Old 06-30-2018, 05:34 AM   #57
mrg666
pessimistic skeptic
mrg666's Avatar
Originally Posted by stevo_12v View Post
https://www.facebook.com/EvolutionRm...86466408045470
Update from the workshop where my car is.
This blue car isn't mine...
Looks promising, 360ish rwhp @ 6psi on PUMP GAS
Car is pretty much stock, except HKS turbo kit, Invidia CBE. Front pipe and overpipe I believe are custom fabricated parts to suit for the kit.
Stock base line dyno figures on that dyno is 130rwhp btw
360 whp at 6 psi does not sound right. You are either getting the power in kW instead of HP (which converts to 268 HP) or giving the boost number wrong.
Old 06-30-2018, 07:54 AM   #58
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Anyone else a little excited for the HKS Turbo kit?
Eehhhhh, no you got that backwards
362Kilowatts =
485.45Horsepower
Either way the boost pressure does not show how much airflow you get at that pressure. As turbos get better and better over the years they can support more and more power on a give boost pressure. '6 PSI' never tells the whole story.
Old 06-30-2018, 08:18 AM   #59
mrg666
pessimistic skeptic
mrg666's Avatar
I was trying to figure out what error was done if there was an error in conversion. 268 HP with a wrong conversion comes to a very typical number. I suspect 130 HP stock power number above should be a conversion error as well. Sure, you can use a big turbo and get more power at 6 psi. Is HKS turbocharger such a special kind? It looks just like the others in the pictures.
Old 06-30-2018, 08:30 AM   #60
Yoshoobaroo
TRACKBREAD
Hard to tell without seeing the full compressor blade and turbine really.
The other possibility is that the dyno is one of those that estimates crank HP by measuring drivetrain drag on the overrun. That number can easily get fudged then by hanging on the throttle a bit.
Old 06-30-2018, 08:48 AM   #61
86p0wa
Drives: 2013 FR-S(Traded in) 2018 Toyota 86
I would venture a guess at around 315 @6 psi on pump gas.
Now I’ll go get the popcorn
86p0wa is offline   Reply With Quote
Old 06-30-2018, 10:02 AM   #62
mrg666
pessimistic skeptic
mrg666's Avatar
OK, I give up. It is what it is.
Old 06-30-2018, 10:56 AM   #63
gtengr
Drives: 2017 BRZ
That said, there's no way he's making a legit 360 rwhp at 6 psi on pump gas.
gtengr is offline   Reply With Quote
Old 06-30-2018, 12:14 PM   #64
Yoshoobaroo
TRACKBREAD
I agree, it's unlikely.
Old 07-14-2018, 03:14 PM   #65
Mad_Infinity
Mad_Infinity's Avatar
Drives: 2015 CWP BRZ
Anyone get/install/dyno it yet? Want to see some real world results.
Mad_Infinity is offline   Reply With Quote
The Following User Says Thank You to Mad_Infinity For This Useful Post:
eightsix (03-14-2019)
Old 07-14-2018, 06:19 PM   #66
Grady
Grady's Avatar
I would say it is impossible!
6psi is 6psi no matter what turbo you put on it. You will have to improve the airflow after the MAP sensor to make more HP. The more effecent turbos and intercoolers keep the IAT down. That is how they make more HP.
Old 07-14-2018, 09:56 PM   #67
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
So a small turbo at 6psi will make the same power as a large turbo at 6psi? No. Psi is a measure of resistance not air flow.
Old 07-14-2018, 10:19 PM   #68
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
No way, I am going to take a guess and say it'll hit 230-250 at the wheels if that.
Trueweltall is offline   Reply With Quote
Old 07-15-2018, 12:13 PM   #69
Grady
Grady's Avatar
Yes but the resistance is the engine. After the turbo.
Old 07-15-2018, 12:24 PM   #70
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
6 psi is 6 psi no matter what turbo you put on it....
Jfc. False.
Never been so excited for an oil change... No Limit Motorsport Engine, Exhaust, Transmission 20 09-27-2012 11:59 PM
Beyond excited!! debs0712 Scion FR-S / Toyota 86 GT86 General Forum 12 06-27-2012 09:03 PM
Excited!!!!!! Filipino Royale BRZ First-Gen (2012+) -- General Topics 2 06-13-2012 10:14 PM
So excited to be here!!!! staycrushing Scion FR-S / Toyota 86 GT86 General Forum 8 05-31-2012 07:05 PM
Brisbane get excited! spr1nter AUSTRALIA 29 05-14-2012 07:07 PM
