Old 03-16-2019, 12:13 AM   #15
Zentec
Drives: 2017 Toyota 86
HKz
Thanks I agree it wouldn’t bother me as much if it was one gear. But it is every gear all the time. As for shifting Im smooth and light on my grip as I’ve driven stick for decades and rid my self of those bad habits.
Humfrz
It’s hard to tell but the it’s not really a squeak but when the clutch disengages there is thud and what I can disceibe as a weighted force that goes back and forth you can actually see the shifter move in succession with the force. The shifter vibrates all over the place under normal driving. Especially over 3500-4000 all the way up the line.
Don’t get me wrong shifters vibrate and make a little noise but this is execessive. Another service director even said so. They won’t let him even look into it because that FSA sent it up the chain blocked me at other dealerships.
I did to go to Subaru although they can’t officialy say anything because of branding. They agree it’s not normal and they never had anyone bring it in because of that.
Zentec is offline   Reply With Quote
The Following User Says Thank You to Zentec For This Useful Post:
humfrz (03-16-2019)
Old 03-16-2019, 03:40 PM   #16
Zentec
Here is another vid of the thudding clutch noise when depressing the clutch peddle. [ame]https://www.youtube.com/watch?v=8VpxQwzcUu8[/ame]
humfrz (03-16-2019)
Old 03-16-2019, 05:22 PM   #17
ls1ac
ls1ac's Avatar
Will the sound change if you hold the shifter into the gate with your hand?
Will it have the noise if you put it in between gears and cost at speed?
Old 03-16-2019, 05:33 PM   #18
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
My car used to do that and quit on it's own, no changes made. If I just touched the shifter it would stop. Then go right back to it when I let up.
Old 03-16-2019, 07:00 PM   #19
Zentec
No sound remains the same will even rattle if the shifter knob is off.
I will check while in nuetral tonight.
Old 03-16-2019, 07:00 PM   #20
Zentec
If I touch it it still vibarates and rattles very loud.
Old 03-16-2019, 08:02 PM   #21
ls1ac
ls1ac's Avatar
SINCE THERE IS NO CHANGE IN THE SOUND when held or deflected, then it is doubtful that it is in the shifter linkage. The fault will probably be in the trans or drive train.
Old 03-17-2019, 12:28 AM   #22
Zentec
Could something that is off balance sending the vibration through the input shaft cause it?
Old 03-17-2019, 03:34 AM   #23
I'm going to ring up ol @Ultramaroon to have a listen to your videos and see if he has any ideas. He's pretty good at messing up - errrr, I mean messing with this transmission.
Zentec (03-17-2019)
Old 03-17-2019, 12:12 PM   #24
radroach
Drives: car
@Zentec your car sounds good
rattle from the factory is normal! Quality!
I personally think shifter rattle and clacking while pressing the clutch in is from play in the throw out bearing. The constant-contact bearing goes out of tolerance and starts throwing vibrations at certain RPM. My guess.
Old 03-17-2019, 01:50 PM   #25
義理チョコ
100% normal driveline lash.
Old 03-17-2019, 02:02 PM   #26
義理チョコ
Shifter noise link
Cable for the reverse lockout buzzes inside the lever. Normal.
Clutch raddel link
Aha! Someone was finally able to capture that damn sound! Mine does it once or twice a year on the hottest days. It's the return spring inside the clutch master cylinder. It's a horrible frightening sound but completely innocuous.
jcw99 (04-05-2019), radroach (04-05-2019)
Old 04-05-2019, 01:09 PM   #27
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
2nd gear is notorious in our transmissions (manual ones anyway). My buddies S2000, who's transmission ours is initially based on, has horrible issues with 2nd gear and it's constantly slipping out of gear. He changed transmission fluids to Pentosin and seemed to clear up most of the issues.
MJones_RB is offline   Reply With Quote
Old 04-05-2019, 03:36 PM   #28
xdavidx
Emperor McDuck
xdavidx's Avatar
Drives: 2019 86 GT; 2018 BMW S1000RR
Why is everyone so anti rattle?
xdavidx is offline   Reply With Quote
Loud Underbody *Rattle* Defect Found - Easy Fix Anorexic 86 Issues | Warranty | Recalls / TSB 32 11-12-2014 10:26 PM
Loud noise and rattle in reverse BeRZed Issues | Warranty | Recalls / TSB 0 06-23-2014 09:38 PM
Loud Rattle? 636 Issues | Warranty | Recalls / TSB 7 03-07-2014 04:52 PM
BRZ Shifter Rattle TSB sc0urge BRZ First-Gen (2012+) -- General Topics 2 08-26-2013 08:53 PM
Loud rattle, lots of shaking from shifter...not the knob...its the trans linkage continuecrushing Issues | Warranty | Recalls / TSB 8 05-18-2013 11:56 AM
