Tracking / Autocross / HPDE / Drifting What these cars were built for! |
04-13-2021, 11:56 AM | #1 |
Drives: 2020 86
Wow what an interesting weekend
So this weekend I sold my Hellcat and decided to upgrade my Twin. I went ahead and dumped my 15 FRS (which had a very VERY rough life prior to me as you can see from my earlier posts) and traded it up new 2020 stripped down 86 because not counting the trade in I got it for 25k.
So I have some money to play with for the track car... I still have the XP10's and XP8's I never installed on the FRS so those are gonna go on the 86. I'm also gonna get some 57CR's in 17x9 and Falken 660's. Maybe an Oil cooler as well. I'm also thinking about getting a front splitter and wing from Verus just because it'll give me a little more traction. I'm gonna wait till my track game gets a little stronger before I start going too hard core on suspension. I could care less about power or sound for at least the time being. Anyone have any recommendations? |
The Following User Says Thank You to Jstyle For This Useful Post: | Wally86 (04-14-2021) |
04-13-2021, 12:45 PM | #2 |
Drives: 2012 WRX, 2003 RSX Type S
Y not wait for the new twins?
04-13-2021, 02:12 PM | #3 | |
The Following 3 Users Say Thank You to macuser27 For This Useful Post: |
04-13-2021, 02:18 PM | #4 |
Drives: '13 FRS - STX
lol first year new engine design from Subaru in a track car? pass
Unfortunately won't be able to get much camber with the 17x9's without doing top hats, maybe the pedders and a cam bolt could get you over -2 though, it'll pay for itself by the second set of tires, rear LCA's will be desired eventually might as well only align it once. |
04-13-2021, 06:40 PM | #5 | |
Drives: 2020 86
04-13-2021, 06:41 PM | #6 |
Drives: 2020 86
Also what are top hats?
Sorry for the newb questions... not new to racing... I am new to racing on 4 wheels. |
04-13-2021, 07:30 PM | #7 |
Drives: ADM Toyota 86 GT
Depending on the tyres you're running an how aggressively you're driving, these things need well in excess of -3 degrees camber on the front not to absolutely ruin the edge of your tyres. With camber bolts you'll get maybe 1-1.5 degrees, then with top mounts you'll get that up to around 3-3.5 degrees depending on the mounts.
Adjustable top mounts are mounts for the top of the shock that can move where the top of the shock is located. This gives you additional camber and caster adjustment. They generally come with a set of coil over suspension, although you can just buy the top mounts by themselves. If you want to go above 3.5 degrees, you'd need to get front lower control arms. This is all in my experience with Whiteline camber bolts and shockworks coilovers/adjustable top mounts running z221 semis on the track with likely too aggressive a driving style. Sent from my CPH1979 using Tapatalk |
The Following User Says Thank You to Snake For This Useful Post: | Jstyle (04-14-2021) |
04-13-2021, 07:41 PM | #8 | |
Also given your planned wheel choice you will be limited by wheel to spring perch clearance when using camber bolts, you will not be able to hit -3 without camber plates or a camber adding top hat like pedders. The rear is not camber adjustable from the factory, you need adjustable lower control arms to align the rear properly on this car. This does the job for most people: https://www.spcalignment.com/compone...tion&pid=67660 Top hats are the plates that mount the damper to the chassis, just another name for them. Camber adjustable top hats might be more proper then camber plates but meh who cares. |
04-13-2021, 07:42 PM | #9 |
Useful thread
https://www.ft86club.com/forums/show....php?p=2600171 |
The Following User Says Thank You to strat61caster For This Useful Post: | Jstyle (04-14-2021) |
04-13-2021, 08:15 PM | #10 |
Here is what I would do to be honest in this order:
Oil Cooler Coils with Camber: Look at RCE SS-1s or CSG Tien Flex A's(do it once and be done) Rear LCA's Track Alignment at a good shop (aim for -3 up front and -2 or -2.1 rear) Wheel and tire Package 17x9 and a 235-245 size tire Use Carbotech's for Track. Get second pair of rotors to swap with the pads so you can re-use stock pads on the street(quiet and dust free) Brake Ducts Don't mess with Aero yet.
2013 Series 10 FRS #553
04-13-2021, 08:38 PM | #11 |
Drives: '23 BRZ
My 0.02: rear LCAs in my case were unnecessary. I'm at -2.7 rear camber at -1.25", pretty much right where I want to be.
04-14-2021, 08:18 AM | #12 |
If you're going to run any sort of Aero package the stock suspension is not enough to handle the amount of downforce being generated. For camber, compression and rebound valving, spring rate...etc
With that being said, I think Aero is a pretty big step from a light track build to something a bit more serious.
Kyle H. - #89 STX
04-14-2021, 09:14 AM | #13 | |
Drives: 2020 86
04-14-2021, 09:43 AM | #14 | |
Similar Threads | ||||
Interesting... | Boomerang | BRZ Photos, Videos, Wallpapers, Gallery Forum | 10 | 12-19-2018 04:35 PM |
This looks interesting | g e | BRZ First-Gen (2012+) -- General Topics | 4 | 02-13-2018 04:03 PM |
The most interesting swap? | Cuchullain | Engine Swaps | 10 | 08-16-2014 07:41 PM |
All British Car Weekend THIS Labor Day weekend | stockysnail | Northwest | 5 | 09-05-2013 03:10 AM |
Why ft-86 is interesting? | NewCarInQ42011 | Scion FR-S / Toyota 86 GT86 General Forum | 69 | 11-26-2010 04:05 PM |
