Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
02-09-2018, 10:12 AM | #43 | |
Brett
Drives: ‘94 Supra
MAR17 - Catback installed/ doubled checked for leaks APR17 - Dealership installed refreshed TOB via TSB (never had issues to begin with) and replaced front-pipe due to heatshield rattle (we'll come back to this). AUG17 - One morning, the car wouldn't go into reverse pulling out of garage (clutch fully depressed). Next morning, on cold start I begin hearing a rattle from the bell housing/ transmission area. Has happened every morning since. Goes away once the car is fully warm. OCT-NOV17 - Went to the dealership because my clutch pedal was making a rubber on rubber sound, I have since then fixed this with some lucasoil grease (great stuff). Also, I started to hear that compressed air/ BOV noise I'm talking about. They checked for exhaust leaks and found nothing and could confirm the noise, but told me to deal with it and that the car is meant to make noises and to wait for something to break because it's covered. Last Week - After cold start, car wouldn't go into first gear. Had to take off in second gear and then everything was fine after that. Present Day - Did what @humfrz suggested lol. Scared the hell out of myself, so I didn't finish the process. The rattling on cold starts is more pronounced now having done so and I can hear popping at random times if I'm going slow enough when I depress the clutch. I have an appointment to the dealership for next Thursday, but I may just go tonight after work and see if they can hear me out this time. Just to be clear, I know what sounds are normal for this car. I've driven too many to not. They're raw and meant to be noisy, but I know there's something going on here and it stems back to AUG17 when it wouldn't go into reverse. Last edited by DaBoBo21; 02-09-2018 at 10:41 AM. |
The Following 3 Users Say Thank You to DaBoBo21 For This Useful Post: |
02-09-2018, 11:29 AM | #44 | |
The BOV noise sure sounds like a vacuum or exhaust issue. Perhaps something was loosened or removed when the did the other work. You positive it is an air sound? Could it be the TOB lightly brushing against the clutch fingers?
The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (02-10-2018) |
02-09-2018, 11:44 AM | #45 | |
Brett
Drives: ‘94 Supra
02-09-2018, 11:48 AM | #46 |
Ya it really shouldn't make the noise when the clutch is engaged. Probably back to a vacuum line someplace. Vacuum leaks can be a royal pain to track down.
02-09-2018, 11:55 AM | #47 | |
Brett
Drives: ‘94 Supra
Yeah, I've literally checked all the vacuum lines I could find and nothing felt loose.. |
02-09-2018, 12:17 PM | #48 | |
OK if none are loose you need to start tracing them back and looking for damage through the length. I do not envy you that task.
02-09-2018, 12:22 PM | #49 | |
Brett
Drives: ‘94 Supra
Yeah, not looking forward to it, man. lol |
02-09-2018, 12:35 PM | #50 |
No the bearings shouldn't be impacted unless the shift lever is actually putting pressure on the gear changer. This whole thing is a bit baffling! Drive over here so I can hear it would you?
The Following User Says Thank You to Tcoat For This Useful Post: | DaBoBo21 (02-09-2018) |
02-09-2018, 01:24 PM | #51 |
Brett
Drives: ‘94 Supra
I wish I could lol. Well I believe when I put it into gear position I am putting pressure on the gear changer. I think that's why the noise stops, and then when I relieve the pressure it begins again.
02-09-2018, 02:06 PM | #52 |
義理チョコ
More mysteries. :|
Staying tuned and hoping the best. Waiting for something to break is a bullshit response. "Wait until you are stranded on the side of the road at the worst possible time. Meanwhile, drive knowing it could take a dump anytime."
The Following User Says Thank You to Ultramaroon For This Useful Post: | DaBoBo21 (02-09-2018) |
02-09-2018, 02:12 PM | #53 |
Brett
Drives: ‘94 Supra
Pretty much, man. It's been very irritating and stressful to say the least. They spent two hours trying to figure out my clutch pedal noise and lubed up everything but the area that was causing the noise and it took me about 10 minutes to find it and grease it last Sunday.
The Following User Says Thank You to DaBoBo21 For This Useful Post: | x808drifter (02-15-2023) |
12-18-2019, 10:54 PM | #54 |
Drives: Halo
Any updates on what's causing the sound?
05-03-2022, 11:01 PM | #55 |
New BRZ Guy
Drives: 2022 Subaru BRZ
Was this ever fixed?
02-14-2023, 08:09 PM | #56 | |
Drives: WR Blue Pearl 2022 Subaru BRZ
Only started hearing it with the back seats down, and its almost like its after a short load up time it starts making a light air escaping noise, then when I back off the throttle it takes about 1 or 2 seconds and the hiss fades out. Back on the throttle and after a second or so it fades back in. Wondering if its the secondary cat or something that is filling or saturating and then its either leaking or vibrating something to sound like an air leak or something. Did you ever have a problem with it over time? |
Similar Threads | ||||
Road noise? Tread Noise? | zERoTu | Issues | Warranty | Recalls / TSB | 21 | 10-07-2020 10:21 PM |
Compressed Natural Gas--Compatible? Fiery Death Imminent? | HunterGreene | Engine, Exhaust, Transmission | 21 | 01-27-2020 02:31 PM |
What is that noise | MyGT86Yas | Engine, Exhaust, Transmission | 16 | 01-17-2017 04:11 PM |
Fan noise? | djliquidsteele | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 07-30-2012 05:22 PM |
