Old 04-07-2020, 03:59 PM   #15
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Every car manufactured is compromised, so if every mod is a compromise then 2 negatives should make a positive...
I LIKE TIRES!
JD001 (04-07-2020)
Old 04-07-2020, 04:13 PM   #16
beltax90
beltax90's Avatar
Drives: 2010 corolla
No, seriously. I'd still like to know.
Thanks!
beltax90 is offline   Reply With Quote
Old 04-07-2020, 04:20 PM   #17
beltax90
beltax90's Avatar
PSH HAW. I KNOW WHY I CANT FIND IT ON HERE. IT"S BECAUSE IT'S NOT HERE!! HAHA
https://www.reddit.com/r/ft86/commen...really_cleans/
my bad
The Following 2 Users Say Thank You to beltax90 For This Useful Post:
Leonardo (04-07-2020), Suparu (04-11-2020)
Old 04-07-2020, 04:21 PM   #18
Leonardo
Country Boy 4 Life
Leonardo's Avatar
my bad
Now I get it! Lol
I LIKE TIRES!
Old 04-07-2020, 04:22 PM   #19
beltax90
beltax90's Avatar
I'm guessing you just get a hammer??? practice whack a mole at chuck e cheese??
edit:
AGriggs191
I just happened upon a picture of an 86 I saw on FB. I messaged the owner and he said to get in contact with Sebastian Krämer. (guy standing on a rock in his profile picture) He has a kit that he sells every once in a while, that I bought. It's a simple kit. It just has a custom metal plate that the stock light gets mounted to, and some nuts, bolts, washers, and plastic fasteners.
Pull the stock light off, pull out the carpet piece it was sitting on, drill out some plastic welds, attach the plate to the light, attach the light back on the carpet piece, reinstall back into the car, bingo bango bongo, your light is how it should have been from the factory.
If I didn't have to fuss with the carpet piece (too much hot glue from factory) I could have done this mod in less than half an hour.
hmmm, i like my hammer idea way more.
Old 04-07-2020, 07:39 PM   #20
churchx
churchx's Avatar
Drives: 2014 GT86
Again "how it should have been from factory". Right, toyota of course should have put it at height that's too low for compliance with regulations in some countries, from the factory, to prevent certification & sales there. I might agree that location at top of window imho is better, but there is bit of minimal height. I doubt there being any other reason for "spaceship" to be designed.
Same reason for them not removing eg. cats in exhaust or not "fixing" sunken in stock wheel offset. Regulation compliance in at least some of countries for car certified/sold world wide. In most cases when i see "should have been from factory", seems that poster just doesn't know reasoning behind and simply wishes for his custom mods to be already done to car.
Old 04-07-2020, 07:48 PM   #21
soundman98
ProCrastinationConsultant
soundman98's Avatar
i would be really interested to hear the reasoning of why they chose to install the third brake light at the bottom of the rear window instead of the top.
but i doubt we'll ever get a solid answer about it. it probably came down to saving on wire cost or something.
Old 04-07-2020, 08:23 PM   #22
churchx
churchx's Avatar
Drives: 2014 GT86
Not sure on that, as making that "spaceship" also may cost extra nullifying wiring savings. I'd rather bet that putting it there made sense according automated assembly/manufacturing process to make it quicker/simpler/cheaper (eg. installing whole shelf with light and ISOFIX covers already mounted on shelf in one-go (as it seems from fact that "spaceship" construction/mount doesn't seem to consider it's removal), instead of extra steps of mounting/sticking to window if on top, then connecting wires, then applying roof and side pillar trim). Spaceship certainly is there with other parts adjusted for it, eg. shelf itself, window defroster area (when i did mod of relocating light to top, had issues in winter with area behind light fogging/not defrosting for long time. Did another mod with installing extra window defrosting lines where light is).
Old 04-07-2020, 08:26 PM   #23
Infinity
Drives: 2016 Scion FR-S
Is that for sale somewhere or you made it custom?
Infinity is offline   Reply With Quote
The Following User Says Thank You to Infinity For This Useful Post:
Old 04-07-2020, 08:41 PM   #24
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I made it. I installed the leather seat skins too.
I LIKE TIRES!
Irace86.2.0 (04-07-2020)
Old 04-07-2020, 09:12 PM   #25
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I'm more about that high life (old pic).
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
soundman98 (04-07-2020)
Old 04-07-2020, 10:17 PM   #26
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
That looks great! is that available somewhere or is it homebrew?
Old 04-07-2020, 10:25 PM   #27
soundman98
soundman98's Avatar
yes to all.
some have home-brewed their own variations, others use variations of '3rd brake light relocation kits'
https://www.ft86club.com/forums/showthread.php?t=138233
i personally use the mustang version:
https://www.americanmuscle.com/highm...ight-9909.html
i believe irace uses the intec version:
https://www.ft86speedfactory.com/int...2013-ft86.html
but i've been eyeing one of these for some time for a different idea...
https://www.ebay.com/itm/Waterproof-...53.m1438.l2649
Old 04-07-2020, 10:55 PM   #28
Irace86.2.0
@wheelhaus version. Superior. It doesn’t have that string of Christmas lights look.
The Following 3 Users Say Thank You to Irace86.2.0 For This Useful Post:
Pat (04-07-2020), soundman98 (04-07-2020), wheelhaus (05-15-2020)
DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video continuecrushing DIY (Do-It-Yourself) Guides 44 11-23-2020 06:17 PM
17+ Taillights, 4th Brake Light, Valenti Brake Light Harness, PPF & More kashmir Exterior Parts (Aero, Lighting, Etc.) 7 12-11-2019 02:42 AM
DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) BirdTRD DIY (Do-It-Yourself) Guides 17 11-06-2017 08:42 PM
**PHASTEK** Rear Fog Light/Brake Light Kit for the Scion FR-S and Subaru BRZ PhastekSport Exterior Parts - Lighting 57 07-10-2017 08:14 PM
For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! Vicious LED Exterior Parts (Aero, Lighting, Etc.) 9 08-25-2013 07:26 PM
