Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
09-18-2020, 11:48 AM | #1 |
Drives: 2013 Scion FRS
Looking to bench test a Instrument cluster
I did some work to a test instrument cluster and want to test the part before I put it back in a car. I was browsing through the schematics for the 2013s, and haven't found anything yet.
I was curious if anyone had already figured this out yet. I searched the forums and what I found is mostly just LED swap jobs and re installations. I will keep looking through the schematics, and if I find it I will update here. |
09-18-2020, 11:58 AM | #2 |
Drives: 2018 BRZ
Maybe a silly question, but why not test in the car? You don't need to put it back in, just hookup the connector to it.
I would imagine a test bench would need to supply much more than just 12V to get anything meaningful from the cluster. |
09-18-2020, 12:17 PM | #3 |
I haven't taken mine out of the car yet. I wanted to do quick ops check, without swapping them out. My ESD workbench isn't at home so I just wanted to test while I worked it.
I have a programmable Power supply that can support this, I have used it for much larger projects. |
09-18-2020, 01:18 PM | #4 |
Drives: 2018 BRZ
I'm pretty sure you'll want the Combination Meter, starting at page 326 here: https://www.ft86club.com/files/BRZwiringi.pdf. That would be connector D7, a straightforward 2 row 40 pin connector. Looks like it's mostly controlled via CAN, so not sure how easy it would be to get it working outside of the vehicle.
Good luck, though! |
09-18-2020, 02:16 PM | #5 |
Thanks I'll check that out. I really just need power, shouldn't need any of the signals.
Tags |
electrical, instrument panel, wiring diagram |
Similar Threads | ||||
Instrument cluster mystery | Qwimby1 | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 09-27-2018 10:07 AM |
Single DIN Instrument Cluster | Aussie | DIY (Do-It-Yourself) Guides | 0 | 04-01-2018 06:44 PM |
F/S: FR-S instrument cluster | MissDeb | Audio/Visual, Electronics, Infotainment, NAV | 5 | 04-08-2014 04:02 PM |
WTB: FRS instrument cluster | jabbajaw99 | Interior Parts (Incl. Lighting) | 3 | 02-14-2013 01:31 PM |
Scuderia Ferrari fires up V6 turbo on test bench | quik1987 | Other Vehicles & General Automotive Discussions | 0 | 08-28-2012 06:31 PM |
