04-21-2021, 02:18 PM | #77141 |
Drives: Crapcan
I would like to do pressure in the future but airspeed is the easiest to calibrate. Suction cup to front of car, note speed, note A/D reading. I figure it is a start with my limited ability.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Spuds (04-21-2021) |
04-21-2021, 02:29 PM | #77142 |
The Dictater
Drives: '13 Red Scion FRS
If you are saying that you calibrate it in front of the car, then put it under the car, it is still going to be inaccurate. Calibration only accounts for that specific location of the pitot tube. It will still show precise data you can compare against multiple runs, but it won't be accurate to actual airspeed.
The Following User Says Thank You to Spuds For This Useful Post: | p1l0t (04-21-2021) |
04-21-2021, 02:35 PM | #77143 | |
Drives: Crapcan
04-21-2021, 02:47 PM | #77144 |
The Dictater
Airspeed exiting the back of the car (assuming some sort of diffuser?) would be interesting data. Other than that, I would recommend pressure transducers on surfaces or strain gauges on whatever mounts for a diffuser/splitter if you have them. The biggest problem you are going to have is turbulence under the car. Idk the scale of that vs how take will affect the baseline, but be prepared for smoothing difficulties. That is one benefit of the strain gauge technique, it basically averages and damps for you.
04-21-2021, 02:50 PM | #77145 |
Airspeed indicator measures the difference between ram air and static airpressure. The difference in the calibrations based on location might tell you something...
Sent from my SM-G975U using Tapatalk |
04-21-2021, 02:52 PM | #77146 | |
The Dictater
Edit, this is wrong... Last edited by Spuds; 04-21-2021 at 05:01 PM. |
The Following 3 Users Say Thank You to Spuds For This Useful Post: |
04-21-2021, 02:58 PM | #77147 | |
Drives: Crapcan
All good info from you and @Spuds I will likely start a build thread for my car this year even though it is pretty much built, just to document stuff like this. It may be backyard hackery but it's fun to play around with so why not.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
04-21-2021, 03:44 PM | #77148 | |
The Following User Says Thank You to p1l0t For This Useful Post: | NoHaveMSG (04-21-2021) |
04-21-2021, 03:47 PM | #77149 |
You're not an ass, but actually you are wrong. See total (ram) air pressure vs static air pressure is was gives you the dynamic pressure. So when I said it compares ram air vs static I was 100% correct. If I said it measured dynamic pressure I would simply not mention the comparison (ratio).
The Following 2 Users Say Thank You to p1l0t For This Useful Post: | soundman98 (04-21-2021), Spuds (04-21-2021) |
04-21-2021, 05:00 PM | #77150 | |
The Dictater
Now I'm just a dumbass lol. But really I should have known that since that's kind of my degree... |
The Following 2 Users Say Thank You to Spuds For This Useful Post: | p1l0t (04-21-2021), soundman98 (04-21-2021) |
04-21-2021, 05:09 PM | #77151 | |
04-21-2021, 05:13 PM | #77152 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
I'm in that mood today where I hate everyone and everything. That is all.
The Following 2 Users Say Thank You to weederr33 For This Useful Post: | p1l0t (04-21-2021), soundman98 (04-21-2021) |
04-21-2021, 05:19 PM | #77153 |
The Following User Says Thank You to p1l0t For This Useful Post: | soundman98 (04-21-2021) |
04-21-2021, 05:20 PM | #77154 | |
Guilt free parts vulture!
Drives: 2013 FR-S - Asphalt 6MT
But...
The Following 4 Users Say Thank You to nextcar For This Useful Post: |
Similar Threads | ||||
Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
Random Rubber Part | OoLong | BRZ First-Gen (2012+) -- General Topics | 8 | 01-28-2014 10:31 AM |
Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
