Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-03-2021, 07:39 PM | #1 |
Steve Bodalenko
Drives: Toyota 86 GTS
Verus CF driveshafts.
Simple question.
Need an honest review of the Verus CF driveshaft by those that have one installed with regard to Install difficulties, increase, if any, in NVH, and overall satisfaction with the unit. Also for those using one with the IRP shifter. Have you had any issues with rubbing with both fitted. Apparently there is a post here somewhere from someone mentioning the issue. Thanks in advance. |
09-03-2021, 07:43 PM | #2 |
Wes
With any aftermarket driveshaft, diff and subframe bushings cause a change in pinion angle and vibration at around 80 mph. Stock cars don't seem to have this issue.
Instagram: @gt86ws
09-06-2021, 03:37 PM | #3 | |
Do you think I would suffer of vibrations from the driveshaft? |
09-06-2021, 04:52 PM | #4 | |
Drives: 2017 Toyota 86
I had 2 that vibrated above 80 mph. I do have Whiteline differential, subframe, and transmission crossmember inserts, which may have influenced things. |
The Following User Says Thank You to billstock67 For This Useful Post: | gpvecchi (09-07-2021) |
09-06-2021, 05:24 PM | #5 |
Wes
Don't think so. I think it's the bushing inserts that do it. Not sure if replacement bushings do it.
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | gpvecchi (09-07-2021) |
09-07-2021, 11:48 AM | #6 | |
Drives: Q5 + BRZ + M796
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Jdmjunkie (09-07-2021) |
09-07-2021, 09:10 PM | #7 |
I would look for the original design one. I have Whiteline transmission, subframe and diff inserts along with Torque solutions engine mounts. It is possibly causing a harmonic noise above 130 MPH. Can’t say I am worried about it I don’t get there at any of the tracks around here.
Similar Threads | ||||
Half priced CF driveshafts? | Impureclient | Engine, Exhaust, Transmission | 3 | 08-28-2018 09:06 PM |
DSS vs PST Carbon Driveshafts | chazmuska | Engine, Exhaust, Transmission | 9 | 07-05-2018 08:57 AM |
PST vs DSS carbon driveshafts, anyone compare? | OICU812 | Engine, Exhaust, Transmission | 26 | 06-15-2014 03:10 PM |
Where are the aluminum driveshafts? | post_break | Engine, Exhaust, Transmission | 22 | 04-01-2013 05:31 PM |
AT Carbon Fiber Driveshafts | RallySport Direct | Transmission and Driveline | 33 | 12-15-2012 12:35 AM |
