Forced Induction Turbo, Supercharger, Methanol, Nitrous |
08-10-2020, 09:37 PM | #15 |
Drives: 2017 toyota 86
What about OEM vs 1050x? for drive ability, tuning, quality of life etc... assuming you’re not maxing out oem maybe at 80-85% and OEM are working just fine. Does the 1050x atomize better or have more precision?
The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | sroby (08-17-2020) |
08-12-2020, 07:57 PM | #16 |
Drives: Q5 + BRZ + M796
The OEM port injectors are like 200s, so there isn’t a whole lot of overhead. You can’t run the direct injectors at 80%, so you are limited there too. Most people max out NA with E85 and most don’t go over 10-12ish psi on stock injectors. It depends on the tuner. Some tuners don’t want to mess too much with direct injectors, so the ports will run out fast.
08-12-2020, 10:08 PM | #17 | |
Drives: '14
08-12-2020, 10:20 PM | #18 | |
What one is better? Not for overhead/max potential. but tune-ability, drive-ability, precision, better atomization etc... If oem is 200cc 1% would be 2cc vs 1050cc 1% is 10.5cc. So does OEMs have a lot more precision, or does the 1050x make up for it in someway? can the 1050x limit flow enough that at idle or low rpm it’s not super rich? |
08-12-2020, 10:26 PM | #19 | |
I’m at 12.5psi E45 WMI Probably making 285-290whp and tuner has no concerns on my injectors. Even if E85 with no WMI it would be pushing similar numbers and be pretty close to maxing injectors so it might be advised at that point but sprintex is probably the least efficient blower for top end power with how much parasitic draw the blower takes. |
The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | kev0 (08-12-2020) |
08-12-2020, 10:44 PM | #20 | |
Drives: '14
"Also, any reason why you're running ethanol on stock injectors with boost? Though possible, you're stretching the limits and shortening the life on the fuel system. You're also going to be getting very poor atomization and essentially zero rest time on both sets of injectors, vastly increasing chance of failure for various components. Just so you know!" Like I said earlier, so many conflicting information but injectors are pretty cheap so I might as well get it. |
The Following User Says Thank You to kev0 For This Useful Post: | Irace86.2.0 (08-12-2020) |
08-12-2020, 10:56 PM | #21 | |
08-12-2020, 11:09 PM | #22 |
Drives: '14
08-12-2020, 11:43 PM | #23 | |
08-12-2020, 11:59 PM | #24 | |
At low loads and idle the car is running on direct injection, so it isn’t an issue. The 1050s will just be better overall than 700s because they are a better Bosch injector, but not necessarily worth it for everyone. If they are 50% more expensive, they not 50% better in terms of other metrics, if that makes sense. https://www.ft86club.com/forums/show...56&postcount=4
08-13-2020, 12:21 AM | #25 | |
08-13-2020, 12:34 AM | #26 | |
OEM vs 1050x what is better even if OEM still has head room. |
08-13-2020, 12:41 AM | #27 | |
08-13-2020, 01:07 AM | #28 | |
Similar Threads | ||||
Difference Between V2.076 and V4.03 | NyX_Nick | Software Tuning | 2 | 06-01-2018 10:00 AM |
What's the difference | DarkSideFRS | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 02-09-2018 09:12 AM |
bra difference from frs | shift2launch | BRZ First-Gen (2012+) -- General Topics | 5 | 01-22-2015 01:00 AM |
cat/no cat hp difference? | EN2_Squirrel | Engine, Exhaust, Transmission | 6 | 11-17-2013 09:32 PM |
LED vs HID: what's the difference? | GhostofAkina | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 04-06-2013 07:23 AM |
