |
08-20-2013, 08:50 PM | #74 | ||
Drives: '24 GR86
Snap back?? I think everybody on this forum who goes to drift events frequently are running stock sways. I am too.
08-20-2013, 08:58 PM | #75 | |
used to my built S13 and lots of suspension, tires, and power. Been a while since I have drifted with such a stock(ish) car. Running a shake down tomorrow before local drift event with the new Fortune Auto's. using stock tires, and will probably get some 215's kenda's to use (local to me)
08-21-2013, 10:37 AM | #76 |
Drives: Scion fr-s
I am running stock sways also, i might try a bigger front when i have a bit more power, but for now i don't see why i would need one!
As for the clutch i am pretty gentle, i don't think it's going to be worst then my R32 Skyline. As for the snap back, i assuming you are talking about the transition, you need to be more carefull then with a S13. S13 you can throw them and they will sit nicely but this car you need to anticipate a little bit more, but if you stay gentle with the steering you shouldn't have a problem! |
08-21-2013, 06:22 PM | #77 |
Drives: '24 GR86
It's because of the Torsen diff. It makes transitioning a bit difficult to stay consistent. You can handbrake while transitioning and it works well but regardless of how quick you do it, is slows your momentum down and with the lower power, you want to keep it up.
A legit 2 way diff would make it much better. @philstar can probably commenton this because he switched to a tomei 2 way diff and said the car improved drastically after doing so.
08-21-2013, 11:35 PM | #78 | |
08-22-2013, 12:01 PM | #79 |
Drives: Scion fr-s
i would agree on that!!!
08-22-2013, 12:33 PM | #80 |
Drives: '24 GR86
[QUOTE=canu_50;1153374]I would also not run much more then -0.5 rear camber, the car is very predictable at -.2 like i have now.
QUOTE] What did you use to get that alignment? I thought they ran about -1 stock and even with LCAs and toe links, it was hard to get much less then -1 camber for the rear.
08-22-2013, 01:17 PM | #81 | |
Drives: Scion fr-s
[quote=TylerLieberman;1159192]
But most people i see on stock alignement gets around -.5 to -.3 so i didn't really ask my self any question. But i had done my alignement on my re-11 which are wider and shorter diameter then oem set up.. doubt it change anything but mehhhh... |
08-22-2013, 08:14 PM | #82 | ||
Drives: Ford Focus RS & Toyota 86 GTS
Hey guys,
Great thread! I've been setting my car up for drift as well so very happy to find this thread. Keen follow this to learn some tips from you all and maybe share a few of my own experiences along the way. Quote:
Feel free to checkout my build thread in my signature and he's a few pics from a recent morning drift session we did on Wednesday. Just click to enlarge. Cheers.
08-24-2013, 02:29 AM | #83 |
Drives: fr-s
[QUOTE=executivekoala;1163464]So I've starting getting more serious with learning and I have seen in a few other threads, how are everyone's axle's holding up? I know its been asked before but I wanted to know if i just just buy some extra axles for when they do snap.
08-24-2013, 08:35 AM | #84 | |
[quote=executivekoala;1163471]
I guess it kind of depends on how you drive and how you setup the car. I shattered a bearing casing and replaced the entire rear axle set with a 600hp rate axle from the driveshaft shop. If you want to be safe maybe keep one close by. When I did mine Toyota quoted me $1700 + fitting AUD for only the left hand side section of the axle PLUS a four week wait for the part to come out of Japan. They denied my warranty claim but that's a whole other story. The DSS were able to get me one shipped to Australia in a week and it only cost me about $1000 landed. It's obvious why I didn't go with Toyota. Best advice I can give you. If car is low and you drift in the dry, order one.
The Following 2 Users Say Thank You to JordanWho For This Useful Post: | Baldoak (12-09-2015), GT86_PRAGUE (05-26-2015) |
Similar Threads | ||||
Is there a thread for 'people doing stupid things in their brand new car' thread? | Symbiont | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 36 | 02-18-2013 12:24 PM |
BRZ Drifting. | Hunter | BRZ Photos, Videos, Wallpapers, Gallery Forum | 7 | 09-20-2012 08:57 AM |
So Cal drifting | Thefear13 | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 08-10-2012 04:53 PM |
REAL drifting thread | TylerLieberman | Off-Topic Lounge [WARNING: NO POLITICS] | 20 | 02-28-2012 04:20 PM |
FT-86 II (RC) Drifting | ft86cbx | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 8 | 11-11-2011 02:02 AM |
