Old 05-25-2023, 03:45 PM   #7575
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I'd string your box, if you'd let me.
Originally Posted by humfrz
I'm old and lazy
The Following 3 Users Say Thank You to Clipdat For This Useful Post:
spike021 (05-25-2023), Spuds (05-25-2023), Ultramaroon (05-25-2023)
Old 05-25-2023, 03:45 PM   #7576
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Yeah. I'm still too chicken to try a string box. @Spuds
It's not hard. You can do it!
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread"
The Following User Says Thank You to Spuds For This Useful Post:
Old 05-25-2023, 03:48 PM   #7577
Clipdat
Proud of BOXER
Clipdat's Avatar
Do you need level ground and an enclosed garage?
I'm old and lazy
Old 05-25-2023, 03:49 PM   #7578
Ultramaroon
義理チョコ
Ultramaroon's Avatar
Clipdat (05-25-2023)
Old 05-25-2023, 03:52 PM   #7579
Clipdat
Proud of BOXER
Clipdat's Avatar
I'm old and lazy
Old 05-25-2023, 04:38 PM   #7580
Spuds
The Dictater
Spuds's Avatar
You need level ground, but an enclosed garage is not really necessary, just nice to have if it's windy or raining... or sunny... in general I guess lol. The FRS parking space in my garage leans about .5 degrees down on the left rear relative to the right rear so I shim the left rear wheel with some plywood. I don't really care about minute difference front to back. Really, this amount of difference shouldn't matter if you are just measuring toe, but I like to be exact and also measure camber. Ground level measured side to side on a bubble level with two equal height standoffs at the ends.
Equipment needed includes 4 jack stands (preferably identical) with axel style fork at the top, fishing line, weights (I just use old/redundant sockets around 10mm), 2x 7ft+ PVC pipes, a metric mm ruler or calipers (I find ruler easier), painters tape, pencil, notebook, possibly a drafting compass, and a small saw.
I like this video's explanation for the string box itself.
I don't like/use their camber measurement method. I found the digital gauge to be a bit off after rotating 90 degrees. I prefer to hang a vertical next to the wheel and measure to the top and bottom.
I also started checking the thrust angle by marking the outside of the front and back wheels as they roll over the same spot and found my string box was off by about .1 degrees so it's not always perfect.
NoHaveMSG (05-25-2023), Ultramaroon (05-25-2023)
Old 05-25-2023, 04:51 PM   #7581
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Replaced stock top hats with the Pedders yesterday. It might already be common knowledge but I'm quite pleased with myself for coming up with a minimally invasive procedure.
Lifted front.
Removed one wheel.
Supported control arm with another small jack.
Lowered front.
Lashed three coils on both sides of one spring.
Loosened strut top nut.
Removed mounting nuts for both top hats.
Lifted front again until the weight of the installed wheel pulled everything free.
Went to town on the open side, blah blah blah...
Winner winner chicken dinner!
My pedders are still noise-free nearly 100k kms later
wolffbite is offline   Reply With Quote
The Following User Says Thank You to wolffbite For This Useful Post:
Old 05-25-2023, 05:04 PM   #7582
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I can make some time for you next weekend. You can come down here or I can head up that way. Car probably feels okay now, just toe'd in a little bit at the front.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Spuds (05-25-2023)
Old 05-25-2023, 05:18 PM   #7583
Ultramaroon
義理チョコ
Yeah! I'll come to you. Will be fun.
Old 05-25-2023, 09:36 PM   #7584
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
My oil report on the Lotus. Who says you have to change your oil every year?
Good news, if the leak is bad enough you'll never have to change your oil, only add new!
The Following 5 Users Say Thank You to Kiske For This Useful Post:
bcj (05-26-2023), Clipdat (05-25-2023), NoHaveMSG (05-26-2023), pope (05-25-2023), spike021 (05-25-2023)
Old 05-25-2023, 11:19 PM   #7585
Sapphireho
¯\_(ツ)_/¯
Sapphireho's Avatar
Drives: '15 ultramarine
Momma's got a string box, daddy never sleeps at night.
The Following 4 Users Say Thank You to Sapphireho For This Useful Post:
Dadhawk (05-26-2023), NoHaveMSG (05-26-2023), pope (05-25-2023), Ultramaroon (05-26-2023)
Old 05-25-2023, 11:21 PM   #7586
Sapphireho
¯\_(ツ)_/¯
Sapphireho's Avatar
Make up oil = 0
(That means no leaks for those of you new to cars)
Old 05-25-2023, 11:41 PM   #7587
Sapphireho
¯\_(ツ)_/¯
Sapphireho's Avatar
Thanks for all the thanks and good words guys.
Mom is going into a home early next week.
Kiske (05-26-2023), soundman98 (05-26-2023)
Old 05-25-2023, 11:48 PM   #7588
Sapphireho
¯\_(ツ)_/¯
Sapphireho's Avatar
Have a bud light and relax.
have you turned it off/on, i heart my boxer, i still hate you all, kiss me, maple syrup, multipass, next one is a prequel, ow my balls, special_k abandoned you, the search for more money
Random Thoughts - Part Deux [NO POLITICS] Ultramaroon Off-Topic Lounge [WARNING: NO POLITICS] 84004 03-07-2022 11:00 AM
OEM BRZ spark plug part number? qqzj Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 05-26-2017 11:33 PM
Random search on bing sdwagonjp Off-Topic Lounge [WARNING: NO POLITICS] 11 11-19-2014 07:35 PM
