Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
05-27-2020, 01:15 AM | #29 | |
First off, you would have a ways to go to get an 86 to beat out your old SS in a straight line or to beat out your old Boxter on a curvy road. If you want it to be a dependable, fun driving machine for weekend adventures on mountain roads, I'd suggest (like others have said) that you leave it stock until you have driven it for a while. It's performance, right out of the box, may pleasantly surprise you. Then, decide what you want it to do better and modify it to meet those goals. |
05-27-2020, 08:17 AM | #30 |
Drives: car
+1 on the clutch engagement point mod
05-27-2020, 08:30 AM | #31 |
Drives: TRD Pro Tundra and 4Runner
It's going to have to be an automatic transmission.
Sold my SS and my Boxster because my knee would ache (I have a bit of arthritis) for days after any extended driving. It was fine while I was driving most of the time, but I found myself not wanting to drive them over concern about my knee. |
05-27-2020, 08:35 AM | #32 | |
The SS was a boat on curves, but was something else in a straight line. With 0-60 coming in mid to high 4's. I think I'll eventually want the 86 to get low to mid 5's and I'd be happy. Either way, I'm definitely going to drive it a bit first. Have to make it through the break in period on the engine. Then test it out a bit. I just get the feeling I'm going to want to get rid of that torque dip ASAP for mountain roads; especially with no MT. |
The Following User Says Thank You to 86GTDriver For This Useful Post: | humfrz (05-27-2020) |
05-27-2020, 09:06 AM | #33 | |
Drives: 17 Asphalt 86
As others have mentioned, the intake is worth skipping. Drop in a high flow filter and call it a day. Does FT86SF do custom tuning? If it's a canned tune I would just consider going OFT instead. Cheaper overall, can be flashed whenever you want and later sold without much loss. Last edited by RToyo86; 05-27-2020 at 10:28 AM. |
The Following User Says Thank You to RToyo86 For This Useful Post: | 86GTDriver (05-27-2020) |
05-27-2020, 10:06 AM | #34 |
Drives: 16 Silver BRZ, 04 Silver WRX wagon
My advice is to go drive it for awhile and then upgrade things one at a time, so that you can really get a feel for the benefit. When you upgrade to much at once you can not isolate the benefit of a specific part. I have done this with both my WRX and my BRZ. For example, when I did the lightweight crank pulley on my WRX, you could feel a much quicker increase and decrease in rpms, so it was a benefit. When I did it on the BRZ I felt no change at all. Yes I know butt dyno is not the best, but if you are really honest with yourself you can make some good judgements whether a mod was worth it or not.
I wish there were stock cars available to drive to compare side by side, so you could really compare the value of a mod. I try to avoid confirmation bias as much as possible and really ascertain what works and what does not. |
The Following User Says Thank You to Ernest72 For This Useful Post: | 86GTDriver (05-27-2020) |
05-27-2020, 12:19 PM | #35 | |
Drives: 2016 Scion FRS Halo
The Following User Says Thank You to AKITA For This Useful Post: | 86GTDriver (05-27-2020) |
Similar Threads | ||||
Long term build | Zer0 | Member's Car Journals | 171 | 08-06-2022 03:57 AM |
Andy0323's Back To Basics Build Thread <Long Term Project> | andy0323 | Member's Car Journals | 15 | 02-02-2018 12:16 AM |
long term and short term | brichard0625 | Engine, Exhaust, Transmission | 7 | 08-26-2013 08:56 AM |
Fuel Trims - Long term and short term | victorb | Engine, Exhaust, Transmission | 6 | 03-27-2013 02:18 PM |
Short Term and Long Term Fuel Trims | naikaidriver | Engine, Exhaust, Transmission | 3 | 03-18-2013 09:55 PM |
